Phonebook update failed
Grab our Forum Feed
+ Reply to Thread
Results 1 to 2 of 2
Thread: Phonebook update failed
  1. #1
    Join Date
    Apr 2017
    Location
    Northern Virginia Metro.
    Posts
    1
    Question Phonebook update failed
    2014 Volt
    Pixel Phone running Android 7.1.2
    After pairing via bluetooth the phone and allowing the phone to share everything with the car my volt keeps prompting me with "Phonebook update failed".
    Has anyone else encountered this problem before, does anyone have any suggestions on resolving it?
    Thanks!
    DB
  2. #2
    Join Date
    Jul 2013
    Location
    North East USA
    Posts
    1,020
    Default
    Most Bluetooth pairing issues can be resolved by the following steps
    Delete phone from car
    Delete car from phone
    Reboot phone
    Restart car
    Following documented pairing process
    Last resort end-user has is resetting the phone and doing the aforementioned steps
    If it still does not work, try using a different phone with the vehicle. If that phone also has the same issues, then take the car to the dealer and request service. You can tell them you tried all other options and strongly believe the issue is with the car.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Infotainment / Bluetooth / Phonebook / Samsung question
    By brightonrock in forum Generation 2 Volt (2016-2020)
    Last Post: 02-08-2017, 12:32 PM
  2. How to access Bluetooth Phonebook from Main Menu?
    By crodgers79 in forum Newcomers to GM-VOLT.COM (See here for FAQs)
    Last Post: 01-25-2013, 12:43 AM
  3. Problems with Motorola RAZR Maxx and Bluetooth Phonebook Pairing
    By JeremyK in forum Generation 1 Volt (2011-2015)
    Last Post: 11-30-2012, 11:31 AM
  4. HTC EVO and Phonebook pairing
    By Brandon in forum Software & Programming/Code Discussions - Chevy Volt
    Last Post: 02-19-2012, 11:25 PM
  5. phonebook
    By keegs54 in forum Generation 1 Volt (2011-2015)
    Last Post: 03-26-2011, 12:11 PM
Tags for this Thread
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
