HCS 40-P 240V EVSE
Grab our Forum Feed
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: HCS 40-P 240V EVSE
  1. #11
    Join Date
    Dec 2013
    Location
    Norco/Corona, CA
    Posts
    2,493
    Default
    If your heart is set on using the existing 30a wiring and breaker, set it up as a 14-30 outlet (or L14-30 round). Put a plug or adapter on the EVSE to match. That way nothing higher than 30a can be plugged into it.
    Although I'd just redo it now to 14-50R to give the most safety and possibilities. Remove the old 30a breaker, replace with 50a breaker, use 6 gauge wires. Total parts are usually under $100. They make all sorts of adapters for 14-50 outlets since they are used for RVs.
    Ménage à trois - 2017, 2016 and 2013 Volts.
    Tesla Model 3 Reserved
  2. #12
    Join Date
    Jun 2014
    Location
    Austin
    Posts
    418
    Default
    The Volt is limited to 15amps*240v=3.6kw and charges at ~12mph. The LCS-30 provides 24amps*240v=5.76kw, and would charge a Bolt at ~20miles per hour. This is probably more than adequate.
    Hidden Content 2017 Volt Premier Pepperdust metallic Jet Black/Brandy w/pkg I & II, AAC; Clipper Creek LCS-20
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. ClipperCreek HCS-40, JuiceNet® Edition
    By Quark in forum Generation 2 Volt (2016-2020)
    Last Post: 12-16-2016, 09:44 AM
  2. Clipper Creek HCS-40 Installed
    By viking79 in forum Electric Vehicle Batteries & Plug-In Charging
    Last Post: 02-23-2015, 03:16 PM
  3. Clipper Creek HCS-40 for sale
    By kincade in forum Li-Ion Battery, Charging, & Battery Managment System - Chevy Volt
    Last Post: 02-01-2015, 11:56 PM
  4. Clipper Creek LCS-25 vs HCS-40
    By axelvolt in forum Generation 1 Volt (2011-2015)
    Last Post: 01-25-2015, 09:34 AM
  5. New Clipper Creek HCS 40 Level 2 / 7.2 KW
    By alfon in forum Li-Ion Battery, Charging, & Battery Managment System - Chevy Volt
    Last Post: 01-13-2014, 04:53 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
