Charging Cord Problem
Grab our Forum Feed
+ Reply to Thread
Results 1 to 6 of 6
Thread: Charging Cord Problem
  1. #1
    Join Date
    Jun 2012
    Location
    Southlake , Texas
    Posts
    1,997
    Default Charging Cord Problem
    I''m having a problem with my 110v Voltech cord getting stuck in the charging port of one of my Volts . It gets stuck and when I can finally get it out it damages the head of the cord . The 240v Blink charger never gives me this problem .
    Anyone else having issues with their cord ?
    2012 Volt - Sold
    2014 Volt
  2. #2
    Join Date
    Nov 2012
    Location
    Omaha NE
    Posts
    1,045
    Default
    Without actually fiddling with it, I'm going to have a hard time telling what the problem might be. Can you tell if it's the latch mechanism hanging up or too much friction from the pins? If it's excessive friction on the pins, you can lubricate them with a bit of dry gun lube or other non-oily lubricant.
    2013 Crystal Red WATT GAS
    Stock EVSE converted to L1/L2 auto-switching
  3. #3
    Join Date
    Aug 2012
    Location
    Lost State of Franklin
    Posts
    1,415
    Default
    I have the opposite problem...my power Xpress level 2 SPX J1772 is loose in the port and occasionally doesn't seat. My Lvl 1 is a little tight. Plastic moldings and temperature change? It's not the latch per se.
    2012 White Diamond
    2014 White Diamond ..daughters
    Hydro Powered
    (By TVA)
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Jan 2012
    Location
    Streamwood, IL
    Posts
    226
    Default
    Quote Originally Posted by jfkirk View Post
    My 110v EVSE cord is a bit tight as well, but it requires just a bit more muscle to push in or pull out. I've only had my Volt for a few days though.
    I never thought I would own a Gen 1 Volt! Hidden Content
    Volt Baptismal Date: 12/10/12
    2013 Cyber Grey Metallic - ESP1, Comfort Package
    Logged 10,000 miles on 10/10/13: 8923 EV miles; Gas used: 35.3 gallons; 89% electric
  7. #5
    Join Date
    Feb 2012
    Location
    Torrance, CA
    Posts
    89
    Default
    I have the exact same problem. Every 240 v charger I use (at home or on the road) plug in and plug out perfectly. But the 120v one with my car plugs in fine but is always tough to get out. Since I have a 2012 model, this plug is not the original one that came with the car. This is the new one that replaced the original one (recall swap). The first one I had worked fine.
  8. #6
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    15,290
    Default
    I found with repeated use, they wear-in a bit and the issue goes away. Both my 120V units and my 240V unit displayed this "sticky" tendency for a few months. YMMV
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 85,558 miles, 125 MPG, Remaining Oil Life 38%
    Typical Commute: 60 miles
    30 day Stats: 966 miles, 108
    MPG, 62% Electric, 38% gas, Saved 33 gal., 31 kW-hr/100 miles
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Extension Cord Charging
    By graynator in forum Generation 1 Volt (2011-2015)
    Last Post: 03-10-2013, 03:27 AM
  2. Charging problem with 110 charging unit
    By ghostgs1 in forum Li-Ion Battery, Charging, & Battery Managment System - Chevy Volt
    Last Post: 06-25-2012, 12:32 PM
  3. Discoloration of charging cord?
    By AndrewW in forum Generation 1 Volt (2011-2015)
    Last Post: 07-13-2011, 08:22 PM
  4. Follow-Up: 120-V Charging Cord
    By CorvetteGuy in forum Chevy Volt Accessories and Modifications
    Last Post: 03-24-2011, 11:08 PM
  5. Retractable Charging Cord?
    By Eric E in forum Suggestions for GM - Chevy Volt
    Last Post: 09-10-2009, 07:42 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
