PROPULSION POWER REDUCED message
Grab our Forum Feed
+ Reply to Thread
Results 1 to 9 of 9
Thread: PROPULSION POWER REDUCED message
  1. #1
    Join Date
    Feb 2012
    Location
    Eureka, IL
    Posts
    11
    Default PROPULSION POWER REDUCED message
    I am the original owner of a 2012 Volt. It has 104,000 miles on it. Twice in the past month I have received the following message: "Propulsion Power Reduced". In both instances, my battery had been depleted and had been running on gas. I turned the car off and after turning the car back on and driving a short distance I got this message. Both times temperatures were sub freezing perhaps even close to 0 F (I can't exactly recall). Even though I accelerated slowly and was driving in town and at slow speeds, the gas generator was racing very fast. When I arrived home (about 1 mile drive), I could smell that "hot engine" smell.
    Could it be that the car is overusing the battery and when I start it back up the generator needs to recharge to the minimum battery level? Or perhaps the cold reduced the battery capacity readings as it sat and needed to recharge up to the minimum? Hopefully I'm not looking at a major problem here?
    Has anyone else had this issue or can anyone explain why this might be happening?
  2. #2
    Join Date
    Mar 2010
    Location
    Central NY
    Posts
    4,305
    Default
    Just one theory here (there's many other possibilities)...
    When very cold and battery depleted, you stop somewhere with no usable charge left in the battery. Battery voltages tend to droop with cold temperature. The battery may be cooling off while sitting, causing the battery voltage drooping a bit before you turn the car back on. When you do turn it back on, the car thinks the voltage is too low, so you receive the message as described and the engine revs up high to charge the battery a bit.
    I would wait and see what happens, but it wouldn't surprise me if this is what's occurring.
    Do you charge your battery to full often? If not, try doing that as well. It will make sure the cells are properly balanced. When I had a section of the battery replaced due to a bad temperature sensor, I had the PPR message and high engine revving once when switching over to gas after the battery was depleted. Seemed to be a one off occurrence due to cell balancing and a new section of the pack. Once I charged it back up to full the message never occurred again.
    Hidden Content - Provide backup power to essential appliances.
    Hidden Content - Keep yourself from getting unplugged!
    Join thE REVolution
    2011 Volt #186, VIN: B-00186, Cyber Gray Metallic - TRADED! 28k miles, 9k engine, 120MPG
    2013 Volt #43404, Blue Topaz Metallic
    Driving for FREE with Solar PV!
  3. #3
    Join Date
    Oct 2014
    Location
    phoenix
    Posts
    133
    Default
    This is a normal condition when the drive motor battery is below threshold and the engine is used to bring the charge back up. has seen this with one of our salesman's car.
    The vehicle does NOT need to be taken to a dealer unless the Propulsion Power Reduced message is accompanied by a Malfunction Indicator Light (Check Engine Light).
    Not just a volt tech, also a volt owner.
    2015 Volt
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5.
    Advertisement
  6. #4
    Join Date
    Jul 2009
    Location
    Kitchener, Ontario, Canada
    Posts
    2,927
    Default
    Did the car sit un-plugged for a period of time when the message came up.
    Reason I ask is if the battery gets very cold the Volt can start in a type of deep cold battery mode. It will run off the gas engine as much as possible to minimize battery use till the battery warms up sometimes bringing up propulsion power reduced.
    Hidden Content 2017 Volt - Kinetic Blue - Black Cloth - HU3085
    Hidden Content
  7. #5
    Join Date
    Feb 2012
    Location
    Eureka, IL
    Posts
    11
    Default
    The car was not plugged in at the time. (I was shopping for about 15 minutes.) I always plugin and fully charge the car at night. I wasn't driving it any differently and was in similar weather as the previous 4 years I've owned it. Perhaps with the mileage, these quirks may start to occur. I suspected it may have to do with voltages dropping as it sat in the cold. Hopefully that is the case. Thanks for the quick feedback!
  8. #6
    Join Date
    Dec 2013
    Location
    Norco/Corona, CA
    Posts
    2,371
    Default
    Some of us believe the Volt is more EV than Hybrid. The gas motor can only produce 84HP, but the battery can supply 149HP.
    Because of that, if the battery cannot be used to make up the 65HP difference, it shows the Propulsion Reduced message.
    Does the 2012 have Mountain Mode? If so, try that.
    It's funny that ICE cars don't show this message at high altitudes on hot days, when they lose up to 1/3 of their rated HP.
    Ménage à trois - 2017, 2016 and 2013 Volts.
    Tesla Model 3 Reserved
  9. #7
    Join Date
    Aug 2010
    Location
    Detroit, MI
    Posts
    3,562
    Default
    Quote Originally Posted by amhobbs View Post
    We can see how this might be concerning, mhobbs. We recognize that you may be seeking advice from other drivers, however we'd like the opportunity to look into this further on our end as well. If you could please send us a private message with your contact information, VIN and preferred dealership, we'll proceed from there.
    Lauren E.
    Chevrolet Customer Care
    If you have any further questions feel free to contact the
    Chevrolet Volt & Spark EV Advisor Team:
    (877) 486-5846
    Chevrolet Volt & Spark EV Advisor Hours:
    Monday - Friday 9AM to 9PM EST.
    Closed on Saturday and Sunday.
    Hidden Content
    Hidden Content
    Hidden Content
    For information on the GM Privacy Statement, please visit Hidden Content
  10. #8
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    15,115
    Default
    A "racing engine" is simply the gas engine is trying to generate more electricity to fill the battery. Normal. It has nothing to do with car speed.
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 84,576 miles, 135 MPG, Remaining Oil Life 74%
    Typical Commute: 60 miles
    30 day Stats: 1366 miles, 125
    MPG, 65% Electric, 33% gas, Saved 48 gal., 27 kW-hr/100 miles
  11. #9
    Join Date
    Jan 2015
    Location
    North Dakota
    Posts
    779
    Default
    Every time I leave my '12 Volt sit outside for extended periods in subzero temps, I see "reduced propulsion". It's from a cold battery.
    IF you see it after unplugging, or above zero temps, then you need to worry.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Weird reduced propulsion message
    By peevee in forum Problems/Issues, Driver Warnings or DTCs - Chevy Volt
    Last Post: 09-13-2016, 06:46 AM
  2. Propulsion power is reduced message came up for the 9th time this month!!!
    By Zagnuts in forum Generation 1 Volt (2011-2015)
    Last Post: 09-12-2016, 01:44 PM
  3. Propulsion Power Reduced warning
    By gattboy in forum Propulsion Systems - Chevy Volt
    Last Post: 03-15-2015, 05:54 PM
  4. Reduced Propulsion Message and Engine Check Light
    By ClarksonCote in forum Problems/Issues, Driver Warnings or DTCs - Chevy Volt
    Last Post: 08-12-2013, 05:06 PM
  5. "Propulsion power reduced/ limited" error message
    By scottgf in forum Problems/Issues, Driver Warnings or DTCs - Chevy Volt
    Last Post: 12-27-2012, 09:02 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
