Adding a second OEM charger for 6.6kW charging - CANBUS hacking
Grab our Forum Feed
+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 25
Thread: Adding a second OEM charger for 6.6kW charging - CANBUS hacking
  1. #11
    Join Date
    Jan 2011
    Location
    Fresno, CA
    Posts
    1,718
    Default
    Also, Volt components have specific ID codes that are checked each time the car is turned on. If you even attempt to substitute a different charger in place of the original one, the car will not charge or operate until the main ECU is re programmed at a dealer to recognize the new component.
    So you are are going to have a lot of serious obstacles to your project. (not saying it can't be done, just that you will have major headaches trying to get it to work without cooperation from GM)
    Jerry, Fresno, California
    2017 Bolt ordered, Orange Sunburst, w/all options,
    #536 2011 Crystal Red Volt,
    2012 Diamond White Volt, saved from the crusher, gift to my niece.
    1975 Cosworth Vega, stored
    1988 Formula Fiero, also saved from the crusher, in the midst of restoration.
  2. #12
    Join Date
    Feb 2015
    Location
    Ephraim, UT
    Posts
    13
    Default
    Quote Originally Posted by mikeg3 View Post
    You have to tell the Volt to use the second charger. That means understanding and changing the computer programs that monitor and control the Volt HV battery. No one outside of GM has ever demonstrated that capability. I hope that this answers your question.
    Incorrect. The Volt needs to know nothing about the second charger. All it cares about (WRT a second charger) is how many coulombs are entering the battery, and it can count the extra ones along with the others. All that matters within the Volt computer system is if it produces errors when it counts more than 3.3 kW entering the battery. It probably won't, just like computers didn't care about 00 being the year instead of 99. Why would it? The Leaf doesn't.
  3. #13
    Join Date
    Feb 2015
    Location
    Ephraim, UT
    Posts
    13
    Default
    Quote Originally Posted by Raymondjram View Post
    I don't have a Volt but, as an EE, I see that a second charger will not work because the onboard battery monitor communicates with the EVSE to determine the charging current. 3.3 kW is about 15 A for a Level 2 EVSE and that is set at the code level. A second charger, if setup to supply the same charge current of 15 A (for a possible total of 30 A), will be working against the first EVSE. The monitor circuit will detect the higher current and tell the EVSE to drop the current, so at the end, the two EVSE and chargers will reduce their outputs to be just 15 A together (or 7.5 A each).
    Someone has to break into the Volt battery monitor code to allow higher currents to charge the battery. And someone here mentioned that the regenerative braking does supply higher currents, but that is from the motor/generator. If there were a way to "spoof" the monitor to believe that the Volt is in regeneration, maybe the higher charge current can be possible.
    I once thought of a third path: a direct battery attachment, bypassing the internal monitor. But that is dangerous if the new external monitor cannot measure the exact current entering the battery and its thermal conitions. This is all dangerous due to the high amounts of energy involved. No layperson, or even an EE with little knowledge or training, can do any type of external modification to increase the Volt battery charging input over the coded 3.3 kW without getting some information or help from LG Chamical of any specialized GM engineer. The gain cannot compensate the risks involved.
    Also an engineer here.
    I don't think we need to worry about the BMS. You're positing that the BMS will tell the original charger to scale back because it will detect extra AC input current flowing, right? I think that can be managed simply. Since the J1772 inlet and wiring will need to be replaced anyway, any monitoring hardware that the BMS may or may not monitor simply remains on the AC lines feeding the original charger, and nothing is wrong. For the second charger, a separate microcontroller handles EVSE-facing J1772 communications and feeds translated inputs to the onboard J1772 logic. Not too hard. Upstream from this, the second charger taps the incoming AC power.
    On the topic of the BMS, I think the primary legitimate concern is if the BMS will produce and error when it sees more DC current coming in than usual. This may well be a problem, but I tend to think it won't. The BMS isn't sentient, and will only error out if GM programmed it to do so. And why would they? It'd be a waste of code. The charger likely has overcurrent protection, and that is sufficient for charging. The battery handles much higher currents regularly and there is no common AC charging overcurrent fault that GM engineers would create an error code for. Still possible, but I doubt it.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #14
    Join Date
    Feb 2015
    Location
    Ephraim, UT
    Posts
    13
    Default
    Quote Originally Posted by SharkVolt View Post
    You are right about that, and that's why a second CANBUS network is needed. The OEM chargers are only happy to work, according to mauswerkz, as the only charger on their particular CANBUS network. So we have a second CANBUS network via a microcontroller, with some custom work mentioned previously to translate J1772 inputs and decide when and how much to run the second charger.
  7. #15
    Join Date
    Nov 2015
    Location
    USA
    Posts
    2,181
    Default
    Quote Originally Posted by nedfunnell View Post
    OK, thanks for the threadjacking guys. I was hoping to discuss the addition of a second 3.3kW OEM charger to a Gen 1 Volt. Any comments on that?
    Agreed - don't you just love the internet
    It does sound interesting, however it's way above my paygrade. Hopefully this becomes a useful discussion.
    Joe
    Hidden Content
    Gen 1 Wind Buffeting fix - Hidden Content
    Rotor/Stator bearing replacement - Hidden Content
    GM Warranty Hidden Content
    GM Owners Manuals Hidden Content
  8. #16
    Join Date
    Oct 2013
    Location
    Fighting Illini country surrounded by bean fields
    Posts
    9,982
    Default
    I think doubling the current coming into the volt with two separate EVSEs will likely fry the batteries or at a minimum shorten the lifespan of the battery. But you'd have to hack into a bunch of code that nobody really has cracked AFAIK. A few years back someone found a higher capacity charger online and was wondering if they could upgrade the onboard charger with this higher capacity one. That became a dead end.
    To date, I think the only solution for charging faster is to trade the volt in for a different vehicle. I personally don't need faster charging as much as I would love a 100 mile battery with my range extender. More cargo space is also pretty high on my list as the volt is the smallest vehicles I've ever purchased for myself (I did have a Toyota Supra which was about the same size, yet 2 doors, but my Dad gave that to me).
    LLninja (greenback troll #1)
    2013 Volt G1 white diamond tricoat
    If I can get the guy in the mirror under control I can be skinny and rich.
    If you don't have the money, don't buy it. Debt is hazardous to your wealth
    Hidden Content Originally Posted by doctorq Hidden Content
    "what kind of mental problem do you have? you should really get yourself checked out, are you on any type of psychotropic medications?
    R:IQ $2.2M, at $1.7M proj $4.8M
  9. #17
    Join Date
    Dec 2015
    Location
    Indianapolis
    Posts
    47
    Default
    There are a group of people that have used the Lear charger that is installed in the Volt to charge the batteries in their DIY electric cars. They have uncovered a wealth of info on this product. Some of it may help you. Here is their forum: http://forums.evtv.me/?forum=395914
    You'll have to sign up to get access, but it's pretty painless.
    Good luck on your quest.
  10. #18
    Join Date
    Jul 2016
    Location
    In my Volt
    Posts
    15
    Default
    @nedfunnell:
    It seems pretty obvious (to me at any rate) that you've given this much more thought, and have better comprehension of your intents and proposed implementation, than most if not all of the other contributors to this point in the thread.
    Unless user WopOnTour joins the discussion, I think you may well be the most knowledgeable person on this subject who's posting here.
    So while this is a good place to ask your question, I don't expect you to get very high-quality responses that go beyond what you've already gleaned on your own (unless and until WOT joins the discussion).
    Personally, although this mod definitely isn't for me, I am curious to hear more about your efforts. The Volt has been available for almost 7 years now, it's about time we get some competent tinkerers who are willing and able to push the car beyond it's design limitations.
  11. #19
    Join Date
    Jul 2015
    Location
    Mississippi
    Posts
    948
    Default
    There have been several "tuners" on this board claiming that they can modify a Volt. Every one of them only talks about improving acceleration, particularly 0-60 time.
    No "tuner" has even claimed to use more of the battery's total capacity, improve the charging rate, or do anything else involving the battery. Either they have no idea why people buy Volts in the first place or they only know how to change some tables, not code, through the bus.
    I wonder if these guys offer Corvette tunes that just improve the mpg.
    Don't conflate why YOU purchased a Volt with why "people" buy Volts. This anti "tuner" attitude is infuriating.
    And yes, tuners DO offer Corvette tunes specifically to improve the mpg... why on earth wouldn't they do this? Oh, right... tuners are neanderthals that are hell bent on destroying the earth, I forgot!
    I purchased the Volt for 2 reasons. I love the quiet comfortable driving experience of an electric drivetrain, and because I hate waste of any kind. Driving a high powered aftermarket tuned turbocharged 300 HP Miata on the weekends is a blast, driving it as a daily driver commuter car is a waste...
    Now back on topic, I don't know of anyone working on the Volt to increase battery charge rate, but twright is probably on the right track pointing you towards people that have used the Volt charger in a custom configuration on different vehicles. Good luck finding a tuner who knows Volt code that hasn't left this forum in disgust due to the bad attitude of the many "enlightened" volt owners here.
    Keith
  12. Advertisement
  13. #20
    Join Date
    Feb 2008
    Location
    Whitby, ON
    Posts
    2,735
    Default
    I would think the simplest route would be to find a higher powered charger that fits in the space of the existing 3.3 unit (they probably exist by now as electronics get smaller over time) and build the aforementioned translation unit to make the car thing it is talking to the original lear unit (serial # 123467) and everything is A-OK
    From what I can gather of the 240V charging process, the car just says "Hey, charge time" to the lear unit, it does it's job and then sends a message back to the main computer "I'm done". I know this because it always defaults to 83.5% SOC when charge complete happens. This means it's a programmed response vs a measurement. It will update to a measured/calculated SOC at a later time.
    There is likely no monitoring of kW rate or anything of that sort.
    The computer is only involved in 120V charging as part of the 8A/12A limiting process.
    Hidden Content
    Year 1: 8101km | 97.5% EV | 6.0 L/100km CS-only
    35.1L burned | 1.5L EMM, 22.6L wasted (16.6 ERDTT, 6 dealer)
    Year 2: 9277 km | 92.5% EV | 5.0 L/100km CS-only
    29.6L burned | 0.5L EMM
    Combined EV%: 95%
    -Triple-honk when exiting the vehicle (purposefully left on) - possible workaround Hidden Content
    Extremely cold and can only use engine?
    Hidden Content
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. 6.6KW/h charger might be possible after all
    By Kunundrum in forum Generation 2 Volt (2016-2020)
    Last Post: 04-20-2016, 04:47 PM
  2. Adding OEM Seat Heaters???
    By hyperlexis in forum Chevy Volt Accessories and Modifications
    Last Post: 03-15-2016, 10:10 PM
  3. Help, Charging Issue With OEM Charger, 2011 VOLT
    By 2BeLivingGreen in forum Generation 1 Volt (2011-2015)
    Last Post: 11-23-2014, 01:06 PM
  4. 2014 Volt 3.6KW Charger and 16 KWH charging time details
    By plugin_max in forum Li-Ion Battery, Charging, & Battery Managment System - Chevy Volt
    Last Post: 07-22-2014, 06:10 PM
  5. Lack of 6.6kw charger b/c of cost, battery stress or something else?
    By realdb2 in forum Electric Vehicle Batteries & Plug-In Charging
    Last Post: 03-11-2013, 02:29 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
