Question about preconditioning and rate based charging
Grab our Forum Feed
+ Reply to Thread
Results 1 to 9 of 9
Thread: Question about preconditioning and rate based charging
  1. #1
    Join Date
    Apr 2017
    Location
    Ontario, Canada
    Posts
    6
    Default Question about preconditioning and rate based charging
    Regarding rate based charging, does this apply also during preconditioning? My off-peak hours are 7pm-7am, but I normally don't leave until 8am. I would like to precondition while plugged into my EVSE, but I'm wondering if my option to only charge during off-peak peak hours will prevent the Volt from pulling power from the EVSE during the precondition.
    Any input or tips are appreciated.
  2. #2
    Join Date
    Mar 2017
    Location
    Ontario Canada
    Posts
    76
    Default
    Activating a precondition will draw grid power regardless of any rate/time/location based charging restrictions. It's all completely overridden at that point.
    We are in the exact same situation as you, also located in Ontario. My wife leaves every morning around 7:30AM (and the Volt is configured to avoid the 7a-9a peak electricity period for normal charging) but it does indeed draw over 3KW from our grid (as verified on my whole-home wattage display) during precondition.
    -Mark, Ontario Canada
    -2012 Volt
  3. #3
    Join Date
    Apr 2017
    Location
    Ontario, Canada
    Posts
    6
    Default
    Quote Originally Posted by PrivatePilot View Post
    Thank you, that is exactly what I was hoping to hear!
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Jul 2013
    Location
    North East USA
    Posts
    1,041
    Default
    In my Gen 1, it pulls power from the wall when preconditioning even when the rate is not favorable but once the precondition stops, it will not top up the battery (in some cases, precondition can draw more than 3.3kw, or 3.6 in case of gen 2, and the difference comes from the battery)
  7. #5
    Join Date
    Mar 2017
    Location
    Ontario Canada
    Posts
    76
    Default
    Quote Originally Posted by telveer View Post
    You know, I hadn't even thought about that part of the equation.
    I think I'll adjust my time of use configuration to move the low-rate schedule end ahead an hour to 8AM, despite the fact it actually ends at 7AM - this way when we precondition at 7:15A every morning it'll top off the battery afterwards.
    -2012 Volt
  8. #6
    Join Date
    Apr 2017
    Location
    Ventura, CA
    Posts
    31
    Default
    Ok newbie time for dumb question. How do I do the precondition? Is it the same as the remote start option on my key fob? thanks
  9. #7
    Join Date
    Dec 2016
    Location
    Maryland
    Posts
    337
    Default
    Quote Originally Posted by dmatt13 View Post
    Yes, the remote start will precondition the battery and also heat or cool the cabin depending on the last climate control setting.
    Drive electrically and enjoy the difference!
  10. #8
    Join Date
    Oct 2010
    Location
    Nashville, TN
    Posts
    2,246
    Default
    Or if you leave the HVAC in Off or Fan Only, it will do what ever it needs to reach the set temperature.
    2017 Premier Siren Red - H 0157 - Hidden Content Born 2/01/16 - Delivered 2/27/2016 Hidden Content
    2013 Crystal Red - D 2516 - Delivered 10/16/2012 .... Returned to Ally 11/07/2015
    U235 Powered
  11. #9
    Join Date
    Apr 2017
    Location
    Ventura, CA
    Posts
    31
    Default
    Quote Originally Posted by jcanoe View Post
    That's what I figured but wanted to be sure. Thanks for clarifying for me.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Charging Rate 12 or 8 Question
    By ticoemsa in forum Generation 2 Volt (2016-2020)
    Last Post: 02-28-2016, 01:27 PM
  2. Modding volt for 6.6 charging rate is out of the question?
    By striker in forum Chevy Volt Accessories and Modifications
    Last Post: 11-28-2014, 02:25 PM
  3. Gen 2 charge rate question....
    By MrEnergyCzar in forum Generation 2 Volt (2016-2020)
    Last Post: 11-13-2014, 07:10 PM
  4. Preconditioning Question
    By MPG33095 in forum Generation 1 Volt (2011-2015)
    Last Post: 09-24-2012, 09:55 AM
  5. Question on preconditioning while plugged in
    By supafrovolt in forum Generation 1 Volt (2011-2015)
    Last Post: 01-17-2011, 04:06 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
