Has anybody run wire from the engine compartment to the passenger compartment?
Grab our Forum Feed
+ Reply to Thread
Results 1 to 7 of 7
Thread: Has anybody run wire from the engine compartment to the passenger compartment?
  1. #1
    Join Date
    Aug 2015
    Location
    Hudson Valley, New York
    Posts
    40
    Default Has anybody run wire from the engine compartment to the passenger compartment?
    All,
    I'm in process of wiring up some auxiliary lights (a pair of PIAAs). After removing the bumper cover and having mounted them, I'm at a point where I have to run the last bit of harness through to get to the switch. Anybody done this or have any ideas?
  2. #2
    Join Date
    Dec 2012
    Location
    kettle falls, wa
    Posts
    551
    Default
    I would suggest a relay pulling off a fuse connected to possibly the stud at the firewall for jump starting. You may also be able to tie into one of the fuses in the underhood fuse panel. It would be best not to have the full light current going through a dash-mounted switch and passing into the passenger cabin.
    2013 White Diamond, "Hal" Black leather w/white accents, Bose
  3. #3
    Join Date
    Aug 2015
    Location
    Posts
    40
    Default
    Thanks for the reply, but that doesn't address my question at all. Perhaps I need to be more clear: I'm looking to penetrate through the firewall or somehow feed wire from the engine compartment to passenger compartment. This is for a pushbutton switch to operate the aforementioned auxiliary lights.
    Addressing the mentioned relay and such: this is not an issue; power and ground is already wired to the contact of the relay. It's the manually operated pushbutton in the passenger compartment I'm trying to connect.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Oct 2013
    Location
    Illinois
    Posts
    7,353
    Default
    You didn't say what year, but this is a photo of where an airline was run through the firewall in a G1. Post #92 in this thread: http://gm-volt.com/forum/showthread....t=extreme+volt
  7. #5
    Join Date
    Aug 2015
    Location
    Posts
    40
    Default
    Thanks, Mister Dave! That does give me some direction. 2012, by the way.
  8. #6
    Join Date
    Oct 2013
    Location
    Illinois
    Posts
    7,353
    Default
    Quote Originally Posted by gbodybilly View Post
    You're welcome. I had a similar quandary so I asked Rapier Pilot. He's got a few things going through the firewall.
  9. #7
    Join Date
    Jan 2015
    Location
    North Dakota
    Posts
    818
    Default
    I was wondering the same thing as I prepared to install my ERDTT mod. Unfortunately I didn't need it as the wire is barely long enough to go behind the headlights. The engine compartment is so tight, it's difficult to run any wiring from the grill to the cabin.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Hosing Down Engine Compartment
    By VoltCrazee in forum Generation 1 Volt (2011-2015)
    Last Post: 05-26-2014, 12:45 PM
  2. Mount the charger inside the engine compartment.
    By PowerHouse in forum Chevy Volt Accessories and Modifications
    Last Post: 03-01-2012, 07:36 PM
  3. 6 Ft Gasket (about 6 ft long) Around Back Edge Of Engine Compartment has Loosened Up
    By Paul Slazas in forum Suggestions for GM - Chevy Volt
    Last Post: 07-11-2011, 11:02 PM
  4. Pressure Washing Engine Compartment?
    By Steverino in forum Generation 1 Volt (2011-2015)
    Last Post: 06-01-2011, 03:30 PM
  5. Passenger Compartment Temp.
    By RLM in forum Suggestions for GM - Chevy Volt
    Last Post: 05-13-2008, 08:21 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
