Bulletin PIP5201 Cold Start Misfires MIL P0300 P030x
Grab our Forum Feed
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Bulletin PIP5201 Cold Start Misfires MIL P0300 P030x
  1. #11
    Join Date
    Jun 2016
    Location
    Indiana
    Posts
    9
    Default
    Took it to the dealer since I was still under the 5yr/100k mile powertain warranty. Dealer said there's a memo out that this code with these symptoms on 2012 Volts means the cylinder head needs replaced, so they're doing so. Part should be in tomorrow. I wonder if they fixed whatever caused this to happen in the first place. If not, might be selling this. No way I want to have to pay for this again out of pocket! Probably not a cheap or easy fix.
  2. #12
    Join Date
    May 2016
    Location
    Reedsburg, WI
    Posts
    174
    Default
    Ask for the service bulletin number. Head replacement is very extreme for a cylinder misfire.
    Dennis
    2013 VOLT (Premier) Diamond White w/ Polished wheels (Loaded), Diode Dynamic HID 6K Headlights and PLUGLESS L2 charger (purchased before Price hike)
    2005 PRIUS (Base) Salsa Red 240K mi. and climbing
    1981 DELOREAN DMC-12 2nd owner 23 yrs and climbing
  3. #13
    Join Date
    Jun 2016
    Location
    Indiana
    Posts
    9
    Default
    The service bulletin is PIP5201A. Got it back. $2,300 repair - done just under warranty! Dodged that bullet!!!
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #14
    Join Date
    May 2016
    Location
    Reedsburg, WI
    Posts
    174
    Default
    I'd like to know what makes this a 2012 Volt specific issue? Did the they change the head design for 2013 model years. I found the service letter but could not access the full document without paying a $5 one time fee for that info. The title was " Cold start misfires MIL P0300". (Jan-25-2017)
    Dennis
  7. #15
    Join Date
    Jun 2016
    Location
    Indiana
    Posts
    9
    Default
    Quote Originally Posted by DMC5180 View Post
    I'll buy it and post it so we can all see what it has to say.
  8. #16
    Join Date
    Sep 2008
    Location
    my little grass shack
    Posts
    4,621
    Default
    Quote Originally Posted by jvidamins View Post
    Nothing in the head was redesigned as far as I am aware (and nothing stated to that within the bulletin)
    In fact, the preliminary bulletin is comprehensive in it's directions to inspect NUMEROUS potential causes for a "cold start misfire" including ignition and fuel system checks.
    Instructions to perform "top end" cleaning is an item mentioned specifically deeper into the document, and if unable to alleviate the misfire after doing so (and all previously listed diagnostic checks) the head it to be replaced and the customer advised to use ONLY TOP TIER FUELS (specifically formulated to help keep injectors and top-ends free of carbon deposits)
    Again, no head redesign or anything and AFAIK it's the same part number. But I too am curious as to what makes this specific to the 2012 models (but will try to find out)
    WOT
    Welcome Hidden Content as our latest forum vendor!
    Follow the Chevy Volt and other GM electrified cars on Twitter! Hidden Content
  9. #17
    Join Date
    May 2016
    Location
    Reedsburg, WI
    Posts
    174
    Default Bulletin PIP5201 Cold Start Misfires MIL P0300 P030x
    This is a good tutorial on what I think was going on with OP problem and ties into what WOT was explaining.
    http://www.aa1car.com/library/intake...di_engines.htm
    The very first sentence in the last paragraph of the article is what I think happened here. Prompted by the fact it was still under "Warranty"
    Dennis
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Check engine light on. Engine will not start. Vehicle running on low power
    By ewd1949 in forum Problems/Issues, Driver Warnings or DTCs - Chevy Volt
    Last Post: 07-23-2016, 12:38 PM
  2. Electric drive malfunction & check engine light: I drove home on the 'backup engine'
    By RobbertPatrison in forum Problems/Issues, Driver Warnings or DTCs - Chevy Volt
    Last Post: 02-17-2016, 08:12 PM
  3. Replies: 39
    Last Post: 01-06-2016, 05:02 PM
  4. check engine light
    By dvinci9 in forum Chevy Volt Accessories and Modifications
    Last Post: 06-17-2015, 02:23 PM
  5. Check engine light was serviced (POD22) Now the car is using gas engine a lot more
    By gobluemitchigan in forum Problems/Issues, Driver Warnings or DTCs - Chevy Volt
    Last Post: 11-28-2014, 02:18 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
