Unable to access VoltStats
Results 1 to 8 of 8
Thread: Unable to access VoltStats
    1,632
    Default Unable to access VoltStats
    Update, suddenly I could access site. Maybe it's the buggy iOS6 I just down loaded on my iPad.
    Tom
    USAF Retired
    2012 Volt
    Best EV Range 50.x miles (more than once)
    Arlington, VA
    970
    I was unable to access it around 7am yesterday morning. When I got to work a while later, I was able to access.
    Dennis
    7.1kW grid tied solar/solar hot water
    2012 Volt- Diamond White, C22542 (fully loaded- MyLink-No Nav)
    2008 Prius
    Blink Level 2 EVSE
    VoltStats-Rocky Volt
    First year stats-- 13,100 miles, 100% EV, 22,500 mpg, 92.63 mpge
    Feb 2012
    Chicago Burbs
    280
    It varies for me. Certain times, no pattern, I will be unable to access the car via remote app. An hour later, things are fine, and no more issues for days, sometimes weeks.
    Silver Volt VIN: C03305, Nov. 2011
    Jun 2008
    Tolland, CT
    346
    I've been having problems for the past few days using IE9, but Firefox works just fine. Probably a glitch with a recent Microsoft update.
    2012 Blue Volt
    Voltstats.net: 2012-16084 (C-6084)
    In my garage charging for the 1st time on 24-Mar-12
    Typical Commute: 39 miles each way (Charging at Work!)
    All-Time Best....55.4 eMiles on a single charge.
    Colorado Springs, Colorado
    2,833
    Quote Originally Posted by David B. Kelting View Post
    If its IE9, its also possible you have been hacked. There was a zero-day exploit earlier this week and part of the side effect is that after it takes over you machine, it messes with IE9 to make it easier for it to do its job and help ensure no furture anti-virus fixes will correct the compromise.
    http://www.pcworld.com/article/20100...erts-warn.html
    http://tech.slashdot.org/story/12/09...ed-in-the-wild
    ________________________________
    BoultVolt Red 2011 #3745. More freedom than electric.
    Personal best, 82.1 miles on one charge.
    While I'm moderator my job there is to delete spam. To be clear, in my posts I'm speaking as myself. These views are my own and don't represent this board, my university, employer,etc.
    Just browsed it, no problems.. Chrome on OS X, with adblock/flashblock/etc .
    Jun 2008
    Tolland, CT
    346
    Quote Originally Posted by tboult View Post
    Seems unlikely, as I am able to access VoltStats but when I try to scroll down the through the entries it momentarily goes blank and then reverts back to the beginning. Also, I just performed a full scan with Malwarebytes yesterday.
    2012 Blue Volt
    Chicagoland
    751
    Quote Originally Posted by BAZINGA View Post
    Probably a transient.
    No problems for me just now with Safari on iPad 2 running iOS 6 GM (I was on the beta so I loaded the GM - should be the same as the commercial one they just released). I tried with Chrome on the same platform as well, again no problems.
    Perhaps there's a name check in the VoltStats code to bounce you
    Ron C. / Chicago-area
    2012 Crystal Red Tintcoat Volt C8794, acquired 11/08/2011
  1. Help! Unable to permanently set the correct date.
    By RobbertPatrison in forum Software/programming/code
    Last Post: 12-18-2012, 03:59 AM
  2. Unable to charge?
    By Curb71 in forum Volt Ownership Forum
    Last Post: 09-03-2012, 11:28 PM
  3. Unable to Charge
    By jbudacov in forum Volt Ownership Forum
    Last Post: 09-01-2012, 11:56 PM
  4. Replies: 15
    Last Post: 04-29-2012, 12:15 AM
  5. Unable to communcate with telematics module
    By black88mx6 in forum Volt Ownership Forum
    Last Post: 01-27-2012, 06:32 PM
