Reduced Range and usable only 9.9kWh usable after Recall 16055 applied
Results 11 to 16 of 16
Thread: Reduced Range and usable only 9.9kWh usable after Recall 16055 applied
    May 2015
    California
    86
    Mine is a June '16 made one. The big difference after the recall was applied was the smoothness of the regen paddle braking. There are lot of updates that are required but not discernible to the driver. We are not in a position to say it was a useless one! GM should be more clear with a customer facing document regarding what changed, even if it is has some techie stuff.
    Sent from AutoGuide.com Free App
    Aug 2015
    Rochester, NY
    455
    Quote Originally Posted by Veej View Post
    More smooth? Less smooth? Haven't tried it yet.
    2016 Kinetic Blue Premier, brandy/black leather, both safety packages.
    My Hidden Content
    VIN: ***GU119354
    May 2015
    California
    86
    More smooth
  5.
  6. #14
    Feb 2016
    11
    My energy usage did go back up as suggested. It took about 2 full charges. I'm now back to 14kWh used for a full battery depletion
  7. #15
    Oct 2016
    Flyover Country
    15
    Quote Originally Posted by MrvW View Post
    Good to know...I got the notice in the mail about this update and will have it done when I take the car in for it's first scheduled maintenance/oil change sometime next month.
  8. #16
    Apr 2016
    Irvine, CA
    43
    Didn't notice any change in the regen paddle.. But the location based home charge delay was turned off.. That was a tad annoying.
  1. Improved Range and Efficiency after the Reduced Propulsion Recall
    By JoeReal in forum Generation 2 Volt (2016-2020)
    Last Post: 01-17-2017, 12:16 PM
  2. Gen 2 Usable kW
    By BAZINGA in forum Generation 2 Volt (2016-2020)
    Last Post: 05-18-2015, 05:33 PM
  3. 2015 usable KW
    By secakc33 in forum Chevy Volt General Discussion, News, and Events
    Last Post: 01-17-2015, 10:51 PM
  4. Usable Battery Capacity
    By Ladogaboy in forum Li-Ion Battery, Charging & Battery Managment System - Spark EV
    Last Post: 07-31-2013, 07:30 PM
  5. Usable kWh question...
    By CarZin in forum Generation 1 Volt (2011-2015)
    Last Post: 02-14-2012, 02:27 PM
