Use of ethanol free gas
Grab our Forum Feed
+ Reply to Thread
Results 1 to 6 of 6
Thread: Use of ethanol free gas
  1. #1
    Join Date
    Mar 2012
    Location
    United States
    Posts
    12
    Question Use of ethanol free gas
    Would the use of Ethanol free gas be an advantage for the Volt. My wife and I love our Black 2012 Volt and and taken many trips with it as we are retired. Is this something that is plus for the user if the ethanol free gas is available.
    Thank you
  2. #2
    Join Date
    Mar 2008
    Posts
    1,299
    Default
    Ethanol free gas is going to be advantageous for any car owner. If you can get it, and don't burn gas that often (or your access to the ethanol is easy and not at a premium), then you should use it.
    I use only ethanol free gas in my boat.
    2012 Chevy Volt
    Please visit my blog at Hidden Content
    Twitter: @voltdriver
  3. #3
    Join Date
    Jul 2012
    Location
    Los Angeles
    Posts
    5,546
    Default
    There are some advantages and disadvantages to ethanol-free gas, but the primary advantage is better fuel economy (by 2% to 5%, typically). That advantage is offset by a higher price, but it might be worth it for some people.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Apr 2011
    Location
    Wickenburg, AZ
    Posts
    866
    Default
    Quote Originally Posted by lefty1630 View Post
    Well, that sort of depends on your view of why ethanol fuels are used in the first place. Ethanol fuels do have their positive side, otherwise they wouldn't be in the mix. I'm willing to bet that GM makes sure that their engines function as good as they can on ethanol fuels. Maybe in the big picture using ethanol fuels is more positive than negative.
    VIN # B0985
  7. #5
    Join Date
    Oct 2010
    Location
    So. Texas
    Posts
    1,265
    Default
    I can get ethanol-free gas but it's only from one station and only in regular grade. Although the volt has cut my fuel use dramatically, I'm not going to be one of those facing maintenance burns so long term stability isn't an issue with me.
    So here's my question: is ethanol-free regular better than premium with ethanol in terms of mpg? Price is about the same.
    Doug
    2013 CMax Energi Red (His)
    2015 Subaru Outback w/EyeSight (hers)
    2012 Jet Black Volt (sold)
  8. #6
    Join Date
    Jul 2012
    Location
    Los Angeles
    Posts
    5,546
    Default
    Quote Originally Posted by fotomoto View Post
    Most likely, but that is due to energy density. If your car is tuned for higher octane (typically very advanced ignition timing and high compression), a lower octane fuel (even if ethanol free) might cause the engine to retard to the point that you aren't seeing engine efficiency that you would normally see with the higher octane fuel. In my experience, very few factory cars are tuned so aggressively that they actually need premium grade fuel, but it some worst-case scenarios, it does become necessary.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Charge Point offers free ChargePass card for free on Earth Day
    By tangentlin in forum General Motors and General Automotive Topics
    Last Post: 04-22-2011, 12:52 PM
  2. biolectric better than ethanol
    By TimL in forum Chevy Volt General Discussion, News, and Events
    Last Post: 05-13-2009, 07:14 AM
  3. Biolectric better than ethanol
    By TimL in forum Chevy Volt Engineering and Design
    Last Post: 05-11-2009, 12:05 AM
  4. Ethanol News - ethanol fuel cell to be tested ...
    By Jason M. Hendler in forum Politics, Finance, and Environment
    Last Post: 03-12-2009, 04:54 PM
  5. Ethanol From Algae.
    By JoeReal in forum Totally Off-Topic
    Last Post: 06-12-2008, 10:58 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
