Adding a second OEM charger for 6.6kW charging - CANBUS hacking
Grab our Forum Feed
+ Reply to Thread
Page 3 of 3 FirstFirst 1 3
Results 21 to 25 of 25
Thread: Adding a second OEM charger for 6.6kW charging - CANBUS hacking
  1. #21
    Join Date
    Jul 2011
    Location
    San Antonio, Texas
    Posts
    1,751
    Default
    Quote Originally Posted by Fourdoor View Post
    Good luck finding a tuner who knows Volt code that hasn't left this forum in disgust due to the bad attitude of the many "enlightened" volt owners here.
    Keith
    Please point me to the thread on this board of anyone who claims to have changed any code except table values in a Voltec system.
    I don't say it can't be done - any code created in 2010 can be hacked in 2017 - I just say that no one has done it.
    As for externally charging or discharging the HV battery without the battery management system detecting it, you obviously don't believe in redundancy. There would be fault codes in seconds.
  2. #22
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    15,219
    Default
    Quote Originally Posted by mikeg3 View Post
    To the modders that just sounds negative.
    So my response is: "Great! Go for it. Please post pictures and the step-by-steps for adding the 6.6kW charging to your Volt." There are many who would be interested in doing the same. When does this Volt 6.6 project start?
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 84,576 miles, 135 MPG, Remaining Oil Life 74%
    Typical Commute: 60 miles
    30 day Stats: 1366 miles, 125
    MPG, 65% Electric, 33% gas, Saved 48 gal., 27 kW-hr/100 miles
  3. #23
    Join Date
    Feb 2015
    Location
    Ephraim, UT
    Posts
    13
    Default
    Quote Originally Posted by GeV View Post
    @nedfunnell:
    It seems pretty obvious (to me at any rate) that you've given this much more thought, and have better comprehension of your intents and proposed implementation, than most if not all of the other contributors to this point in the thread.
    Unless user WopOnTour joins the discussion, I think you may well be the most knowledgeable person on this subject who's posting here.
    So while this is a good place to ask your question, I don't expect you to get very high-quality responses that go beyond what you've already gleaned on your own (unless and until WOT joins the discussion).
    Personally, although this mod definitely isn't for me, I am curious to hear more about your efforts. The Volt has been available for almost 7 years now, it's about time we get some competent tinkerers who are willing and able to push the car beyond it's design limitations.
    I think you're right. I doubt I'll make much progress on it by myself, so I'll keep looking for other places to connect with people who can chip away on the project.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #24
    Join Date
    Aug 2013
    Location
    Houston, TX
    Posts
    333
    Default
    (yet another engineer here)
    This thread brings to mind the phrase:
    "What could possibly go wrong?"
  7. #25
    Join Date
    Apr 2015
    Location
    Belarus-Minsk
    Posts
    38
    Default
    Very interesting topic.
    Sorry GM does not allow to increase charging 6.6 kW
    My friend has a second battery, and he charges two batteries through one connector
    https://www.drive2.ru/l/456998265263541164/
    My Volt can travel 130-140 km (80-85 mils) !!!
    Hidden Content !!!
    My Volt
    Hidden Content
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. 6.6KW/h charger might be possible after all
    By Kunundrum in forum Generation 2 Volt (2016-2020)
    Last Post: 04-20-2016, 04:47 PM
  2. Adding OEM Seat Heaters???
    By hyperlexis in forum Chevy Volt Accessories and Modifications
    Last Post: 03-15-2016, 10:10 PM
  3. Help, Charging Issue With OEM Charger, 2011 VOLT
    By 2BeLivingGreen in forum Generation 1 Volt (2011-2015)
    Last Post: 11-23-2014, 01:06 PM
  4. 2014 Volt 3.6KW Charger and 16 KWH charging time details
    By plugin_max in forum Li-Ion Battery, Charging, & Battery Managment System - Chevy Volt
    Last Post: 07-22-2014, 06:10 PM
  5. Lack of 6.6kw charger b/c of cost, battery stress or something else?
    By realdb2 in forum Electric Vehicle Batteries & Plug-In Charging
    Last Post: 03-11-2013, 02:29 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
