Differences Between the Ford C-Max Hybrid and C-Max Energi Plug-In
Grab our Forum Feed
+ Reply to Thread
Results 1 to 2 of 2
Thread: Differences Between the Ford C-Max Hybrid and C-Max Energi Plug-In
  1. #1
    Join Date
    Aug 2008
    Location
    Carlsbad, CA
    Posts
    1,567
    Default Differences Between the Ford C-Max Hybrid and C-Max Energi Plug-In
    Interesting article on the SAE home page discussing the difference in electronics between the hybrid and plug-in versions of the C-Max.
    "Turning a hybrid electric vehicle (HEV) into a plug-in hybrid (PHEV) is more than adding cells to a battery pack, reflashing the controller, and installing a charger. The 2013 Ford C-Max and C-Max Energi are examples of what it takes to develop conventional hybrid and plug-in versions of the same vehicle—that is, many specific parts, software, and validation."
    http://www.sae.org/mags/aei/11705
  2. #2
    Join Date
    May 2011
    Location
    Delaware
    Posts
    8,020
    Default
    Here's what I got out of it:
    Battery in cabin, air cooled by cabin air (like a lot of older hybrids)
    No electric heat.
    Even SAE doesn't understand ERDTLT on the Volt (article implies it exists to warm the battery.)
    Ford cools the battery due charging with ambient outside air (not cabin air?? Some sort of valve arrangement?) Charging in the middle of the day the the southwest may be problematic...
    Fords says that high cabin temps at rest aren't an issue, and the battery cools quickly once you start the car. (good insulation & dedicated A/C duct? More tolerant chemistry? Huge A/C system? Similar spin to Nissan's "we did extensive desert testing?")
    Hopefully Ford is using a more tolerant chemistry, but after reading this article, I think I'd be nervous buying one the first couple years if I lived somewhere hot.
    Walter
    2016 Tesla X75D delivered 8/25/16
    Hidden Content
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. How not to sell a Ford C-Max Energi
    By OhioEE in forum Hybrid and Electric Vehicle Competitors
    Last Post: 01-10-2013, 10:32 PM
  2. Ford announces Volt competitor: C-Max Energi
    By honoreitiscom in forum Chevy Volt General Discussion, News, and Events
    Last Post: 06-10-2011, 10:17 AM
  3. Ford premieres 500 mile C-MAX Energi
    By srschrier in forum Hybrid and Electric Vehicle Competitors
    Last Post: 01-12-2011, 09:39 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
