Getting 7 MPG while in ERDTT...
Results 1 to 9 of 9
Thread: Getting 7 MPG while in ERDTT...
    Default Getting 7 MPG while in ERDTT...
    Seems a little low.
    You would figure the engine wouldn't run so rich while cold (30 degrees F) - (more fuel = lower combustion temperatures). Only drive one or two miles in ERDTT (for about 5 minutes) but, what a hit to MPG.
    I'm thinking the gas "guess-O-meter" may be off and needs to recalibrate.
    Dec 2015
    Virginia
    1,451
    Quote Originally Posted by Slave to Opec View Post
    Seems a little low.
    Modern cars inject extra fuel to heat up the catalytic converter fast so it becomes functional. All ICE suck for the first 5-10 miles so I'm not at all surprised at that reading.
    I've watched my Gen 1 tank down to 10mpg like it was pushed off a cliff, then work it's way back up to reasonable as the engine gets warm.
    A study in opposites
    1997 Jeep Cherokee
    2013 Chevy Volt "OHM-RIDE"
    Aug 2009
    Texas - DFW
    4,328
    Instant MPG is misleading for any vehicle. It could hit 99mpg if going downhill on most ICE cars.
    For perspective: At full power, a 700HP Hellcat uses a tank of fuel in 20 minutes.
    Driving a show car. Every day!
    Don't Pokemon and drive!
    2014 Crystal Red ELR (REDD) code R w/Cashmere interior
    L2 - GE WattStation
    iOS 10.2 on iPhone 6. MyCadillac App version 3.3.0
    wisconsin
    1,302
    If your driving slow that's what it is.
    I've had it as low as 9 mpg.
    Drive faster and your mpg will go up in the 20's
    I would recommend a somms resistor.
    I only need mine 2 months a year but well worth it.
    12,141
    Unfortunately the estimate may be right. As pointed out, the engine needs to run to heat up the cat converter. So you pay a big price. In pollution as well by the way. A Prius would get about the same MPG. Sad fact of life. Wish ERDTT wasn't needed. On a trip it won't matter since you're covering a lot more ground and the engine is a lot more efficient.
    Central illinois
    144
    No that is pretty much standard. The gas and elec runtogether during erdtt though so your mpg will be 40-50 or 60 that depends.....I guess you could hold mode and go to all gas but then your overall mpg would be in the 30's
    Aug 2008
    2,436
    I saw 2-3 when I first started my last trip, but it kept climbing as I drove. I'd say it's normal
    Mar 2010
    Central NY
    4,267
    Seems a little low.
    Not unexpected especially if some of the time the engine is running, you're stopped in traffic.
    Also, you could always change the setting under Engine Assisted Heating in the Config menu to "Deferred" ... when this is done, ERDTT will only occur when colder than 15F, rather than the default 35F.
    Hidden Content - Provide backup power to essential appliances.
    Hidden Content - Keep yourself from getting unplugged!
    Join thE REVolution
    2011 Volt #186, VIN: B-00186, Cyber Gray Metallic - TRADED! 28k miles, 9k engine, 120MPG
    2013 Volt #43404, Blue Topaz Metallic
    Driving for FREE with Solar PV!
    Aug 2014
    Marion, IA USA
    1,996
    How are you calculating the MPG?
    In ERDTT mode energy is also put into the battery, so the only decent way to measure it is with a dead battery and end the drive with a dead battery.
    If I look at the gas miles driven divided by the gas used I get meaningless results. In the single digit temps, fan only mode (no electric heat), and I calculate around 14 mpg on short trips, but also my electric range extends way out as the engine is running a lot more. However, if I factor in the extra electricity generated it is about 25 mpg.
    My point is that if you calculate by EV miles and gas miles driven in the display, with ERDTT on you will see your electric driven efficiency go up and your gas efficiency go down. As I said, just don't charge your car one day and drive it around to see what kind of efficiency you are really getting. I think ERDTT will actually reduce your overall energy use assuming you would have used electric heat.
  1. Replies: 5
    Last Post: 07-11-2016, 09:26 PM
  2. trip computer mpg doesn't match energy usage screen mpg
    By bxd20 in forum Chevy Volt General Discussion, News, and Events
    Last Post: 03-11-2015, 05:51 PM
  3. I have had my Volt for 8 months, no charger at home, and my lifetime mpg is 307 mpg.
    By Ziv in forum Chevy Volt General Discussion, News, and Events
    Last Post: 02-12-2014, 09:39 PM
  4. 131 mpg over a distance of 100 miles compared to 78 mpg with a 2010 Prius
    By Dominique Matte in forum Propulsion Systems - Chevy Volt
    Last Post: 09-05-2013, 11:19 PM
  5. 700 mile trip, 46 MPG total, 41.7 MPG on gas
    By ctdeng0 in forum Chevy Volt General Discussion, News, and Events
    Last Post: 07-27-2012, 07:00 PM
