Reduced Range and usable only 9.9kWh usable after Recall 16055 applied
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: Reduced Range and usable only 9.9kWh usable after Recall 16055 applied
  1. #1
    Join Date
    Feb 2016
    Posts
    11
    Default Reduced Range and usable only 9.9kWh usable after Recall 16055 applied
    Hello,
    Yesterday I brought my 2016 Volt in for the recall 16055 “Propulsion Power is Reduced”. I noticed today that my max kWh used before the ICE starts is now much lower. I used to get about 50+/- miles and 13.9kWH (since full charge) used before the ICE would turn on and battery showed empty. Today it only went 37miles and 9.9kWH (since full charge) before the ICE started due to battery empty?? Has anyone seen this? On the Dealer Invoice it states "Recall 16055 Programmed HPCM2 for Recall. Relearned Batt Capacity and coolant Valve"
    Could they have relearned a Lower capacity? Or entered a wrong value?
  2. #2
    Join Date
    Jul 2014
    Location
    New Joisey
    Posts
    538
    Default
    Not sure if Gen 2 is similar, but on Gen 1 if the "relearn" procedure was not performed to exacting standards, the Volt has to "relearn" on its own the correct SOC for charging and depletion. In the meantime, it will default to "safe" values that are way more conservative than normal. This takes several (perhaps 10--WOP knows the full amount) complete charges and discharges before it will start getting back to normal.
    My advice is to make sure you deplete the battery fully after a full recharge and avoid partial charges for at least a couple weeks. If it doesn't start creeping up to normal, time to take it back.
    Also, I think another Gen 2 owner had a similar issue after the recall, so you may want to look for that.
    ***2013 Black Volt, Leather with Ceramic White Accents***
    ***17" Sport Wheels, Nav, Bose, SP1***
  3. #3
    Join Date
    Feb 2016
    Posts
    11
    Default
    Thanks, all I was coming up with searches are post on MPGe being better after the reprogram, or mileage dropping due to cold weather. I have a 78mile round trip so draining the battery each time won't be a problem. We'll see what happens.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5.
    Advertisement
  6. #4
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    12,296
    Default
    It's an automated process so the possibility of an errant number making it's way into the update is slight. Just keep an eye on things. It's quite possible the update simply returned all the values to their default and it will take a few cycles for the car to factor in your driving cycle.
  7. #5
    Join Date
    Jun 2016
    Location
    Washington
    Posts
    581
    Default
    It's probably due to a reset from the recall. See my post in the recall thread.
    My Volt appeared to have lost 2kWh of battery when in fact the 2kWh I consumed driving it to the dealer was zeroed out. Upon completely draining the recharging the battery, I got my 14kWh capacity back and it's corroborated by my standard commute during same weather: the % EV miles was still the same before and after the recall so my EV capacity was back to normal.
    2017 Kinetic Blue Volt, VIN #11955, built June 2016.
  8. #6
    Join Date
    Aug 2008
    Location
    Gwinnett County, GA
    Posts
    131
    Default
    I didn't notice any difference after the upgrade involving EV miles, but I did have to change some settings back to my preferences. However, I did notice one odd occurrence. The first day, I no longer had the "three flash" lane change function on my turn signals which I use a lot on expressways. I checked the manual, but there was no setting to change it as there is on my German cars. Then a day or two later the "three flashes" came back. Since it's now working, I'm not going to worry about it.
  9. #7
    Join Date
    Mar 2012
    Location
    Southern Illinois
    Posts
    5,592
    Default
    Quote Originally Posted by O'Dell View Post
    +1 after recall done to my 17.
    Tom aka Accidental Electronaut
    USAF Retired
    My garage
    2017 GMC Acadia Denali
    2017 Volt Premier
  10. #8
    Join Date
    Jul 2015
    Location
    S.E. Wisconsin, U.S.A.
    Posts
    330
    Default
    It appears that they're also needlessly recalling cars that already have the updated program. Mine was one of them...
    ____
    Bob
    2017 Volt LT
    Summit White/Black
    Bose, Comfort, Protection
  11. #9
    Join Date
    Apr 2016
    Location
    Evans, GA
    Posts
    32
    Default
    Mine too. It was built in June 2017. I never had any trouble with it and noticed no difference after recall applied.
    Glenn Link
    2017 Volt LT Citron Green
    2006 BMW 330i
    2005 Dodge Sprinter 118"
    2004 Club Car Precedent (gas)
    2002 Harley Davidson Road King Classic
  12.
    Advertisement
  13. #10
    Join Date
    Aug 2015
    Location
    Rochester, NY
    Posts
    465
    Default
    What settings?
    Quote Originally Posted by BAZINGA View Post
    2016 Kinetic Blue Premier, brandy/black leather, both safety packages.
    My Hidden Content
    VIN: ***GU119354
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Improved Range and Efficiency after the Reduced Propulsion Recall
    By JoeReal in forum Generation 2 Volt (2016-2020)
    Last Post: 01-17-2017, 12:16 PM
  2. Gen 2 Usable kW
    By BAZINGA in forum Generation 2 Volt (2016-2020)
    Last Post: 05-18-2015, 05:33 PM
  3. 2015 usable KW
    By secakc33 in forum Chevy Volt General Discussion, News, and Events
    Last Post: 01-17-2015, 10:51 PM
  4. Usable Battery Capacity
    By Ladogaboy in forum Li-Ion Battery, Charging & Battery Managment System - Spark EV
    Last Post: 07-31-2013, 07:30 PM
  5. Usable kWh question...
    By CarZin in forum Generation 1 Volt (2011-2015)
    Last Post: 02-14-2012, 02:27 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
