MyChevy App sucks
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: MyChevy App sucks
  1. #1
    Join Date
    Mar 2017
    Location
    Ottawa
    Posts
    33
    Default MyChevy App sucks
    It is possibly the most useless thing I have used to date. Car is awesome, but the app is abysmal.
    Anything else out there that I can use?
  2. #2
    Join Date
    Jul 2013
    Location
    North East USA
    Posts
    998
    Default
    What is abysmal about it? The Look and Feel (Form), or how it operates (Function)?
    If this is about how it operates, there are multiple factors that can affect your experience
    -> Your mobile signal to internet
    -> Your cars signal to ATT network
    -> OnStar server load
    -> OnStar internet connection
    -> ATT network status
    You see, the app operates in what is commonly called asynchronous mode. This means that when you log into the app and press a button to, say, remote start the car, the app has to first authenticate with OnStar.
    If that succeeds, because it is a Start action, OnStar then asks for a PIN. If both are correct, then OnStar adds your Start request to a queue, which is processed by one of several OnStar servers. How soon your request is processed can depend on a variety of factors (like how many people are using the app at the time, etc).
    When your request is processed from the queue, OnStar attempts to communicate with your vehicle over ATT network. This can take some time. Once communication is established, your vehicle authenticates and makes sure that it is indeed OnStar making the request. Once that determination is made, your car receives the Start request. It takes a few seconds to process that, and once it has determined that a Start happened successfully, it sends a confirmation message to OnStar. This is stored in another message queue on OnStar side. OnStar server reads that message and lets your app know that restart is complete.
    As you can see, it is quite a series of steps .. and all of them have to happen without a hitch for the app to work as intended, and even then, it is slow (because it is asynchronous communication). OnStar uses 4G technology for newer vehicles (like Gen 2 Volt). For older Volts, it actually uses a crude form of text messaging to communicate with the vehicle. I am actually surprised that the app works as well as it does, given all the complexities.
    Having said that, if you are having consistent failures with your app, maybe there is something that OnStar needs to fix on their end. Mis-configurations are not un-common. Or it could be bad hardware, or an issue on the phone, or an issue with ATT signals where you park, or something else.
  3. #3
    Join Date
    Oct 2010
    Location
    Nashville, TN
    Posts
    2,152
    Default
    Quote Originally Posted by tlevy View Post
    You can try the Onstar RemoteLink app. But, it is no longer supported. Both apps work quite well for me except the reported lifetime MPG is currently incorrect.
    2017 Premium Siren Red - H 0157 - Hidden Content Born 2/01/16 - Delivered 2/27/2016 Hidden Content
    2013 Crystal Red - D 2516 - Delivered 10/16/2012 .... Returned to Ally 11/07/2015
    U235 Powered
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Nov 2010
    Location
    Baltimore
    Posts
    990
    Default
    I have to heartily disagree. The remote start feature alone makes it worthwhile. The vehicle location function is great. The remote locking and unlocking provides peace of mind. Charging status, tire pressure, code reading, checking for recall notices.
    Frankly, I see little support for your assertion.
  7. #5
    Join Date
    Mar 2017
    Location
    Ottawa
    Posts
    33
    Default
    It may perhaps be that I am pretty new to all this..admittedly, I probably jumped the gun on my assessment of the app...
  8. #6
    Join Date
    Feb 2016
    Location
    Arizona
    Posts
    318
    Default
    I think the app works quite well. My problem is with the car. We have no AT&T signal where we live, so the app doesn't work unless we are an hour away from home.
    2011 Chevrolet Silverado 3500HD LTZ Dually
    2015 Subaru Outback 2.5i
    2017 Chevrolet Volt Premier
  9. #7
    Join Date
    Jul 2013
    Location
    North East USA
    Posts
    998
    Default
    Quote Originally Posted by SSonnentag View Post
    Not sure if you use AT&T yourself .. you may be able to get a MicroCell from ATT
    https://www.att.com/att/microcell/
  10. #8
    Join Date
    Nov 2015
    Location
    USA
    Posts
    2,180
    Default
    Works fine on my Galaxy S7, rarely has an issue.
    Joe
    Hidden Content
    Gen 1 Wind Buffeting fix - Hidden Content
    Rotor/Stator bearing replacement - Hidden Content
    GM Warranty Hidden Content
    GM Owners Manuals Hidden Content
  11. #9
    Join Date
    Mar 2017
    Location
    Durham, NC
    Posts
    3
    Default
    You only say this because you have not seen the Nissan app so don't know what "useless" really means!
    On a serious note...both apps leave a lot to be desired. Clearly GM and Nissan's strong suits are building cars, not building apps. And that's probably not a bad thing.
    At least with Nissan there are some third party apps that while still stuck with the crappy/slow API provided with Nissan actually make the user experience tolerable. Things like auto-updating each hour while charging is detected, and single button press widget to remote start HVAC. I don't know if there are any suitable replacements for the Volt (if there are, please let me know).
  12. Advertisement
  13. #10
    Join Date
    Jul 2013
    Location
    KC, MO.
    Posts
    2,643
    Default
    It is possibly the most useless thing ..., the app is abysmal.
    As a BEV driver it is important to me to be in contact with the car. It does everything I could ask for !! Consistently. Good cell coverage for the car in my area?
    What do you expect this app to do for you?
    '14 Spark EV w/DCFC
    In the middle of the country,
    far from any of its sibs,
    feeding off free electrons, mostly.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. OnStar remote built into new MyChevy app
    By danieljw in forum Generation 1 Volt (2011-2015)
    Last Post: 05-11-2016, 01:37 PM
  2. It's official VoltDC sucks
    By BAZINGA in forum Chevy Volt General Discussion, News, and Events
    Last Post: 07-04-2013, 07:01 PM
  3. Oil Sucks...and it stinks...and it sinks
    By flmark in forum Politics, Finance, and Environment
    Last Post: 04-13-2013, 10:42 PM
  4. Well that just sucks.
    By solar_dave in forum Totally Off-Topic
    Last Post: 11-03-2012, 02:26 PM
  5. Battery Expert : Leaf sucks, BYD sucks, Volt is better but too $$$
    By HyperMiler in forum Hybrid and Electric Vehicle Competitors
    Last Post: 05-17-2010, 08:28 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
