SERVICE COOLANT REPLACEMENT at 5yr or 150.000miles
Grab our Forum Feed
+ Reply to Thread
Results 1 to 2 of 2
Thread: SERVICE COOLANT REPLACEMENT at 5yr or 150.000miles
  1. #1
    Join Date
    Apr 2015
    Location
    savannah
    Posts
    138
    Default SERVICE COOLANT REPLACEMENT at 5yr or 150.000miles
    The gen 1 Volts are getting old,,,,must be quite a few that have replaced the Main Battery COOLANT at GM DEALER. HOW was your experience ?. What about the price of the change?. Any problems with the car that have the WOT default sensor?...Any problems after the coolant change ?.
  2. #2
    Join Date
    Jan 2013
    Location
    McKinney, Tx
    Posts
    485
    Default
    Good question, I'm a little over 4 years and 93000 miles into my Gen one. Will know soon enough.
    John Fields
    2013 Volt #Hidden Content
    FunFact: Discovered "Licensed to Ill" in my CD slot, driving away from the dealer.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Gurgling after Coolant heater control module replacement
    By burgandy25 in forum Generation 1 Volt (2011-2015)
    Last Post: 12-09-2016, 01:08 PM
  2. Punctured Coolant Hose - Service Bulletin # 16-NA-114
    By rio in forum Problems/Issues, Driver Warnings or DTCs - Gen2 Volt
    Last Post: 05-30-2016, 11:00 AM
  3. My first dealer service for low battery coolant level
    By IERP in forum Generation 1 Volt (2011-2015)
    Last Post: 02-08-2016, 05:48 PM
  4. Codes, Coolant Sensor, Great Service
    By langosta39 in forum Care, Maintenance & Service - Chevy Volt
    Last Post: 10-20-2013, 11:28 PM
  5. New service bulletin re: low coolant sensor
    By dgruber in forum Problems/Issues, Driver Warnings or DTCs - Chevy Volt
    Last Post: 09-17-2013, 10:12 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
