Front recovery hook?
Grab our Forum Feed
+ Reply to Thread
Results 1 to 7 of 7
Thread: Front recovery hook?
  1. #1
    Join Date
    Dec 2015
    Location
    Santa Cruz
    Posts
    24
    Default Front recovery hook?
    The 2016 Volt Playbook that I received from my dealer lists a front recovery hook as standard on both trims. I found that curious, because when I had the Volt for a test drive, I looked for hooks in the front and back and couldn't find any.
    Can someone who has a 2016 Volt tell me if they can find the hook? The reason I am in interested is because I'd like to use it for a kayak front tie-down.
  2. #2
    Join Date
    Jan 2014
    Location
    Rochester, NY
    Posts
    1,001
    Default
    It should be in with the air pump, tire goo and such, under the trunk floor. It may be under all of that stuff.
    PO Troll #3
    Your Volt is too loud. Really!
    Your Volt is too unfinished. Seriously.
    Your stuff in the trunk is too visible. Not cool!
    Your floor mats are too small. They aren't up to the job.
    Your phone and GPS block your view. And you don't need cords all over.
    Your radiator is too vulnerable. Beware of small caliber rocks and racoons!!!
    Your trunk is too dark, the floor is unprotected, and your rear console needs a cover.
    The solutions are here: Hidden Content
  3. #3
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    15,215
    Default
    It's actually a big eye-bolt, not a "hook". It should be under the cargo deck.
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 84,576 miles, 135 MPG, Remaining Oil Life 74%
    Typical Commute: 60 miles
    30 day Stats: 1366 miles, 125
    MPG, 65% Electric, 33% gas, Saved 48 gal., 27 kW-hr/100 miles
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5.
    Advertisement
  6. #4
    Join Date
    Dec 2010
    Location
    Woodland Hills, CA
    Posts
    360
    Default
    Quote Originally Posted by mudskipper View Post
    This is what it looks like.
    2011 Volt #001800 03/25/11 - 10/26/15 Diamond White
    2016 Volt #012849 10/20/15 - ? Iridescent Pearl Premier
  7. #5
    Join Date
    Dec 2013
    Location
    Norco/Corona, CA
    Posts
    2,486
    Default
    I posted pics and instructions how to use somewhere on this board. It's underneath everything in the trunk, and it's LEFT hand thread.
    Ménage à trois - 2017, 2016 and 2013 Volts.
    Tesla Model 3 Reserved
  8. #6
    Join Date
    Dec 2013
    Location
    Norco/Corona, CA
    Posts
    2,486
    Default
    This search engine is bizarre, but finally found it, click to see the hook and how to install:
    http://gm-volt.com/forum/showthread....66#post2828466
  9. #7
    Join Date
    Dec 2015
    Location
    Santa Cruz
    Posts
    24
    Default
    Thanks, all! I couldn't see the cover for the front hook when I looked at my test-drive vehicle--guess it just wasn't where I expected it to be.
    This is good news for being able to tie-down a kayak! Now if only somebody would start making a roof rack for a 2016 Volt, I'd be all set. (I'm gambling on Rhino doing so--hope it isn't a gamble I lose!)
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Front tow-hook license plate holder?
    By Spec R in forum Chevy Volt Accessories and Modifications
    Last Post: 06-11-2013, 11:16 AM
  2. Gasoline jump risks recovery. Go Volt!
    By Steverino in forum Politics, Finance, and Environment
    Last Post: 02-18-2012, 04:05 PM
  3. Costlier Oil Threatens Recovery
    By George S. Bower in forum Politics, Finance, and Environment
    Last Post: 03-06-2011, 08:58 PM
  4. Reserve Recovery Capacity
    By revolt in forum Totally Off-Topic
    Last Post: 07-15-2010, 01:30 AM
  5. Why not Hydraulics Brake Energy Recovery System?
    By JoeReal in forum Chevy Volt Engineering and Design
    Last Post: 06-16-2008, 07:59 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
