Adding a second OEM charger for 6.6kW charging - CANBUS hacking
Grab our Forum Feed
+ Reply to Thread
Page 1 of 3 1 3 LastLast
Results 1 to 10 of 25
Thread: Adding a second OEM charger for 6.6kW charging - CANBUS hacking
  1. #1
    Join Date
    Feb 2015
    Location
    Ephraim, UT
    Posts
    13
    Default Adding a second OEM charger for 6.6kW charging - CANBUS hacking
    Howdy,
    I am interested in adding a second OEM charger to a first-generation Volt to double the charging power from 3.3kW to 6.6kW. This is theoretically possible, according to work by EV developer mauswerkz, by creating a separate CANBUS network for the second charger. The CANBUS module would need to send info to the second charger based on what the car is telling the first charger to do.
    Of course, there would be HVDC and AC wiring work to do: possible replacement of the J1772 inlet and AC wiring with higher-current-capacity hardware, and duplicate or replacement wiring for the HVDC charger output. Also, it'd be necessary to sniff the J1772 communication to see if there is adequate current from the EVSE to drive the second charger at full or partial power, or at all.
    I could see this being pretty useful for me and others that want to minimize gas use during trips that go beyond EV range. I tend to stay close to my rural home most of the time, but regularly take longer errand-running trips that would benefit from higher-power opportunity charging. It's not necessary or beneficial for most, but it would be a nice option for some.
    Does anyone know of any existing work on adding a second charger, OEM or otherwise?
    Here are some more links from mauswerkz' project, which uses a number of Volt parts:
    https://hackaday.io/project/4649/logs/sort/newest
    http://www.diyelectriccar.com/forums...er-133857.html
    http://forums.evtv.me/?forum=403618
    http://gm-volt.com/forum/archive/index.php/t-12958.html
    https://hackaday.io/project/4649/log...he-small-stuff
    https://hackaday.io/project/4649/log...-front-battery
    https://hackaday.io/project/4649/log...ing-components
  2. #2
    Join Date
    Jul 2011
    Location
    San Antonio, Texas
    Posts
    1,755
    Default
    There have been several "tuners" on this board claiming that they can modify a Volt. Every one of them only talks about improving acceleration, particularly 0-60 time.
    No "tuner" has even claimed to use more of the battery's total capacity, improve the charging rate, or do anything else involving the battery. Either they have no idea why people buy Volts in the first place or they only know how to change some tables, not code, through the bus.
    I wonder if these guys offer Corvette tunes that just improve the mpg.
  3. #3
    Join Date
    Aug 2008
    Posts
    2,560
    Default
    Repurposing salvaged parts isn't quite the same as modifying the OEM system.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Jan 2015
    Location
    North Dakota
    Posts
    818
    Default
    Although this doesn't answer the OP's question, I disagree with Mike's comment.
    • A lot of "tuners" in this forum have modified their vehicles.
    • The most common modification is to make the accelerator pedal more sport like by default.
    • A few of us altered the ICE for better mileage.
    • One improved his 0-60 time, but required the ICE to be running and got a CEL during the process.
    Regarding using a Corvette tune, that's not going to work. Our Volts are heavy and the ICE doesn't really idle since it's always maintaining the HV battery so a better tune would come from a high compression flex fuel V8 pickup.
  7. #5
    Join Date
    Mar 2010
    Location
    Central NY
    Posts
    4,358
    Default
    Quote Originally Posted by colchiro View Post
    Are you personally aware of the engine MPG mods for better mileage? I'd love to hear more about how well that may have worked.
    Hidden Content - Provide backup power to essential appliances.
    Hidden Content - Keep yourself from getting unplugged!
    Join thE REVolution
    2011 Volt #186, VIN: B-00186, Cyber Gray Metallic - TRADED! 28k miles, 9k engine, 120MPG
    2013 Volt #43404, Blue Topaz Metallic
    Driving for FREE with Solar PV!
  8. #6
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    15,288
    Default
    Define "a lot". 3? 6? 24? 10,000?
    None of the "modified" examples involve what the OP is asking about. All involve the ICE. 2 out of 3 seem suspiciously similar to what MikeG said: acceleration. The third kicks on the ICE.
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 85,558 miles, 125 MPG, Remaining Oil Life 38%
    Typical Commute: 60 miles
    30 day Stats: 966 miles, 108
    MPG, 62% Electric, 38% gas, Saved 33 gal., 31 kW-hr/100 miles
  9. #7
    Join Date
    Jul 2011
    Location
    San Antonio, Texas
    Posts
    1,755
    Default
    You're basically agreeing with me.
    None of the tunes affect the battery in any way.
    While the tuners have not disclosed their methods, other posters have strongly suggested that the tunes only involve table changes. I assume that GM has a standard format for these tables, so finding the right cells sounds doable. Decompiling the actual code has not been demonstrated.
    My Corvette comment was meant as sarcasm - you don't buy a Corvette for superior mpg and you don't buy a Volt for red hot acceleration.
  10. #8
    Join Date
    Feb 2015
    Location
    Ephraim, UT
    Posts
    13
    Default
    OK, thanks for the threadjacking guys. I was hoping to discuss the addition of a second 3.3kW OEM charger to a Gen 1 Volt. Any comments on that?
  11. #9
    Join Date
    Jul 2011
    Location
    San Antonio, Texas
    Posts
    1,755
    Default
    Quote Originally Posted by nedfunnell View Post
    You have to tell the Volt to use the second charger. That means understanding and changing the computer programs that monitor and control the Volt HV battery. No one outside of GM has ever demonstrated that capability. I hope that this answers your question.
  12. Advertisement
  13. #10
    Join Date
    Jul 2010
    Location
    Bayamon, Puerto Rico
    Posts
    4,300
    Default
    I don't have a Volt but, as an EE, I see that a second charger will not work because the onboard battery monitor communicates with the EVSE to determine the charging current. 3.3 kW is about 15 A for a Level 2 EVSE and that is set at the code level. A second charger, if setup to supply the same charge current of 15 A (for a possible total of 30 A), will be working against the first EVSE. The monitor circuit will detect the higher current and tell the EVSE to drop the current, so at the end, the two EVSE and chargers will reduce their outputs to be just 15 A together (or 7.5 A each).
    Someone has to break into the Volt battery monitor code to allow higher currents to charge the battery. And someone here mentioned that the regenerative braking does supply higher currents, but that is from the motor/generator. If there were a way to "spoof" the monitor to believe that the Volt is in regeneration, maybe the higher charge current can be possible.
    I once thought of a third path: a direct battery attachment, bypassing the internal monitor. But that is dangerous if the new external monitor cannot measure the exact current entering the battery and its thermal conitions. This is all dangerous due to the high amounts of energy involved. No layperson, or even an EE with little knowledge or training, can do any type of external modification to increase the Volt battery charging input over the coded 3.3 kW without getting some information or help from LG Chamical of any specialized GM engineer. The gain cannot compensate the risks involved.
    No Volt or Bolt EV yet!
    2009 Chevrolet Equinox 2LT
    Level 2 JuiceBox EVSE installed at 7.2 kW
    Registered EVSE at PlugShare
    Waiting for the first EV to charge!
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. 6.6KW/h charger might be possible after all
    By Kunundrum in forum Generation 2 Volt (2016-2020)
    Last Post: 04-20-2016, 04:47 PM
  2. Adding OEM Seat Heaters???
    By hyperlexis in forum Chevy Volt Accessories and Modifications
    Last Post: 03-15-2016, 10:10 PM
  3. Help, Charging Issue With OEM Charger, 2011 VOLT
    By 2BeLivingGreen in forum Generation 1 Volt (2011-2015)
    Last Post: 11-23-2014, 01:06 PM
  4. 2014 Volt 3.6KW Charger and 16 KWH charging time details
    By plugin_max in forum Li-Ion Battery, Charging, & Battery Managment System - Chevy Volt
    Last Post: 07-22-2014, 06:10 PM
  5. Lack of 6.6kw charger b/c of cost, battery stress or something else?
    By realdb2 in forum Electric Vehicle Batteries & Plug-In Charging
    Last Post: 03-11-2013, 02:29 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
