Instructions on replacing the HVAC fan?
Results 11 to 15 of 15
Thread: Instructions on replacing the HVAC fan?
    Feb 2015
    England
    1,496
    Let us know how you got on. Photos please. It didn't happen unless there are photos on the internet! Good luck with the job.
    Jun 2016
    Rochester NY
    501
    Quote Originally Posted by Henry_FL View Post
    Job for the dealership, digging deep into the dash with airbags is not for the weekend warrior
    The airbags are on top of the dash and aren't easy to trigger when working around them. There are multiple sensors that need to be tripped and the BCM needs to command deployment.
    my little grass shack
    4,571
    Quote Originally Posted by turboguy327 View Post
    On GMs the "BCM" has nothing to do with airbag deployment, it's all within the SDM (Sensing Diagnostic Module)
    True, on modern airbag systems as used in the Volt the "remote" crash sensors such as those under the hood or on the rad support will not on their own trigger a deployment, however mishandling the SDM (located in the center console) while connected to the main airbag harness CAN trigger an inadvertent deployment. (and yes it has happened)
    Most of the concern when "digging around" in the vicinity of an airbag is the potential of inadvertent deployment due to unknown wiring damage that might exist and manipulated during service. All the airbag needs is B+ on one circuit and GND on the other and a bag is out and in your face. (the SDM does not need to be involved) Yes it initially is delivered towards the windshield but is designed to deflect rearward off of the glass
    The best defence when servicing areas in the proximity of the airbags, crash sensors, or SDM is to follow the GM service information steps to properly and when called upon to properly disable the airbag system completely (or zoned disabling). The take no prisoners approach is to shut the car off, remove all FOBs, and disconnect battery negative. Wait 2 minutes. Work away
    Which is exactly what is listed as "STEP 1" in the blower motor replacement procedure, (due to the proximity) which shouldn't be ignored
    Welcome Hidden Content as our latest forum vendor!
    Follow the Chevy Volt and other GM electrified cars on Twitter! Hidden Content
  6. #14
    Sep 2012
    Potsdam, NY
    25
    I installed the new blower yesterday. Its not difficult technically, but it is difficult physically. I'm relatively fit (185 lbs, 6'2"), but its pretty difficult to get under there and get your arms in the right positions. Amazingly its even harder than working under the dash of my tiny 72 MG Midget, the same "sit backwards on the seat then lay on your back with your legs in there air" trick doesn't work as well in the Volt. You'll also need a 7mm and 5.5mm ratchet socket, which is I think the only time I've ever used my 5.5mm socket.
    The bottom trim panel is held in by three screws, one visible in the front, one on the front right that's partially hidden by the right rocker panel trim, and one in the back that's recessed and hard to see. You don't need to remove the right rocker trim to remove the screw, you can push the corner in enough to get to the screw. Once you have that off, there's one more screw in the floor air duct, and once that's out you have to wrestle with the duct a bit to remove it, but it'll pop out. You don't have to remove it completely to get the blower motor out, but personally I couldn't reach the blower plug without removing the duct. Installation is the reverse. Probably took 30 minutes, and I could probably do it in 10 minutes if I had to do it again.
    The new blower definitely works better than the old one, more air and less noise. I am occasionally still having an issue where the fan runs full speed, but I'm not always getting as much air as I should. I think there might be an issue where the doors that control the flow of air might not be opening and closing entirely.
  7. #15
    Jun 2014
    Charlotte NC
    254
    Quote Originally Posted by WopOnTour View Post
    Not that I need to, but is good information to have, what do you mean by "remove all FOBs"? Get the keys far from the car?
    thanks.
  1. HVAC fan flowing, little air coming out
    By TheLastDeadMouse in forum Problems/Issues, Driver Warnings or DTCs - Chevy Volt
    Last Post: 01-14-2016, 07:45 PM
  2. Fan Only mode isn't always Fan Only
    By ahaer in forum Generation 1 Volt (2011-2015)
    Last Post: 12-10-2015, 08:34 PM
  3. Auto fan control sets fan to max
    By Tywin in forum Problems/Issues, Driver Warnings or DTCs - Chevy Volt
    Last Post: 04-20-2015, 01:51 PM
  4. Instructions for Firefighters
    By DogMom in forum Chevy Volt General Discussion, News, and Events
    Last Post: 06-17-2014, 11:43 PM
  5. Replies: 15
    Last Post: 06-11-2012, 10:07 AM
