Beep, Chirp, Chime, Horn. A guide to what your Volt is saying.
Grab our Forum Feed
+ Reply to Thread
Page 1 of 5 1 5 LastLast
Results 1 to 10 of 44
Thread: Beep, Chirp, Chime, Horn. A guide to what your Volt is saying.
  1. #1
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    15,380
    Default Beep, Chirp, Chime, Horn. A guide to what your Volt is saying.
    Seems like a tone/chirp/beep cheat sheet would be handy. I'll start.
    BEEPS
    • High-toned beeps from the front speakers are for objects detected near the front bumper. (Ultrasonic Parking Assist)
    • Low-toned beeps from the rear speakers are for objects detected near the rear bumper. (Ultrasonic Parking Assist)
    • Beep with voice prompt. Navigation System Voice Recognition System
    • Several Beeps. Forward Collision Alert (FCA) System tailgating alert. Your vehicle is approaching another vehicle too rapidly, the red FCA display will flash. 2013 MY.
    • Three Beeps. Lane Departure Warning (LDW). The vehicle crossed a detected lane marking, the LDW
      indicator will flash. The Owners Manual may have a typo, also see Three Chimes. 2013 MY.
    • Four Beeps. There is insufficient time to fully charge by departure time.
    CHIMING (aka BONGING)
    Chime volume can be changed. Owners Manual: Instruments and Controls > Vehicle Personalization > Comfort and Convenience > Chime Volume. Not sure which of the chimes this will affect.
    • Chime. Delayed Locking. If delayed locking is enabled, a door or hatch is open when the doors are locked with the power door lock switch
    • Chime. Electric Parking Brake. The EPB is applied while the vehicle is in motion. The DIC message RELEASE PARKING BRAKE will be displayed.
    • Chime. Electric Parking Brake. Attempting to release the EPB without the brake pedal applied. The DIC message STEP ON BRAKE TO RELEASE PARK BRAKE will be displayed.
    • Chime. General Navigation Commands. The system responds to commands when feedback is OFF.
    • Three Chimes. Lane Departure Warning (LDW). The vehicle crosses a detected lane marking without using the turn signal. The LDW indicator will change to amber, flash.
    • Four Chimes. Driving and Operating. Entering the car, the key fob is in the car.
    • Five Chimes. Driver or Passenger Safety Belt. 1) The driver or a passenger is unbuckled, or 2) an object is on the seat such as a briefcase, handbag, grocery bag, laptop, iPad, cell phone, or other electronic device, etc.
    • Continuous Chiming. Driving and Operating. The driver door is opened while the vehicle is in ON/RUN.
    • Continuous Chiming. ENGINE OVERHEATED —TURN VEHICLE OFF. The engine cooling system reached unsafe temperatures for operation.
    CHIRPING
    • One Horn Chirp. Charging has begun.
    • One Horn Chirp. Tire Pressure Monitoring System Relearn procedure. Confirms that the sensor identification code has been matched to this tire and wheel position.
    • Two Horn Chirps. Charging is delayed, scheduled to begin later.
    • Three Horn Chirps. Setting Panic Alarm. The exterior lamps flash and the horn chirps three times.
    • Three Rapid Horn Chirps. The RKE transmitter(key fob) was left in the vehicle. This feature can be turned off. Owners Manual: Instruments and Controls > Vehicle Personalization > Remote Locking, Unlocking, Starting > Remote Left in Vehicle Reminder. Car: Config > Vehicle > Remote Locking, Unlocking, Starting > Remote Left in Vehicle Reminder [uncheck]
    • Four Horn Chirps. Insufficient time to fully charge by departure time
    • Repeated Horn Chirps. Electricity was interrupted before charging was complete.
    HORN HONKING
    • Soft‐note Horn. The Pedestrian Friendly Alert.
    • One Horn. Remote Lock Feedback. User configurable setting.
    • Horn. Panic Alarm pressed and held for three seconds. The horn sounds and the turn signals flash for 30 seconds.
    • Two Rapid Honks. Key left in car.
    • Three Rapid Honks. "Your car is still on!" Driver exited the car with the key and closed the door while the car is still on. 2014 and later, and those 2011-2013 that opted for the "Unintended Car Running" recall software update.
    • Two Horns. Tire Pressure Monitoring System Relearn procedure. The receiver is in relearn mode, or indicates the sensor identification code has been matched to the driver side rear tire, and the TPMS sensor matching process is no longer active.
    • 30 Second Horn. Anti-theft Alarm System. An attempt was made to open the doors, hatch, or hood while the alarm system was armed.
    • Continuous Horn. Charge cord unplugged alarm. The car is locked and the charge cord plugged in. Unlock door before unplugging. To disable the "unplugged" alarm on a 2011 you must take it to the dealer. Or, lock the door with the medal key and it's disabled for that lock/charge session. (Unknown if the key method also disables the horn chirping for power loss during a charge.)
    GURGLING, WHIRRING, WHOOSHING
    • Front of car. The car is heating/cooling the battery coolant and circulating it. This can happen plugged in or not.
    • Rear of car. Can sound like a piston. The gas tank pressurization system may be engaged to pressurizing the gas tank.
    CLICKING
    • Rapid clicking, drivers side rear. Heard when approaching the Volt with the key fob. (2012 +)
    SILENCE
    • Car is on. Or off. Check the Blue power button if unsure. Enjoy. :-)
    Please let me know if some Chimes/bongs, etc are nonstop or have a finite number. Not sure what the Panic Horn sounds like. Sure I could test all these, but now it's your turn, haha. I'll update the list as needed. Feel free to contribute which can be turned off by driver configuration. Also missing are the new safety lane departure sounds.
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 85,558 miles, 125 MPG, Remaining Oil Life 38%
    Typical Commute: 60 miles
    30 day Stats: 966 miles, 108
    MPG, 62% Electric, 38% gas, Saved 33 gal., 31 kW-hr/100 miles
  2. #2
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    12,437
    Default
    Great list! Don't forget BONG BONG BONG when you leave the car on and exit the car or leave the door open.
  3. #3
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    15,380
    Default
    Quote Originally Posted by DonC View Post
    That is listed as "Chime. Driving and Operating. The driver door is opened while the vehicle is in ON/RUN." I'm not sure if all chimes sound the same. I'll include bong in the description.
    B3320
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Oct 2010
    Location
    Lansing, MI
    Posts
    1,789
    Default
    Nice post!
    2012 / Silver Ice Metallic / Neutral Leather / Navigation / Bose / Hard Drive / Rear Camera / Park Assist / Sirius satellite radio / Polished Forged Wheels / WeatherTech Floor Liners / Volt All Weather Rubber Cargo Mat / Dual Cargo Nets / Volt Door Sill Plates / Battery Enhancement / StopSafe ECU (rear end accident avoidance system) / Diamond Gloss polymeric resin / Ziebart front bumper and hood paint protection film / XPel Door Edge and Doorsill Guards /
    James McQuaid
  7. #5
    Join Date
    Aug 2010
    Location
    Berwyn, PA
    Posts
    1,966
    Default
    Quote Originally Posted by Sterling Silver View Post
    I wish I knew how to disable a lot of the chirps. The most obnoxious is the "keys left in the car." I like to leave my keys in my Volt at home. Only Navy SEALS could steal my Volt where I live... (and probably Navy geeks are the only ones who can disable this particular annoying set of chirps...)
    In my 2011 Volt:
    Config --> Vehicle --> Remote Locking, Unlocking, Starting --> Remote Left in Vehicle Reminder [uncheck]
  8. #6
    Join Date
    Jun 2008
    Location
    Wisconsin USA
    Posts
    1,024
    Default
    Awesome post, Steverino!
    My 2012 Blue Topaz Metallic Volt... "C YA OPEC"... is GONE!
    *bzzt* -- Lease over! Whatta bummer! We had 33,200 great miles together.
    Lifetime MPG 270+, 90% EV driving bliss! May she serve her new owner well.
    Her replacement: a new 2014 Black Volt: "C YA OPEC mk.2"!
    10,300 miles so far, 88% on electricity, and 250 lifetime MPG!
    Lookin' forward to finding NEW roads and a thousand more "Volt Smiles!"
  9. #7
    Join Date
    Jan 2009
    Location
    Renton, WA
    Posts
    691
    Default
    I'm looking for a way to disable the "door open" chime after a few seconds. There is no need to keep nagging me forever and ever until I begin to entertain violent fantasies.
    My last vehicle had an electromechanical buzzer. I packed clay around it to reduce the obnoxious factor. It would be so easy to fix in software, but I don't see GM doing this (as this feature is likely designed by lawyers and nanny regulators instead of engineers).
    So I am thinking about a time delay relay in series with the door switch. Has anyone tried this?
  10. #8
    Join Date
    Dec 2010
    Location
    West Virginia
    Posts
    804
    Default
    Great Post. Thank you.
    I'm going to ask Chris C to add it to the FAQ he maintains.
  11. #9
    Join Date
    May 2011
    Location
    Delaware
    Posts
    8,020
    Default
    You realize you just became the Volt Whisperer, right?
    Seriously, thanks for putting this all together in one place. I'd heard most of it before, but it's never been assembled that I've seen.
    Walter
    2016 Tesla X75D delivered 8/25/16
    Hidden Content
  12. Advertisement
  13. #10
    Join Date
    Aug 2012
    Location
    Connecticut
    Posts
    127
    Default
    Thanks, the explanations are great.
    Volt White 2012
    Prius 2010
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Driver door chime
    By voltage692 in forum Generation 1 Volt (2011-2015)
    Last Post: 06-03-2016, 09:14 PM
  2. Ever use the Volt warning chirp to warn?
    By honoreitiscom in forum Generation 1 Volt (2011-2015)
    Last Post: 01-20-2015, 11:29 PM
  3. Can the delayed charging horn beep be turned off?
    By lese in forum Chevy Volt Accessories and Modifications
    Last Post: 05-02-2012, 05:50 PM
  4. Charging without the horn chirp..
    By tboult in forum Generation 1 Volt (2011-2015)
    Last Post: 10-30-2011, 08:21 PM
  5. Chevrolet Volt Owner User Guide
    By DougWernert in forum Chevy Volt General Discussion, News, and Events
    Last Post: 05-11-2011, 02:26 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
