Bolt's battery SOC leaving factory
Results 11 to 20 of 20
Thread: Bolt's battery SOC leaving factory
    Los Angeles
    5,085
    When the shipment came in, I stopped by the dealership. They had to charge every Bolt EV they had received (some of them on 120 V), and my salesman was lamenting the 50 hours it was taking to charge.
    Aug 2015
    Vancouver Canada
    1,109
    Quote Originally Posted by Ladogaboy View Post
    Geez, guys, at least spring for a level 2 charger.
    Los Angeles
    5,085
    Quote Originally Posted by Sean Nelson View Post
    They were all in use! We walked around back, and they had two more Bolts plugged into the 120 V. That's when he said that anyone who tried to charge the Bolt from a low battery on 120 V is crazy.
    I'm about to get "crazy" FWIW. :-D
  4. Advertisement
    Aug 2015
    Vancouver Canada
    1,109
    Yeah, that's something I'm contemplating for when I buy a Bolt EV later this year. It takes over 40 hours to fully charge at 120V/12A, so with an overnight 12 hour charge you'd be putting in around 100km's (60 miles) worth of distance. So the question is whether or not you'd need to drive significantly more than that for more than a couple of days in a row.
    14,828
    With my anticipated use (60 or so miles a day or less), I'll be recharging in a few hours on L2 just like my Volt. I would very rarely if ever be recharging a nearly empty battery. The Volt will drop to 10 mile trips. So I anticipate nearly 100% electric use between the two cars (Except for Volt FMM of course).
    2011 Cyber Gray, Std Wheels, Black Leather/White Console, Bose, Nav, Htd Seats, Park Assist. Picked up May 2011
    Lifetime: 84,576 miles, 135 MPG, Remaining Oil Life 74%
    Typical Commute: 60 miles
    30 day Stats: 1366 miles, 125
    MPG, 65% Electric, 33% gas, Saved 48 gal., 27 kW-hr/100 miles
    Hidden Content Free Volt Manual here: Hidden Content
  7. #16
    Oct 2012
    United States - MD
    6,060
    Dang, if my L2 unit somehow craps out and L1 is too slow, where will I ever charge my Bolt? (I live a few miles southwest of Baltimore....sorta hard to see Baltimore though 'cause all the CCS station icons are blocking it)
    My Bolt EV blog: Hidden Content
    cleantechnica.com and electrek.co: you suck, don't link my stuff
  8. #17
    Baltimore
    962
    Quote Originally Posted by bro1999 View Post
    Be sure to sing some opera while waiting for your Royal Farms Chicken and Charge.
  9. #18
    Jun 2008
    Nashville, TN
    7
    Default Bolt EV: Near-zero Vampire Loss in Sub-freezing Temps over Two Days,
    Quote Originally Posted by flankspeed8 View Post
    It will be interesting to track what the vampire loss is. This is one thing that has scared me from the Tesla S, I have heard stories of people loosing 4-5 miles a day. Hopefully technology improves this. I never see any vampire loss on my Volt, even after 2 weeks.
    Take heart, my friend! There are a couple of YouTube videos posted by a brand-new Bolt EV owner (and forum member) who got a flat tire high in the mountains of CA and had to leave his car idle on the roadside for two days in sub-freezing temperatures. It was a serious flat caused by a fairly large, sharp rock hiding underneath the snow. This couldn't be repaired with the PNG (pump-'n'-goop) kit provided with the car, and he also had no cellular connection, so neither OnStar nor anyone else could be contacted; he had to await friendly passers-by for help and go get a new tire mounted.
    I was pretty dang impressed to see that his Bolt only logged about 0.2 kWh of depletion during those two days with mostly sub-freezing temperatures. He drove it home a fairly long distance while getting incredible efficiency of around 5.1 miles per kWh, if I'm remembering correctly. Of course he was driving down a mountain a good part of the way, but still, the heat was running at 69F and the temperature was in the 30's (F). Thus, so far it looks as though the Bolt EV's battery is incredibly efficient and durable. People seem to be getting extremely good range, often 250 miles. The same YouTuber posted another couple of videos showing a route he usually drives in both dry/ warmer and wet/ colder conditions, and his mileage estimator showed (if I remember correctly) something like 225 miles for the former and 195 miles for the latter.
    I can't post links or screen shots yet I don't think, but I shall try. If it doesn't work, you can search YouTube for "News Coulomb" or "Bolt EV TIRE FAIL"; the before/ after shots of his kWh usage are in two separate videos, parts 2 and 3.
    (edit: it appears I *can* post links and screen shots, so below you'll see a screen shot for his kWh estimated usage before and after leaving his car for two days in sub-freezing temperatures. Near-zero vampire losses!)
    https://www.youtube.com/watch?v=YiCFIxB4atk
    https://www.youtube.com/watch?v=72d0J2fCZIs
  10. #19
    Feb 2012
    Columbus, GA
    194
    Sales rep sent me a photo, had 48 miles of charge, but it was charging at the time. So not sure where it started, could have been 40, best guess.
    2017 Bolt Summit White premier on the way
    2012 Volt White Diamond Tricoat awaiting sale
    2016 Volt Summit White
  11. Advertisement
  12. #20
    May 2015
    Virginia
    774
    Quote Originally Posted by cfspeakman View Post
    Slightly lower initial charge -
    2016 Volt Premier Silver/Black #16693 (Delivered Oct 2015)
  1. Actual battery SOC vs. available SOC ranges
    By Sean_R in forum Electrical Systems - Chevy Volt
    Last Post: 11-21-2016, 11:21 AM
  2. Battery Health - Can Regenerative Braking Overcharge a Full SOC Battery?
    By Halcyal in forum Care, Maintenance & Service - Gen2 Volt
    Last Post: 10-09-2016, 09:18 PM
  3. Battery Director Denise Gray Leaving GM For Stealth Battery Startup
    By Lyle in forum Chevy Volt General Discussion, News, and Events
    Last Post: 02-24-2010, 08:32 PM
  4. Taking battery down to only 50% SOC?
    By Altazi in forum Chevy Volt Engineering and Design
    Last Post: 10-03-2008, 07:52 PM
