Hi Guys, almost done with Hybrid volt support in efilive to tune your car yourselves.
Page 25 of 25 FirstFirst 1 15 25
Results 241 to 246 of 246
Thread: Hi Guys, almost done with Hybrid volt support in efilive to tune your car yourselves.
  1. #241
    Aug 2012
    Alberta
    19
    Quote Originally Posted by RoRo View Post
    Nothing like other cars?
    I'm willing to go out on a limb and guess that ECM for the 1.4L engine in the Volt is the exact same ECM that is in the Cruze. I'm also going to take a wild stab and guess that any OBDII diagnostic scanner can hook up to the Volt and read codes. Thus, the computer in the Volt is inherently like other cars.
    Yes the Volt has the same E78 ECM as the Cruze does. EFILive can already unlock that ECM and upload a bootloader to read out the memory segments. However they have not laid out the definition files that allow their software to tune the ECM as yet. wait4me was working on building those definition files, and he has a head start because GM is changing their engine management strategy across their whole line to mesh better with hybrid powertrains. Much of the Cruze coding is already embedded with features that make it easier to adapt to a hybrid application.
    Joel
    D1677 - Purchased August 27 2012
    www.payntonperformance.com
  2. #242
    Oct 2012
    Vermont
    335
    Quote Originally Posted by jpgmtech View Post
    I am well aware of that bulletin. In fact, I wrote and article for it that was published in a Diesel magazine. The LMM and now the LML Duramax Diesels are the only ECM's with an active programming event history list that we (I am a GM tech BTW) can access.
    On every other ECM so far, GM has not found it necessary to activate a programming history routine or make it available with the scan tool equipment. Therefore, you can reprogram the calibrations to stock and return the CVN's to stock without anyone knowing that it was programmed. Of course, GM can easily activate this feature on any of the ECM's that they use. <edit> - It appears that they have activated a programming event history on some of the Global A ECM's for the V8 and V6 engines, just looked up the latest bulletins for the Camaro. There is no such bulletin listed that applies to the Volt
    In addition, some tuners are writing their memory segments so that they return a factory CVN anyway, so a tune can be masked and not show up on our equipment.
    That says it all right here...these tuners trash an engine and then try to cover the tracks of their crime...
    When the systems throw codes the error handler should bump some counters in some form of protected memory segment...Or better yet transmit it via Onstar OFFSITE...
  3. #243
    Aug 2012
    Alberta
    19
    Quote Originally Posted by Upper5Percent View Post
    Some tuners are hacks and damage almost everything they touch. Others are quite good at what they do, keeping things quite reliable. Either way GM certainly does not endorse it.
    Joel
  5. #244
    Mar 2013
    Kentucky
    13
    Ooohh, that's slick! We did something similar in another programming endeavor I was involved in years back to "cloak" our code changes. But I haven't done anything where I had any need hide my code modifications for some time, and didn't really think about doing anything like that. That's a very elegant solution for retaining the proper checksum hash value though!
  6. #245
    Jan 2013
    warsaw indiana
    55
    sorry been busy with other things, so I haven't hung around here at all...
    I sent over the files to be put in the software the day I started posting. They have been done, and anyone with EFIlive software can tune your ENGINE controller. You are in full control of applied throttle torque and 100s of other things you would want to probably play with..
    It is not vapor ware. It is real. I have sent the files needed to about 50 others that asked.. So, good luck guys. I'm now hacking the Fisker karma, which is a much more fun car..
    Karma = 2 200hp electric motors topped off with a Turbo engine that is a variant of what the volt has in it.. When the engine is running with the electric motors on the Karma, with a little tune...... ;D
  7. #246
    Los Angeles
    1,853
    Quote Originally Posted by wait4me View Post
    Thanks for checking in. How has the tuning gone for the guys with the files/EFIlive? Is there anyway the files can be put up on a mirror site?
    Also, good luck with the Karma. That car should be able to put down some interesting numbers.
  1. Support US jobs? Then support electric cars
    By JamesMcQuaid in forum General Motors and General Automotive Topics
    Last Post: 12-03-2012, 03:40 PM
  2. Bob Lutz: Car Guys vs. The Bean Counters
    By Jason M. Hendler in forum General Motors and General Automotive Topics
    Last Post: 06-17-2011, 11:47 AM
  3. Replies: 8
    Last Post: 12-25-2010, 10:06 PM
  4. Build your own cheap electric car? These guys did
    By Anto in forum Electric Car Competitors
    Last Post: 10-27-2009, 06:55 PM
  5. GM: Aren't you the guys who killed the electric car?
    By efusco in forum General Motors and General Automotive Topics
    Last Post: 05-07-2008, 08:12 PM
