Door panel removal- instructions needed
Grab our Forum Feed
+ Reply to Thread
Results 1 to 4 of 4
Thread: Door panel removal- instructions needed
  1. #1
    Join Date
    Aug 2014
    Location
    pnw
    Posts
    42
    Default Door panel removal- instructions needed
    I'm in search of the instructions for removal of the inner door panels. I know where the clips are, as well as their part numbers (& the need to replace those that are single use) but I cannot locate the actual instructions.
    Thanks in advance
    Dan
  2. #2
    Join Date
    Dec 2012
    Location
    kettle falls, wa
    Posts
    505
    Default
    Not too hard actually, but a couple tricks to know: Best to obtain a plastic panel spoon for prying off the door panel. It'll avoid scratches on the door paint. I didn't ruin any clips removing both a front and rear panel. There is a little plastic cover behind the inside door handle. Look carefully and you'll see the upper rear corner has a slight gap. This is so you can get a pick in there and pull it off without leaving marks. There is a bolt behind it you have to remove. Next there are two bolts under the little rubber mat at the bottom of the armrest pull. Then snap the clips loose around the panel. The panel lifts up to unhook from the window area. Door pull is a cable you have to release to get panel off. Speaker wires and window switches unplug. You don't have to remove the window switches to remove the panel. Good luck!
    2013 White Diamond, "Hal" Black leather w/white accents, Bose
  3. #3
    Join Date
    Aug 2014
    Location
    pnw
    Posts
    42
    Default
    Thank you sir!
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5.
    Advertisement
  6. #4
    Join Date
    Feb 2012
    Location
    Transporter Tube
    Posts
    423
    Default
    __________________________________________________ ________
    2016 VW eGolf - electric Fahrvergnügen
    2016 BMW X5 40e - 1600 miles per fill up (on its way out of my garage)
    2014 Chevy Volt - 'Beano' (soon to be gone)
    2013 Porsche 911 Carrera Cabriolet (gone)
    2012 Chevy Volt - 'White Thundervolt' (gone)
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Rear fuse panel cover removal
    By JBumps in forum Generation 2 Volt (2016-2020)
    Last Post: 08-25-2016, 09:09 AM
  2. Need Front Bumper Removal Instructions
    By Triscb82 in forum Generation 1 Volt (2011-2015)
    Last Post: 07-23-2016, 01:10 AM
  3. subwoofer panel removal on LT?
    By aapocketz in forum Generation 2 Volt (2016-2020)
    Last Post: 02-25-2016, 10:15 PM
  4. Plastic Lower Side panel removal Help
    By Brittt1 in forum Chevy Volt Accessories and Modifications
    Last Post: 12-22-2011, 08:05 PM
  5. No clear instructions mailing list removal?
    By kieranmullen in forum General Motors and General Automotive Topics
    Last Post: 01-31-2009, 04:32 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
