One touch blinkers
Grab our Forum Feed
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: One touch blinkers
  1. #11
    Join Date
    Oct 2015
    Location
    San Jose, CA
    Posts
    69
    Default
    To be honest, I didn't know about this feature; so cool! I guess when you keep cars for 20 years ('97 Geo Prizm -> '17 Volt) you don't think about all of these possibilities. Now if I could just find the hand cranks for the windows.
  2. #12
    Join Date
    Dec 2013
    Location
    NJ
    Posts
    2,402
    Default
    My VWs had the feature, the Prii didn't.
    2014 Volt, Brownstone Metallic, Loaded.
    Penguin-The other white meat.
  3. #13
    Join Date
    Jan 2016
    Location
    Portland, OR
    Posts
    44
    Default
    I personally dislike it, too. I would prefer the control of blinking only as long as I'm pressing it. The main reason I dislike it is that, on more than one occasion, I'll check if a lane is clear, press my blinker, and then suddenly have to not actually make that lane change - either because someone else is coming into that lane, or it's the wrong exit, or whatever - and the car continues blinking to indicate my change, even though I'm not doing it anymore.
    FWIW, a 2014 Lexus I had offered the ability to change this at the dealer, and I did. I have not looked into whether the Volt can have this changed by the dealer. Please let me know if you find out.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #14
    Join Date
    Jun 2016
    Location
    Rochester NY
    Posts
    599
    Default
    You can turn it off. If you click it then return it to center it stops blinking. I never knew anyone didn't like this super convenient option. I wish it blinked 4 times though. My 2016 promaster 3500 blinks 5 times.
  7. #15
    Join Date
    Aug 2016
    Location
    Bakersfield
    Posts
    464
    Default
    I found that rather than a quick tap which activates it the 3 blink function, if you hold it in position, it only blinks as long as you hold it as long as at least one blink has been made and stops when released. It's at least some control without locking it into position. The only thing I find slightly annoying is when I'm getting on or off a freeway and I wrongly "disengage" my blinker (usually its in a locked position when merging) because I only tapped it, then it indicates the opposite direction I was intending for a couple blinks. Aside from that I try to remember to lock it into whatever position I need to indicate and cancel manually as one normally would have done with a "dumb" car.
  8. #16
    Join Date
    Jan 2015
    Location
    Missouri
    Posts
    1,433
    Default
    the feature has been around for many years on various cars and trucks.
    2013 Volt Silver Topaz Metallic [Blue]
    2013 Volt Cyber Gray Metallic [Gray]
    Hidden Content
    Hidden Content
    Hidden Content
    Hidden Content
    2013 No Cabin Heat? Perform a forum search on: PIC5796 PIC5943 PIC5855
    2013 Losing Miles? Perform a forum search for the following: PIC6138
    Hidden Content
    Issues contact a Volt Advisor 877-486-5846
  9. #17
    Join Date
    Jun 2016
    Location
    Nebraska
    Posts
    238
    Default
    You can turn it off by pushing the control stalk all the way up/down until it clicks into place...
    Honestly I don't think their's a way to disable it. I really don't see the need for that ability either.
  10. #18
    Join Date
    Sep 2015
    Location
    North Carolina
    Posts
    1,698
    Default
    I find that an odd complaint. It's kind of like saying I don't like that the radio gets the NPR station. She should just not activate the feature.
  11. #19
    Join Date
    Sep 2016
    Location
    Chicago (W Suburbs)
    Posts
    514
    Default
    The only way I can see that you could accidentally activate this is if you're trying to flash the blinker once and don't hold it long enough. If that's the case she should consider letting it blink more times for changing lanes because only blinking it once doesn't really count and won't be noticed...
    If you decide to cancel changing lanes and it keeps blinking, tapping it again in the same direction stops it.
    2016 Kinetic Blue LT
    Unscheduled service visits: 4 Hidden Content
    Longest service visit: 2.5 weeks
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. ELR Grille touch up
    By ELRDave in forum Cadillac ELR General Discussion, News and Events
    Last Post: 05-02-2017, 07:34 PM
  2. Touch up Paint
    By tim-in-ca in forum Generation 2 Volt (2016-2020)
    Last Post: 06-27-2016, 01:15 PM
  3. Help--Need Touch Up Paint
    By vidhead in forum Generation 1 Volt (2011-2015)
    Last Post: 08-27-2014, 09:55 PM
  4. Canbus amber LEDs for front blinkers
    By jcaponeg in forum Generation 1 Volt (2011-2015)
    Last Post: 07-18-2012, 05:01 PM
  5. Touch Interface
    By OldSchool in forum Chevy Volt Engineering and Design
    Last Post: 08-10-2008, 12:31 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
