2013 not fully charging (green bar)
Grab our Forum Feed
+ Reply to Thread
Results 1 to 10 of 10
Thread: 2013 not fully charging (green bar)
  1. #1
    Join Date
    Apr 2017
    Location
    North Carolina
    Posts
    2
    Default 2013 not fully charging (green bar)
    Hey folks. First post.
    Background: I've owned a very lightly used 2013 Volt (30k miles, mostly gas driven from previous owner) for the last 4 months problem free. The car charges on a 120v dedicated 15amp circuit. I always change the power level in the menu prior to charging.
    Issue: The last few days my Volt has not been fully charging. (I'm well aware a full charge number largely depends on the previous few days of driving and charging and climate control usage).
    The issue is the car does not fully charge indicated by the green power bar. After a full nights charge the car is missing 2-3 bars on the power meter and the mileage number matches. Nothing has changed in my household.
    Any ideas as to what is going on?
  2. #2
    Join Date
    Jan 2011
    Location
    Fresno, CA
    Posts
    1,718
    Default
    Several possibilities:
    It could be the charger is not finishing the charge because of settings in the charging menu not allowing enough time. (If you have a preset finishing time for charges)
    Or your car's clock could be set wrong.
    Or charging is getting interrupted due to power glitches from power company.
    Jerry, Fresno, California
    2017 Bolt ordered, Orange Sunburst, w/all options,
    #536 2011 Crystal Red Volt,
    2012 Diamond White Volt, saved from the crusher, gift to my niece.
    1975 Cosworth Vega, stored
    1988 Formula Fiero, also saved from the crusher, in the midst of restoration.
  3. #3
    Join Date
    Oct 2014
    Location
    phoenix
    Posts
    159
    Default
    Does the KW used this charge reset back to zero after your charging is done? What does the charge light on the dash show, solid green, blinking fast, blinking slow? You may check to make sure you do not have time of rate set to winter/summer rates as this may have changed your time your car will charge.
    Not just a volt tech, also a volt owner.
    2015 Volt
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Jul 2008
    Posts
    1,969
    Default
    When you get to your car after a full nights charge, look at the flashy green light. What does that tell you? See if the car thinks it is fully charged. Then, see if the car will accept a charge. Unplug and watch the flashy light. Do this first and this will tell you a few things and can rule out a few things.
    Combine my post with mpmoore1979 and you will probably figure this out.
  7. #5
    Join Date
    Aug 2012
    Location
    Georgia
    Posts
    123
    Default
    My 2013 was doing this and it turned out to be an issue with a section of the HV battery(that was replaced), but I eventually got a CEL as well.
  8. #6
    Join Date
    Aug 2009
    Location
    Texas - DFW
    Posts
    4,433
    Default
    If the charge is being interrupted, it could be an electrical issue. Several have reported various issues with coffee makers and other stuff interfering with the EVSE operation. The EVSE has built in low voltage and GFCI detection, so, a voltage or ground fluctuation could do it.
    First thing I would try is using a different outlet on a different breaker.
    Driving a show car. Every day! Hidden Content
    2014 Crystal Red ELR (REDD) code R w/Cashmere interior
    L2 - GE WattStation
    iOS 10.3 on iPhone 6. MyCadillac App version 3.5.0
    Hidden Content
    Hidden Content
  9. #7
    Join Date
    Jan 2015
    Location
    Missouri
    Posts
    1,370
    Default
    Quote Originally Posted by stiff_muffins View Post
    A few questions need answered:
    1. Is the charge indicator blinking green, solid green or yellow?
    2. Do you schedule charge or do you charge immediately
    3. What time do you begin your charge and what time do you unplug?
    2013 Volt Silver Topaz Metallic [Blue]
    2013 Volt Cyber Gray Metallic [Gray]
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
    2013 No Cabin Heat? Perform a forum search on: PIC5796 PIC5943 PIC5855
    2013 Losing Miles? Perform a forum search for the following: PIC6138
    Hidden Content
    Issues contact a Volt Advisor 877-486-5846
  10. #8
    Join Date
    Jun 2016
    Location
    Dallas, TX
    Posts
    88
    Default
    It sounds like you are changing the charging rate to 12 amps when you start. I'll bet the car is dropping back to 8 amps during the night due to perceived issues with the electricity.
    2013 Base, Summit White w/ Pebble Beige, purchased 8/2/16
    Hidden Content
    Hidden Content
    Hidden Content
  11. #9
    Join Date
    Jul 2016
    Location
    florida's spacecoast
    Posts
    170
    Default
    Remember, the climate where tou live also determines how much charge the vattery gets
    Overnite in a cool climate affects the battery
    in the sumner month's , around august the hottest months of the year, you will pick up a few more ev miles compared to the winter time ,when you lose ev miles
    Remember, you need a dedicated electricial conbection when you charge you're car
    If anything else shares that circut, you could pop the circut breaker and you will stop charging your battery
  12. Advertisement
  13. #10
    Join Date
    Apr 2017
    Location
    North Carolina
    Posts
    2
    Default
    No electrical issues, this is a dedicated circuit correctly rated and only used for the Volt.
    Always change to correct 12 amp in the interface before charging
    No clock issue even though sometimes the car changes the clock and its off by hours (hasn't happened in a while but i adjust right away)
    Charging light aligns with correct functions
    Solution found:
    Using the "charge immediately" at maximum amps for the past few nights solved the issue. My 2013 is registering 50+ miles on screen next to the fully charged bar and obtaining every bit of it during my commute.
    I live in NC so the weather stabilized a while ago so the effect on the battery happened back in those 80 degree February days / mild March.
    I'm not sure why I'm scoring more mileage with the same driving routine / pattern and weather, but I'll take it. My typical "delayed charge" must not have taken into account the extra mileage. Hence the car being at 43-45 and missing a few bars and still charging upon departure.
    Thanks for all the help and suggestions. I'll keep an eye on it the next couple weeks and report any new findings.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. 17-NA-064 Vehicle Not Charging to Full Capacity, Top Charge Indicator Bar Unlit
    By WopOnTour in forum Bolt Service Bulletins, Campaigns, and Recalls
    Last Post: 03-31-2017, 05:21 AM
  2. New 2013 Fully Loaded Volt - Pricing negotiation
    By RJS2015 in forum Buying, Leasing & Selling - Chevy Volt
    Last Post: 07-13-2015, 10:21 PM
  3. Found a Fully loaded 2013 with 52k Miles, what does every one think?
    By Sprayed01 in forum Buying, Leasing & Selling - Chevy Volt
    Last Post: 05-15-2014, 09:40 PM
  4. Any fully-loaded 2013 Volts out there?
    By drusoicy in forum Buying, Leasing & Selling - Chevy Volt
    Last Post: 08-13-2012, 07:14 PM
  5. Each Green Battery Bar = X%
    By Frankman in forum Generation 1 Volt (2011-2015)
    Last Post: 06-02-2011, 10:03 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
