roof help
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
Thread: roof help
  1. #1
    Join Date
    Dec 2016
    Location
    Upstate NY
    Posts
    19
    Lightbulb roof help
    can someone point me in the right direction as far as removing the rubber strips as well as the antenna (from the base)? i am looking in wrapping the entire car myself in clear bra wrap and besides the bumpers which i can handle i figured i would ask you fine folks before i did something stupid by trying to just pry them off. anyone have experience? any help would be appreciated
  2. #2
    Join Date
    Nov 2015
    Location
    USA
    Posts
    2,180
    Default
    Quote Originally Posted by alextheromanian View Post
    Beware, using a clear wrap it will discolor over time and would need to be removed and or re-applied. Those are intended for common 'chip' areas.
    Joe
    Hidden Content
    Gen 1 Wind Buffeting fix - Hidden Content
    Rotor/Stator bearing replacement - Hidden Content
    GM Warranty Hidden Content
    GM Owners Manuals Hidden Content
  3. #3
    Join Date
    Oct 2013
    Location
    Fighting Illini country surrounded by bean fields
    Posts
    9,481
    Default
    Have you thought about using plastidip rubber dip spray?
    https://www.dipyourcar.com/pages/videos-tutorials
    With plastidip, you can just peel and it should cut at any hard edge. Rubber edges like near the windows will need to be taped and peeled while wet. Those rubber strips on the roof should pry right out with a plastic putty knife. The antenna can even be dipped as it shouldn't affect transmission/reception.
    LLninja (greenback troll #1)
    2013 Volt G1 white diamond tricoat
    If I can get the guy in the mirror under control I can be skinny and rich.
    If you don't have the money, don't buy it. Debt is hazardous to your wealth
    Hidden Content Originally Posted by doctorq Hidden Content
    "what kind of mental problem do you have? you should really get yourself checked out, are you on any type of psychotropic medications?
    R:IQ $2.2M, at $1.7M proj $4.8M
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Nov 2015
    Location
    USA
    Posts
    2,180
    Default
    Quote Originally Posted by llninja View Post
    Who would plastidip an entire vehicle?
    Joe
    Hidden Content
  7. #5
    Join Date
    Oct 2015
    Location
    Milwaukee, WI
    Posts
    1,659
    Default
    Quote Originally Posted by Joe67 View Post
    I'm SURE it's been done.
    2012 Standard w/ Navigation
  8. #6
    Join Date
    Nov 2015
    Location
    USA
    Posts
    2,180
    Default
    Quote Originally Posted by hellsop View Post
    Many things have been done, but should they?
    Joe
    Hidden Content
  9. #7
    Join Date
    Oct 2013
    Location
    Posts
    9,481
    Default
    Certainly not with individual cans. But gallon cans and an Erlang dip sprayer makes this task easier. Plus with the new glossy top coat and dip pearls you can do some amazing stuff. Small flying debris bounces right off. No worries about road salt, but the new worry is accidentally dripping gasoline on the plastidip, as it degrades quickly if you overflow your tank.
  10. #8
    Join Date
    Mar 2016
    Location
    California
    Posts
    29
    Default
    Google "Dip your car"
  11. #9
    Join Date
    Dec 2016
    Location
    Upstate NY
    Posts
    19
    Default
    guys i need help to remove the rubber rails. yes i have heard of plastidip and im planning on doing the entire car with it but want the roof shiny black as well as the trunk and mirrors to match the door inserts. i chose to go the wrap route and im sticking with it because im looking for the gloss finish.
    this can be done with a thing called AUTOFLEX or HALO EFX. they are grown up plastidips that look like OEM paint. they can be sanded buffed waxed resist to gas spills and are easily peeled back off. (google each one) they are meant for ENTIRE car projects and not just patches as they are a lot more than regular dip and only sell in gallons. (this makes it incomvenient for me.)
    so this still leaves me with a need to know on how to pry off those rubber strips.
  12. Advertisement
  13. #10
    Join Date
    Dec 2016
    Location
    Upstate NY
    Posts
    19
    Default
    thanks for the heads up but i gotta correct you and let others know youre actually wrong on that info. clear wrap USED to turn yellow in its first generation. the glue would react to UV light and change chemical structure tinting it. the ones they sell today are guaranteed for life to stay 100% clear and see through...they even have a few that self heal. im not a sales rep but ive been doing my homework on them for the better part of 5 or so months in a quest to figure out what im protecting my newly bought volt with.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Where is the solar roof?
    By Lowa in forum Chevy Volt Accessories and Modifications
    Last Post: 02-22-2016, 01:30 PM
  2. Roof heat
    By jbfalaska in forum Chevy Volt General Discussion, News, and Events
    Last Post: 08-12-2013, 02:02 AM
  3. Insulation for the roof.
    Last Post: 01-01-2013, 11:06 PM
  4. Solar roof
    By iwillbegreen in forum Suggestions for GM - Chevy Volt
    Last Post: 12-06-2008, 10:53 AM
  5. Electrochromic roof
    By anvilis in forum Chevy Volt Engineering and Design
    Last Post: 05-07-2008, 02:23 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
