2014 Volt Heater/Firewall Rubbing
Grab our Forum Feed
+ Reply to Thread
Results 1 to 7 of 7
Thread: 2014 Volt Heater/Firewall Rubbing
  1. #1
    Join Date
    Dec 2016
    Location
    Raleigh, NC
    Posts
    5
    Default 2014 Volt Heater/Firewall Rubbing
    Hey all,
    I just recently payed the dealership a large sum of money to track down and repair a creaking sound in my 2014 Volt, which turned out to be my heater core rubbing against the firewall whenever I accelerate or decelerate. For those who are well-versed in the inner workings of a Chevy Volt--where is the heater core, how would I most easily access it, and if you have had a problem like this before, how did you fix it? The dealership said that they "re-shimmed my heater," but I can tell you that a week later this hasn't worked permanently.
    Thank you all in advance, and feel free to let me know if you need any additional info.
  2. #2
    Join Date
    Mar 2010
    Location
    Central NY
    Posts
    4,311
    Default
    I'd bring it back to the dealer given that your car is still under warranty. Let them figure out how to solve the problem permanently.
    Hidden Content - Provide backup power to essential appliances.
    Hidden Content - Keep yourself from getting unplugged!
    Join thE REVolution
    2011 Volt #186, VIN: B-00186, Cyber Gray Metallic - TRADED! 28k miles, 9k engine, 120MPG
    2013 Volt #43404, Blue Topaz Metallic
    Driving for FREE with Solar PV!
  3. #3
    Join Date
    Dec 2016
    Location
    Raleigh, NC
    Posts
    5
    Default
    Unfortunately it isn't under the bumper-to-bumper any more, I bought it past the 36k mark.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Aug 2008
    Location
    Long Island, NY
    Posts
    2,058
    Default
    I think that ClarksonCote is referring to the warranty of the repair. The paid-for repair did not fix the problem. A return to the dealership to point this out is in order. Let them determine what they did wrong - that determination being on their dime - and make the lasting repair, again, on their dime, since you have already paid them for the repair. Good luck.
    EDIT: Additional thought: if it is determined that additional, or replacement parts are required to complete the repair, the cost of that/those part(s) are at additional cost to you. You should not have to pay for the labor to disassemble'replace once again, only for the labor to install the new part.
  7. #5
    Join Date
    Oct 2014
    Location
    phoenix
    Posts
    134
    Default
    The heater core is located inside the dash, unlikely what is causing this noise since it does not move and is not connected to anything that moves. I have seen a lot of cars that make a clicking type noise when taking off and stopping, noise coming from the wheels turned out to be loose cv axle shaft nuts. Retorqued them and the noise was gone. I would recommend you take the car back and go on a road test with the tech to make sure he/she is trying to fix the correct noise you hear.
    Not just a volt tech, also a volt owner.
    2015 Volt
  8. #6
    Join Date
    Dec 2016
    Location
    Raleigh, NC
    Posts
    5
    Default
    Thanks to all who replied!
    I'm a bit new to this whole car ownership thing--what is the repair warranty, and how long is it?
    Also, my note about the heater was direct from the tech's notes, not my own. I have never disassembled my own vehicle.
  9. #7
    Join Date
    Aug 2008
    Location
    Long Island, NY
    Posts
    2,058
    Default
    Quote Originally Posted by Sporkalypse View Post
    Any reputable repair facility will warrant the work they have done for some given period of time. Those times will vary from place to place. Usually, the warranty period is found in writing somewhere on the receipt, but certainly the service manager will be able to state the period. "Hey, the problem is still occurring. When can you take the car back to fix it? OK, thanks, Monday at 9 AM it is." Or words to that effect.
    My dealer usually has my complaint typed on the receipt as well as the parts used to correct the problem. If there were parts used, can you post the P/N's so that we can better understand the area worked on? Perhaps you can also state the labor hours for trouble shooting and the labor hours for the repair, too.
    Good luck.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. 2014 Volt: Heater Problem
    By Quiller in forum Problems/Issues, Driver Warnings or DTCs - Chevy Volt
    Last Post: 12-20-2016, 10:52 AM
  2. Passing wires through 2013 volt firewall
    By Dutch in forum Chevy Volt General Discussion, News, and Events
    Last Post: 01-02-2016, 05:34 AM
  3. 2014 Volt Heater Problem Diagnosed & Fixed by Dealer
    By DogMom in forum Generation 1 Volt (2011-2015)
    Last Post: 06-09-2015, 04:33 PM
  4. my 2014 Volt succumb to intermittent electric heater issue :(
    By lettcco in forum Care, Maintenance & Service - Chevy Volt
    Last Post: 11-20-2014, 02:42 PM
  5. Heater in 2014 models -- please comment
    Last Post: 11-08-2014, 08:14 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
