My Leviton 220 volt EVSE quick install
Grab our Forum Feed
+ Reply to Thread
Results 1 to 6 of 6
Thread: My Leviton 220 volt EVSE quick install
  1. #1
    Join Date
    Oct 2012
    Location
    Bronx, New York
    Posts
    101
    Default My Leviton 220 volt EVSE quick install
    Purchased a Leviton Evr-Green 16-Amp Blue Level 2 Electric Car Charging Station model EVB22-3PM from Home Depot.
    Here are some pictures of the install. Wasn't concerned about "looks" but functionality as this is installed at my office in the warehouse. I ran the cable under the gate and then into my Volt. I have the EVSE mounted upside down to reach the outlet. Doesn't bother me a bit.
    So much better than the 110 EVSE. I only charge at work so the 220 volt EVSE works much better for me.
  2. #2
    Join Date
    Oct 2012
    Location
    Sacramento, California
    Posts
    180
    Default
    Quote Originally Posted by BronxVolt2013 View Post
    Here are some pictures of the install. Wasn't concerned about "looks" but functionality as this is installed at my office in the warehouse. I run the cable under the gate and then into my Volt. I have the EVSE mounted upside down to reach the outlet. Doesn't bother me a bit.
    Attachment 8120Attachment 8119Attachment 8118
    Awesome
  3. #3
    Join Date
    Jun 2012
    Location
    Streamwood, IL
    Posts
    38
    Default
    I am confused a bit. It looks that you ran BX to the unit. I assume you have 3- 10 AWG guage wires inside for the 240 plug. Do you? And also, what kind of plug are you using. Can you take a picture of it? Thanks for the tips.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Oct 2012
    Location
    Bronx, New York
    Posts
    101
    Default
    It actually looks more complicated than it really is because of all the pre-existing boxes/conduits. If you look at the top of the three pole breaker box you will see a non painted EMT coming in. In there you have 4 wires, 3 "hot" wires and a neutral, (3 phase + neutral). The three wires 8 or 10 guage (forgot which) go into the breaker and one goes to the nuetral bar (not used by the EVSE). From the breaker I am only using two of the three legs which feed into the BX cable to the EVSE via the 20 Amp, 250 Volt, NEMA 6-20R, 2P, 3W. In the BX is a ground wire which is bonded to the breaker boxes frame.
    The reason for the 3 phase/3 pole breaker is unrelated to the EVSE. We test 3 phase commercial laundry equipment from time to time so I intend to add a box with Leviton 2510 connector so I can use a test cable to the equipment when needed. There will never be a time when I/we will use both the EVSE and the testing connection so no worries there.
    Here is the image of the connector I needed for the EVSE.
    http://www.leviton.com/OA_HTML/Produ...minisite=10251
    The second BX cable on the left is completely unrelated to the EVSE circuit. This BX is feeding power to the outlet box/gate(s) via separate wires coming in from the conduit in the top of the breaker box.
    To answer your question: From the breaker to the EVSE is 12 gauge which is perfectly fine for this length in this case.
  7. #5
    Join Date
    May 2012
    Location
    Grapevine, TX
    Posts
    1,335
    Default
    How long is the cable on that unit (unit to the car)? On my Blink Unit I could really use and extra 3-5 feet!
  8. #6
    Join Date
    Oct 2012
    Location
    Bronx, New York
    Posts
    101
    Default
    The cable is 18 feet. I also wish it was 25 feet but it works fine for me. As you can tell in the picture I just park closer to the gate.
    Quote Originally Posted by cab View Post
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Review of Leviton EVSE L2 32A 7.7kW Home Charging Station
    By dsinned in forum Electric Vehicle Batteries & Plug-In Charging
    Last Post: 05-19-2013, 08:25 AM
  2. Leviton EVSE L2 Evr-Green charger compatibility question
    By dsinned in forum Generation 1 Volt (2011-2015)
    Last Post: 11-19-2012, 09:50 PM
  3. EVSE Install and SPX Experience
    By Aceves in forum Generation 1 Volt (2011-2015)
    Last Post: 05-13-2012, 10:25 PM
  4. Replies: 19
    Last Post: 10-31-2011, 02:45 PM
  5. any proposals for convincing city or employer to install EVSE
    By lkarnold in forum Newcomers to GM-VOLT.COM (See here for FAQs)
    Last Post: 10-07-2011, 02:52 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
