What a Difference Temp Makes to EV range...
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: What a Difference Temp Makes to EV range...
  1. #1
    Join Date
    Apr 2016
    Location
    Northeast USA
    Posts
    94
    Default What a Difference Temp Makes to EV range...
    Each day I do pretty much the same amount of driving in my '17 Volt. The past few days it has been fairly cold here in Delaware with temps in the 20s and low 30s. Yesterday it was 34 degrees, I started my 20 mile round-trip with 44 miles on the GOM, heat on 74/auto/eco and returned home with 24 EV miles remaining.
    Today it warmed up to 55(!) degrees. I did the same trip starting with 44 on the GOM again, this time no climate - fan only and when I returned home, I had 36 miles remaining e.g. a 20 mile drive only took 8 miles off the expected range.
    It's truly amazing how much the ambient temperature and climate affect the range.
  2. #2
    Default
    Yep, mine went from 53 miles in mid-seventies temperatures to 43 miles in mid-thirties temperatures.
  3. #3
    Join Date
    Mar 2012
    Location
    Southern Illinois
    Posts
    5,552
    Default
    Same here in southern IL. COLD weather sucks the life out of an EV's battery.
    Tom aka Accidental Electronaut
    USAF Retired
    My garage
    2016 Patriot Blue Equinox LTZ
    2017 Volt Premier Siren Red with Jet Black/Brandy
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Sep 2011
    Location
    Central Illinois
    Posts
    437
    Default
    I was getting mid 40's for range but I was able to get 57 yesterday when the temp jumped up near 50 degrees.
    2016 Kinetic Blue Volt (#28836)
    Premier Package
    Confidence I and II package
    Illuminated Charge Port
    Ambient Lighting
    35% 3M Color Stable all around. 70% 3M Crystalline on the windshield
    Gone but not forgotten:
    2012 Volt
    C4229
    2013 Leaf SV
    (QC Port, LED Headlights)
  7. #5
    Join Date
    Aug 2014
    Location
    New Hampshire
    Posts
    451
    Default
    Old fashioned ICE vehicles are also less efficient in the cold weather. Most likely you didn't have all the data Volt drivers get to tell you so.
    2014 White Diamond Volt
  8. #6
    Join Date
    Apr 2014
    Location
    Montreal
    Posts
    937
    Default
    Don't forget guys, the tires pressure is also less than optimal in cold weather !
    My Volt Hidden Content
    2014 White Diamond, S1, Bose, Nav, Premium Pkg
  9. #7
    Join Date
    Dec 2016
    Location
    Cos
    Posts
    32
    Default
    Finally broke 50 ev miles yesterday. Warmed up to the 50's. So it looks like I might be able to make my daily commute on all ev once it gets warmer.
    While I had a milage decrease with my tdi in cold weather it was 10% or less range difference in a full tank which was 570 miles in really cold weather to 630 in warm weather. I am going to miss being able to go 700 miles on a single tank while road tripping.
  10. #8
    Join Date
    Dec 2016
    Location
    Canada
    Posts
    138
    Default
    Quote Originally Posted by Slotracer577 View Post
    Yup but with the TDI you're getting your heat as waste from all that fuel.
    I'll bet it would be closer to 10% at 50F if you only counted traction energy.
    Put on your winter gear, do some test runs and let us know ;-)
    2017 Volt - Kinetic Blue
  11. #9
    Join Date
    Dec 2016
    Location
    Cos
    Posts
    32
    Default
    Quote Originally Posted by bluzer1 View Post
    The difference is I didn't have to do that. Yes ic engines are inherently inefficient and produce almost equal heat to useful energy, but in the winter it's free heat. So yes it has less lost range vs the volt in winter since I am not going to suffer to get a few more miles since it isn't going to go the whole trip on ev anyway.
    I am curious to see how much range I loose when it gets warm and I run the ac. In the tdi I ran heat or ac, almost never vent only.
    I like the volt but I feel it needed a 30kwh pack for my uses. I feel a bit short changed on the range, which is a combination of cold weather range degradation and I drive further than I thought each day. Turns out my shortest days are 50 miles and most are closer to 80, not even an issue in a tdi with a 600 mile range.
  12. Advertisement
  13. #10
    Join Date
    Dec 2016
    Location
    Canada
    Posts
    138
    Default
    Not to start a debate but from everything I've read it's more like 3:1 even for a very efficient engine.
    ... Turns out my shortest days are 50 miles and most are closer to 80, not even an issue in a tdi with a 600 mile range.
    It does sound like a Bolt would've been a better fit for your needs. No matter you should still be able to get better mileage in the Volt than the tdi and you can do your city/shopping drives in EV.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. It no longer makes sense to charge mid-day.
    By gobble in forum Generation 1 Volt (2011-2015)
    Last Post: 11-08-2013, 01:35 PM
  2. Ahhh...What A Difference A Year Makes
    By JamesMcQuaid in forum Chevy Volt General Discussion, News, and Events
    Last Post: 12-03-2012, 08:52 PM
  3. Wow, what a difference the temperature makes!
    By mwfromva in forum Generation 1 Volt (2011-2015)
    Last Post: 09-15-2012, 02:03 AM
  4. What a difference a few degrees makes.....
    By Robinpdx in forum Generation 1 Volt (2011-2015)
    Last Post: 02-06-2012, 07:47 PM
  5. Level 2 Charger makes a BIG difference!
    By BillK in forum Generation 1 Volt (2011-2015)
    Last Post: 01-26-2012, 11:38 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
