What a Difference Temp Makes to EV range...
Results 11 to 13 of 13
Thread: What a Difference Temp Makes to EV range...
    Dec 2016
    Cos
    32
    Yes a Bolt probably is a better fit for daily use except it won't do my weekend trips. About 300 miles each Saturday. I do really like ev, but batteries need to be bigger.
    An ic engine energy goes roughly into thirds, 1/3 produces power, 1/3 waste heat radiator and 1/3 waste heat exhaust.
    Sep 2016
    Chicago (W Suburbs)
    412
    I get mid 40s EV range when it's below 45-50 *F, and mid-high 50s when it's 55-60. The efficiency curve is incredible...a few degrees Fahrenheit can affect your range by 5 miles or more.
    2016 Kinetic Blue LT
    Unscheduled service visits: 4 Hidden Content
    Longest service visit: 2.5 weeks
    Dec 2015
    USA
    139
    Not to start a debate but from everything I've read it's more like 3:1 even for a very efficient engine.
    That was once true, but it's a bit pessimistic in the era of direct injection, EGR, and miller cycle engines. If by "very efficient engine" you mean the current automotive record holder, the gen IV prius, than the actual ratio is 1.5:1.
  1. It no longer makes sense to charge mid-day.
    By gobble in forum Generation 1 Volt (2011-2015)
    Last Post: 11-08-2013, 01:35 PM
  2. Ahhh...What A Difference A Year Makes
    By JamesMcQuaid in forum Chevy Volt General Discussion, News, and Events
    Last Post: 12-03-2012, 08:52 PM
  3. Wow, what a difference the temperature makes!
    By mwfromva in forum Generation 1 Volt (2011-2015)
    Last Post: 09-15-2012, 02:03 AM
  4. What a difference a few degrees makes.....
    By Robinpdx in forum Generation 1 Volt (2011-2015)
    Last Post: 02-06-2012, 07:47 PM
  5. Level 2 Charger makes a BIG difference!
    By BillK in forum Generation 1 Volt (2011-2015)
    Last Post: 01-26-2012, 11:38 AM
