Questions about Hold mode
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Questions about Hold mode
  1. #1
    Join Date
    Jun 2016
    Location
    San Diego
    Posts
    8
    Default Questions about Hold mode
    Still learning about my new 2017 LT.
    I'm nearing the end of an inaugural ~2,000 mile road trip, basically Mexico to Canada by way of the Grand Canyon and Utah national parks, where I did not expect to find--and have not actually found--any charging facilities.
    So, when I left, and every time I start it up again, I switch to Hold mode. My rationale is that, rather than burn through the EV range in the first 50 miles of a very long trip, I view the battery as an emergency can of gas, in case I run out of gas out in the boonies.
    1. When in Hold, with the battery full, what happens to excess energy generated by braking and coasting? Is there an extra buffer in the battery that can only be charged by the ICE, rather than when plugged into the wall, so that the car can still behave as a hybrid even with the battery full while on Hold mode?
    2. I'm about 1800 miles into the trip, charged the battery to full before I left and have not charged it on the trip, and have used Hold religiously with every start. Nevertheless, the battery level is now only about half full. So, it looks as if some of the battery energy is nevertheless being consumed in Hold mode? My sense is that it is using it most for hill climbing. The level will rise a little after a series of long descents from mountain passes.
    Thanks
  2. #2
    Join Date
    Oct 2013
    Location
    Fighting Illini country surrounded by bean fields
    Posts
    9,486
    Default
    I think you are the first person who reported this and attempted this. If you were using Hold and going up big mountains, it is very likely what happened. Except, if you stop the car, then restart it after any rests, then hit hold mode, it will reset your Hold state of charge to the line on the guessometer. So when you are going down hill for a long stretch regenerating, you will see some new green bars above the gray bar on the guessometer. If you switch to normal, then back to hold, you will reset the hold line to the top of the battery level. So if you have a really long stretch and you can regain all your bars, switch to normal then back to hold so the car doesn't consume what you saved...otherwise it will eventually go back down to the original Hold line when driving uphill or even on flat land.
    As for what happens when you regen and exceed the battery capacity, the regen gets lost as heat. I think I read somewhere that the electric motors work against each other and the heat goes into the radiator. I might be wrong on this one.
    LLninja (greenback troll #1)
    2013 Volt G1 white diamond tricoat
    If I can get the guy in the mirror under control I can be skinny and rich.
    If you don't have the money, don't buy it. Debt is hazardous to your wealth
    Hidden Content Originally Posted by doctorq Hidden Content
    "what kind of mental problem do you have? you should really get yourself checked out, are you on any type of psychotropic medications?
    R:IQ $2.2M, at $1.7M proj $4.8M
  3. #3
    Join Date
    Sep 2016
    Location
    Chicago (W Suburbs)
    Posts
    467
    Default
    Quote Originally Posted by llninja View Post
    MGA actually spins the ICE with no fuel. For some reason I notice this happening more often when the battery is empty; there's one intersection close to my house where I usually approach at 55 MPH and it's slightly downhill, and if the engine is on when I start using regen-on-demand, it will stay spinning but it doesn't sound like it's running. I can hear the motor working to spin it. I think it has something to do with the battery heat as well...if the battery's too warm, it won't accept much regen at all.
    2016 Kinetic Blue LT
    Unscheduled service visits: 4 Hidden Content
    Longest service visit: 2.5 weeks
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Aug 2008
    Location
    Gwinnett County, GA
    Posts
    131
    Default
    I've had a similar question about the hold mode. Since my 2017 went into FMM I have been using the hold mode on every start for 11 or 12 days trying to burn through the full tank of dealer gas that was in the car. Over 340 miles, the car has used almost 5 KwH from the battery, even though the hold mode was always engaged. I guess I was wrong, but I thought the reason behind the hold mode was to use the ICE, and not the battery. Anyway, the marathon is almost over as my fuel range is down to about 120 miles, so I'll soon put 3 or 4 gallons of non-ethanol gas in the tank and recharge the battery.
  7. #5
    Join Date
    Oct 2013
    Location
    Posts
    9,486
    Default
    Wow, the crazy things people do... you know you can just put a gallon of fresh fuel in and the FMM will stop while the computer understands the blend and takes that into account. Make sure you use a top tier fuel brand. Mobil, Shell, and BP are, as well as many others, but surprisingly Marathon was not (last I checked).
  8. #6
    Join Date
    Feb 2015
    Location
    England
    Posts
    1,532
    Default
    1. Yes, that's right.
    2. Yes, that's right.
  9. #7
    Join Date
    Nov 2015
    Location
    Sunny California
    Posts
    87
    Default
    Quote Originally Posted by ampera_jed View Post
    1. From what I've read and watched, that is correct. There is an extra buffer in the battery that can only be charged by the regen. So if you live on top of a hill and drive down the hill on a fully charged Volt, then it will further charge the battery through regen. How much is this buffer? I have no idea. But apparently there is a buffer.
    2. llninja explained this pretty well. I've done that many times. Both expending battery due to going up a hill (or accelerating too quickly) and losing bars while on HOLD as well as gaining bars by manipulating HOLD/NORMAL when going downhill.
    2016 Volt LT | Iridescent Pearl | Jet Black w/ Jet Black | Comfort Package
  10. #8
    Join Date
    Aug 2008
    Location
    Gwinnett County, GA
    Posts
    131
    Default
    I could but I don't want the FMM back for a long time. I plan to run it down to about 30 miles estimated [about 1/2 gallon] and then put in 3 gallons of non-ethanol regular. Ouik-Trip has started selling non-ethanol regular in this area, and that's a tier 1 gas.
    This FMM is the first gas I've burned except for a few EMM's in the nine months I've owned the car.
  11. #9
    Join Date
    Feb 2014
    Location
    Portland, OR
    Posts
    573
    Default
    Quote Originally Posted by O'Dell View Post
    Unless the Gen 2 FMM is very different from the Gen 1 version, once the FMM is started, you can’t drive in Electric Mode until the FMM is ended. You don’t need to use Hold at all. The ICE should run when you start driving each day even if you remain in Normal.
    As for your kWh usage... when I was experiencing my second FMM some time ago on my Gen 1 2012 Volt, I plugged into the grid each night to keep my battery "topped up," and I noticed that when I drove off the following morning, I would burn off some electric power (a couple of days it was 1.3 kWh, a couple of days only 0.8 kWh), none of which was recorded as Electric Miles, before the ICE would start up and the system switched to recording gas as the fuel being used. On the night before the day I expected to use up my gas, I did not plug into the grid, and the next morning the ICE started up immediately and no kWh usage was recorded. Perhaps plugging into the grid overnight to keep the battery fully charged during an FMM increased the battery SOC slightly above the "fully charged" SOC %, and that bit of excess power was consumed when my 2012 Volt was first started the following morning before the ICE started up (I did not monitor the OBD port for this SOC factor).
  12. Advertisement
  13. #10
    Join Date
    Aug 2008
    Location
    Gwinnett County, GA
    Posts
    131
    Default
    Sounds reasonable, wordptom, but I haven't plugged in since the FMM started. However, I do have plenty of EV range remaining - over 50 miles. I do get the EV mode after a startup, but it also happens under normal driving too, seemingly at random. Although I'm sure random to me means I just don't understand the reason and the car knows exactly what it's doing.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. That's weird, no more chuggle. Or Mountain Mode vs Hold Mode
    By EV Islander in forum Generation 2 Volt (2016-2020)
    Last Post: 07-23-2016, 04:57 PM
  2. 2015 Volt Mountain Mode vs CS/Hold Mode efficiency
    By schraitle in forum Generation 1 Volt (2011-2015)
    Last Post: 05-23-2016, 11:41 PM
  3. Is Mountain mode equivalent to Hold mode if the battery is at 50%?
    By Darren Donovan in forum Generation 1 Volt (2011-2015)
    Last Post: 10-27-2015, 11:38 AM
  4. Adapting the Mountain Mode for MY2012 Volt to function like the Hold Mode
    By hovite2000 in forum Chevy Volt Accessories and Modifications
    Last Post: 12-17-2013, 10:04 PM
  5. allow reprogramming of Mountain Mode to EV Hold Mode and I'd buy a Volt now
    By jimltz in forum Suggestions for GM - Chevy Volt
    Last Post: 02-13-2013, 01:00 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
