PIC6275 Intermittent P018B P0AC4 U18A2 P16E0 Stall or Reduced Power Message
Grab our Forum Feed
+ Reply to Thread
Results 1 to 7 of 7
Thread: PIC6275 Intermittent P018B P0AC4 U18A2 P16E0 Stall or Reduced Power Message
  1. #1
    Join Date
    Dec 2015
    Location
    California
    Posts
    6
    Default PIC6275 Intermittent P018B P0AC4 U18A2 P16E0 Stall or Reduced Power Message
    I have had my new 2016 Volt for 1 week, and have been loving it. I have about 250 miles on it and probably 220EV vs 30GAS.
    Today when I was driving home from short errand, coming around a turn it lost power and the check engine light came on. I was able to pull to the side. I turned it off, back on, and every time it was shifted out of Park it said to put it back in Park. It would then say reduced propulsion. I couldn't get it to run at all in either Normal or Hold modes. I had just about a full charge, said 45 EV miles left.
    After many tries, I finally turned it off, waited, and it turned back on and would go, although still had check engine light on. I called OnStar and they said it had codes P0AC4 and P1E39. They recommended taking the car to dealer right away, but as it is New Years Eve, I don't have that choice.
    Has anyone experienced this?
    Thank you for any input.
    Ryan
    Last edited by WopOnTour; 03-31-2017 at 07:53 PM. Reason: revised title for DTCs and bulletin
  2. #2
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    4,134
    Default
    Your post was in a moderated status. I freed it. I don't have anything specific. Our 2016 with 1300 miles has not had any issues.
    Pay close attention to anything WOT says.
    P0AC4 - http://gm-volt.com/forum/showthread....0139#post90139
    P1E39 - http://gm-volt.com/forum/showthread....ter-long-drive
  3. #3
    Join Date
    Jul 2013
    Location
    Orange County, CA
    Posts
    36
    Default
    No issues. 1200 miles.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Oct 2012
    Location
    USA
    Posts
    3,802
    Default
    Quote Originally Posted by rybidybo View Post
    Ryan
    Well...you should at least go out and check your fluid levels
  7. #5
    Join Date
    Dec 2015
    Location
    California
    Posts
    6
    Default
    Thanks for the input. I did check fluid levels and looked okay.
    I started the car today (didn't have to go anywhere and was waiting for dealer service to open tomorrow) and the check engine light wasn't on anymore. I took for a short test drive and everything seemed normal.
    Not sure what that hiccup was all about. Kind of scary.
    Ryan
  8. #6
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    12,371
    Default
    The good news is it went away. Better news would be the dealer finds what caused the problem. The MIL isn't a big deal. It can come on for all kinds of trivial reasons like not liking the charger. The reduced propulsion message is a different matter. For Gen I this was usually low coolant, which isn't a big deal, or a coolant leak. Something along these lines. For Gen II it could be something entirely different.
    Sorry it happened. It will take you a while to get over the problem. Let us know what they tell you.
  9. #7
    Join Date
    Sep 2008
    Location
    my little grass shack
    Posts
    4,611
    Default
    A recent bulletin OIC6275 has been released for intermittent SES and specific DTCs (see below) Stalling, or Reduced Power Message
    DTCs affected: P018B, P0AC4, U18A2, P16E0,
    Cause: Lose terminal in the IP fuse block
    Correction: Check the X51A Instrument panel fuse panel for a lose terminal to fuse F9DA (X111 Fuel Pump/Chassis Control Module)
    This is could be causing an interment power issue on ckt 1540, Please drag test Terminal 51 at the fuse block using the right test lead.
    If a lose terminal is found, Replace it with the correct terminated lead listed in SI (Service Information).
    WOT
    Welcome Hidden Content as our latest forum vendor!
    Follow the Chevy Volt and other GM electrified cars on Twitter! Hidden Content
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Reduced Propulsion (Onstar said they couldn't read diagnostics) car won't go.
    By ItGeekOut in forum Problems/Issues, Driver Warnings or DTCs - Chevy Volt
    Last Post: 08-08-2015, 05:04 AM
  2. Replies: 9
    Last Post: 04-27-2015, 01:15 PM
  3. Propulsion reduced on the Grapevine
    By jamtracy1 in forum Chevy Volt General Discussion, News, and Events
    Last Post: 09-16-2014, 02:17 AM
  4. reduced propulsion mode only
    By rbuchner in forum Problems/Issues, Driver Warnings or DTCs - Chevy Volt
    Last Post: 09-11-2013, 08:30 PM
  5. Reduced Propulsion
    By Volt Ohio in forum Li-Ion Battery, Charging, & Battery Managment System - Chevy Volt
    Last Post: 12-13-2012, 09:43 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
