Mythbusters actually tested this years ago, you can probably find a discussion of it on their website. IIRC, using a/c was more efficient, especially as speed increased. Volt is going to run a/c to cool the battery anyway and that also comes into the cabin, nothing you can do about that, so you might as well close the windows and at least use that "free" a/c. In my experience, using a/c (unlike heat) doesn't have a very noticeable impact on range, but I don't live in TX so I don't crank it as much you'd need to.
My guess is that at highway speeds the AC will be more efficient, why don't you run the experiment and report the results. I live in New England where we have the opposite problem, summers are fairly mild so the AC has very little effect on MPGe, but in the winter the heater sucks electricity like there is no tomorrow so I rely on the seat warmers except on the coldest days where I run on the ICE instead of the batteries.
Use the a/c on ECO mode and you will not see much of a range change. Here in Phoenix I use the system in ECO mode and only see about 1 or 2 mile decrease in range. The a/c will run anyway above 85 degs or so to cool the battery so you might as well use it to cool off the cabin as well. In comfort mode, it uses a lot more power. You can see this if you put your screen in the hvac display and it will show you a percent number (gen 1) so you can see the difference between ECO and Comfort modes.
My suggestion for hot days: Roll down all your windows and let the car air for some time. Then close all windows and run AC. Start in Comfort, and once the car is comfortable, switch to Eco. Be Calm. You drive a Volt
If the temperatures are in mid 80s or lower, opening the windows works but who wants to inhale all that polluted air and deal with road noise? I roll down my windows f I am on a quite road with not much traffic, and road noise is bearable. I also have the buffering kit, which helps reduce wind buffeting.
My suggestion for hot days: turn the a/c on remotely 10 minutes before you leave. You will step into a comfortably cool car, and the hit on range will be tiny.
Supposedly if you open a back door, then open and close the front door a few times to pump out the hot air it will help reduce the heat load at startup.
So....
I put a sunshield in the front window and a pop-up one in the drivers side window so I don't fry my butt. That tends to be a 10-18 degree drop right there.
Then windows down to dump the heated air while the A/C fires up
Then windows closed and a/c
Then again I live in VA where it doesn't get quite as hot, but the humidity will punish you.
Mythbusters even got it wrong the first time and had to do a follow-up "revisted" episode to correct their original mis-information that windows down was more efficent...What they found the second time around, in 2004 I might add, is with their test vehicle, when going 50mph+ was more efficient with the A/C on than it with the windows down...
However, their vehicle they used in 2004...
Doesn't have the same frontal area or Cd as the Gen2 Volt...
Doesn't use the same A/C system as the Gen2 Volt...
Doesn't a vehicle in which the batteries are more "sensitive" to ambient temperatures...
Then you have the variables...
What A/C temp set to?
A/C set to ECO?
What are you going speed?
How many windows were you putting down?
Are they open a crack and all the way down?
Ambient temperature?
Does elevation change the results?
If your route includes steep inclines or declines, will that change the results?
Unfortunately lots of testing and data points are needed, to parrot the 2004 mythbusters test that "50MPH is more efficient with the A/C on" isn't accurate...
1) hold unlock as you walk to the car (or if the car is really close, hit it before you leave your workarea/desk/office/whatever)
to roll down all windows and exhaust the hot air
2) if using A/C, initiate remote start once the windows have been down for a minute or so, if not, just get in and enjoy the breeze as you drive.
AC is better at highway speeds. But it's only about a 10% hit for freeway speeds with all 4 windows down. That may be worth it if you prefer the breeze and fresh air.
I think the point to remember is that you can't really compare in this case due to the differing way in which the compressor is powered. If I recall the mythbusters segment they were comparing how much power is sapped from the engine and how much additional fuel is used to operate the compressor. Since the compressor is not directly driven off the engine it could be said that "zero" power is being used from propulsion. I personally have not yet noticed any significant decrease in mpg with or w/o the AC operating compared to a traditional ICE powertrain. I do a mix of both right now as we've had some great weather lately with temps in the 70's and lower 80's.
Also I think one should keep in mind that on extreme temp days the A/C will almost certainly be running for thermal maintenance on the battery anyway so even with the windows down and a/c off, you might still be running the compressor and losing additional power to drag as well due to BTM.
There's no free lunch... our electric compressor is competing for battery energy that the traction motor could use, equivalent to an ICE car using more gas with a/c on than off due to extra load on the engine. In both cases, some energy that could be used for range is being siphoned off for cooling. The overall efficiency argument is essentially the same with either car type.
I open the hatch door at the back then I open the driver's door and wait a minute before closing the hatch and entering the car. I found that preconditioning isn't really working well with our California Sun even though it works well for heating the cabin during the winter.
If the AC compressor is running for battery cooling, I don't think that means it is using the same amount of power as when it is running to cool both the battery and cabin. So if you are really hypermileing, that might be an issue.
I have tried various methods and my personal conclusion is that the AC is so efficient that it is not a large enough hit to range (IMO) to matter more than my own comfort. It is nothing like the heater. So I set AC for comfort. I would not be willing to have windows down at freeway speeds with significant noise even if that were more efficient. If I am driving 40 or less and it is comfortable outside, say below 75 degrees with moderate humidity, I may have windows down just because that would be comfortable. But any hotter or faster and I turn on the AC.
Plus there is the wind buffeting issue which means that only certain window opening combinations are tolerable, so when there are passengers that each want to control their own window, it is just simpler to go with AC.
If you set it to eco mode, the AC consumption is negligible. When the car is at full stop, I watched my energy consumption kW readout, it says 0.5 kW, the same value when the AC is turned on in eco mode.
I just initially vent out the hot air inside the cabin by opening the hatch and driver's side door for a minute. Then close them and drive with all windows open for about a couple of minutes, then close windows and set the AC to 68 deg F and eco mode, while outside is 90+ temperature, sometimes the ambient air reaches 120 deg here in the summer mid-afternoon.
In the middle of an Arizona summer, when the temps are 115-120 degrees, my idle energy use will read as high as 6 kWh for a few minutes, then it drops to about 2 kWh for about 15 minutes, after that it settle down to 0.5-1 kWh. I always roll all the windows down for the first minute to get all the super heated air out of the car, then it's all AC with the windows up.
Related Threads
GM Volt Forum
1.2M posts
84.8K members
Since 2007
