Iced up plug port
Results 1 to 10 of 18
Thread: Iced up plug port
Hybrid View
    Dec 2016
    Ontario
    13
    Default Iced up plug port
    I have had our new 2017 Volt for a few weeks in a VERY snowy part of Ontario and have had the plug
    port iced up such that it would not open. I pushed a credit card like piece of plastic into and around the edge of
    the cover to get it to open. I figured it was ice from snow getting in from when the car is plugged in outside.
    We have only a one car garage and our other vehicle, a Tesla Model S, is usually inside. I really am impressed with our new Volt overall, but I was wondering if anyone has devised a way to keep snow out of the open charging port. I know it seems a bit ridiculous but I have been leaning a broom over the port to keep the snow off. The Tesla port is much smaller and does not seem to be as prone to the icing up as the Volt with its large port door.
    Jan 2012
    Lakeland Florida
    3,372
    Quote Originally Posted by P_L View Post
    How would you know? You just wrote the tesla sits in the garage all the time will the volt is outside
    Just put a dish rag to cover the port should solve your issues?
    2013 Crystal Red Volt #39239 - New off the lot 8/28/2014
    Make Your Stock charger 240V for 30 bucks! Hidden Content
    Aug 2012
    Ontario, Canada
    997
    I am in Ontario and own a Gen 1. My charge port can freeze up too, mainly due to the freeze/thaw cycles we have and snow and ice getting into the port when plugged in. Get some silicone spray or similar dry lube and spray the gaskets and it will help somewhat. I ignore the crunch and force the door closed each morning and like you, I need to pry a little to open the door to charge. Just make sure you don't damage anything when you have to do that.
    Scott.
    2013 Silver Ice Metallic, Jet Black Premium Trim, Bose Sound, Safety Pkg 1
    Sun Country Highway/Clipper Creek LCS-25 240v Charger
    Canadian Volt
    Best range so far - 73.2km
    Worst range so far - 29.3km
  4. Advertisement
    Sep 2014
    Boston MA
    53
    I've built a shield that is just some weak magnets(think refrigerator flexible magnet) in a beefy plastic bag. I attach it above the port and it forms a roof and two vertical sides.
    I've thought about building a flexible water repellent shroud/snorkel to do this - something that could live on the
    j1772 connector and mate with the car sheet metal when plugged into the car. haven't needed to, yet, still want to...
    Lumos,
    2014 gen 1
    14,967
    There are older threads on this. See http://gm-volt.com/forum/showthread....02#post2289602
    2011 Cyber Gray, Std Wheels, Black Leather/White Console, Bose, Nav, Htd Seats, Park Assist. Picked up May 2011
    Lifetime: 84,576 miles, 135 MPG, Remaining Oil Life 74%
    Typical Commute: 60 miles
    30 day Stats: 1366 miles, 125
    MPG, 65% Electric, 33% gas, Saved 48 gal., 27 kW-hr/100 miles
    Hidden Content Free Volt Manual here: Hidden Content
    Jan 2016
    Michigan
    35
    Around the perimeter of the charge port there is a rubber gasket, you can try lubricating the gasket with rubber conditioning/silicone grease to eliminate water buildup that can freeze it to the charge port door inner surface.
    NJ
    1,499
    Quote Originally Posted by Lumos View Post
    ...I've thought about building a flexible water repellent shroud/snorkel to do this - something that could live on the j1772 connector and mate with the car sheet metal when plugged into the car. haven't needed to, yet, still want to...
    Lumos,
    2014 gen 1
    That's a good idea. Maybe something like this with the handle removed and slit along the length so it is open at the bottom and will fit over the charge port door. https://smile.amazon.com/dp/B0006IXNDW If you do it please report back with a photo. Thanks.
    KNS
    Dec 2016
    Ontario
    13
    Sorry about the double post. New to the forum and thought the first was entered before I got authorization to post. Thanks everyone for the ideas.
    Dec 2016
    Ontario
    13
    Quote Originally Posted by Henry_FL View Post
    Used the Tesla last winter a lot. Just got the Volt in Dec.
  11. Advertisement
    Dec 2016
    Ontario
    13
    Default Snow in charging port
    I have to charge outside often and live in a very snowy area. Anybody have any fixes to keep snow out of the charge port while plugged in? Already had to use a credit card once to break an ice seal that prevented me from opening the port after the snow melted then refroze, and so freezing the cover shut. I did try to scoop as much snow as I could before closing the port door. I have taken to leaning a broom against the port to keep the snow out on snowy days.
  1. Iced out by mother nature!
    By JDan in forum Chevy Volt General Discussion, News, and Events
    Last Post: 12-26-2013, 03:03 PM
  2. New From Blink - Have you been ICEd?
    By doudis2 in forum Generation 1 Volt (2011-2015)
    Last Post: 12-19-2013, 03:56 PM
  3. Leave the port door open so someone can plug you in? Useless
    By TwistnShift in forum Problems/Issues, Driver Warnings or DTCs - Chevy Volt
    Last Post: 07-24-2013, 05:51 PM
  4. Not ICEd - Not sure what to call this...
    By Rampage_Rick in forum Generation 1 Volt (2011-2015)
    Last Post: 12-07-2012, 06:08 PM
  5. Lightly iced by a pip
    By aventineavenue in forum Generation 1 Volt (2011-2015)
    Last Post: 09-07-2012, 03:15 PM
