Hook for rear hatch came loose.
Grab our Forum Feed
+ Reply to Thread
Results 1 to 8 of 8
Thread: Hook for rear hatch came loose.
  1. #1
    Join Date
    Mar 2013
    Location
    Maryland
    Posts
    165
    Default Hook for rear hatch came loose.
    Has anyone else had the hook for the rear hatch latch come loose? If you have, do you recall what size torx bit that it takes and how you were able to access the fasteners. I might be able to work my way to them with a 1/4" flex joint and ratchet without taking off the panel. It doesn't appear obvious how to get the plastic panel off. Maybe I'll drill some small access holes in the panel since this thing will probably come loose again. The rear hatch gets quite a lot of use. Maybe some thread loc would be in order.
    Update: I was able to re-tighten the two torx screws by working a T30 torx bit around the spring loaded flap that obstructs access the screws using a 1/4" flex-drive extension.
  2. #2
    Join Date
    Oct 2013
    Location
    Fighting Illini country surrounded by bean fields
    Posts
    9,497
    Default
    I would never drill a hole to get to it. Do the job right. If your car is still under warrantee, take it to the dealer.
    LLninja (greenback troll #1)
    2013 Volt G1 white diamond tricoat
    If I can get the guy in the mirror under control I can be skinny and rich.
    If you don't have the money, don't buy it. Debt is hazardous to your wealth
    Hidden Content Originally Posted by doctorq Hidden Content
    "what kind of mental problem do you have? you should really get yourself checked out, are you on any type of psychotropic medications?
    R:IQ $2.2M, at $1.7M proj $4.8M
  3. #3
    Join Date
    Jun 2012
    Location
    New Hampshire
    Posts
    2,683
    Default
    Which hooks are you referring to? The 2 in the back just have little covers that pop off.
    Love My Volt!
    Blue Topaz, Black/Ceramic White Leather, Nav 2012
    New Hampshire
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Oct 2012
    Location
    United States - MD
    Posts
    6,359
    Default
    Ooo, that reminds me, I need to have 2 of the tabs in the hatch replaced where the rag cover is supposed to hang off of. Add that to my "things to get done before b2b warranty expires" list.
    Hidden Content
    Hidden Content
    My Bolt EV blog: Hidden Content
    cleantechnica.com and electrek.co: you suck, don't link my stuff
  7. #5
    Join Date
    Feb 2015
    Location
    England
    Posts
    1,524
    Default
    Quote Originally Posted by mdgreenster View Post
    Sounds like you're dropping it from a height each time to achieve that.
    Are your bump stops properly adjusted?
    I lower it and hold it around 6" gap, then let go of it. I use the plastic area around the release button as a 'hold-point' until I let go of it.
  8. #6
    Join Date
    Mar 2013
    Location
    Maryland
    Posts
    165
    Default
    It's the steel loop mounted on top of the rear sill that the latch of the rear hatch engages with.
  9. #7
    Join Date
    Jun 2012
    Location
    New Hampshire
    Posts
    2,683
    Default
    You will need to remove the 4 nuts that hold the trunk floor in place and remove it. Then simply grasp the bottom of the rear trim piece and pull out and up. There are about 6 clips that hold it in place.
    This thread has some more detail and pictures about removing the rear interior pieces:
    http://gm-volt.com/forum/showthread....trailer+wiring
    Love My Volt!
    New Hampshire
  10. #8
    Join Date
    Mar 2013
    Location
    Maryland
    Posts
    165
    Default
    Thanks, that looks easy enough.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Do you have to slam your rear hatch?
    By sminnick in forum Generation 1 Volt (2011-2015)
    Last Post: 07-01-2015, 09:53 PM
  2. De-badge Rear Hatch
    By 67Camaro in forum Chevy Volt Accessories and Modifications
    Last Post: 05-24-2015, 07:29 PM
  3. rear hatch
    By axelvolt in forum Generation 1 Volt (2011-2015)
    Last Post: 02-06-2015, 08:39 AM
  4. My 2013 Volt hatch latch is loose and rattles when I hit bumps.
    By Tom17 in forum Chevy Volt General Discussion, News, and Events
    Last Post: 08-12-2013, 03:02 PM
  5. Mysteries of the Rear Hatch
    By Carl S in forum Generation 1 Volt (2011-2015)
    Last Post: 04-02-2011, 04:20 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
