8 Michelin OEM tires, 2016/2017
Grab our Forum Feed
+ Reply to Thread
Results 1 to 2 of 2
Thread: 8 Michelin OEM tires, 2016/2017
  1. #1
    Join Date
    Dec 2013
    Location
    Norco/Corona, CA
    Posts
    2,601
    Default 8 Michelin OEM tires, 2016/2017
    $100 per 4 tire set, 2 front, 2 rear. Removed tires to install high performance self-sealing tires.
    215/50-17 factory tires. 4 like new (rears), 4 have 90% depth but some briefautoX wear, so need to be rotated to the rear. Using the rears as fronts, then the fronts to rear, you will end up with a balanced set of tires that will last about the same as OEM.
    They fit 2011-2017's.
    Location Norco, California (SoCal). Will not ship. email qi@qinsp.com
    Ménage à trois - 2017, 2016 and 2013 Volts.
    Tesla Model 3 Reserved
  2. #2
    Join Date
    Dec 2015
    Location
    Vancouver, WA
    Posts
    43
    Default
    Are these from a Gen 1 or 2 Volt? Sent you an email...
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. G2 Tires (Michelin Energy Savers) on G1?
    By Hank101 in forum Wheels & Tires - Chevy Volt
    Last Post: 07-12-2016, 01:36 PM
  2. Replies: 13
    Last Post: 12-28-2015, 11:25 AM
  3. Michelin tires
    By bizmodel in forum Chevy Volt General Discussion, News, and Events
    Last Post: 12-16-2015, 04:31 PM
  4. Replies: 9
    Last Post: 07-04-2015, 04:57 PM
  5. Michelin Energy Saver AS tires
    By alfon in forum Wheels & Tires - Chevy Volt
    Last Post: 06-28-2014, 02:02 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
