Car would not charge
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Car would not charge
  1. #1
    Join Date
    Mar 2012
    Location
    Boston
    Posts
    61
    Default Car would not charge
    This happened to me once, about a month ago, but since my Volt advisor hadn't heard of this before I'm posting it here.
    1. Came home after a three day trip in Mountain Mode. I switched out of MM a few miles from home, so there were a few miles left on the battery.
    2. Opened the charger door but didn't plug in right away. (PS we have 3 Volts at work sharing 1 charger and we do that all the time.)
    3. About an hour later, I connected my 120V charger. Nothing happened. The car didn't beep, didn't light up yellow, literally nothing. The charger was normal with all its green lights on.
    Here's what I tried: unplug and replug. Unplug the charger from the wall outlet and replug. These had no effect.
    Here's what worked: close the charger door, then open it again with the remote fob. Now when I plugged in, the light immediately went yellow and then green.
    Is it possible that the charge port is ignored if the car thinks the charge door is closed, and that it thought the door was closed in this case?
  2. #2
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    5,390
    Default
    That would be news to me, but I can try to replicate the "leave the charge door open but don't plugin for several hours".
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 30,821 miles, 139 MPG, Remaining Oil Life 100%
    Typical Commute: 57-67 miles
    30 day Stats: 1100 miles, 201
    MPG, 82% Electric, 28% gas, Saved 42 gal., 26 kW-hr/100 miles
    VOLT TIPS & SECRETS
  3. #3
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    6,258
    Default
    Your theory sounds reasonable but I've never heard of it.
  4.
    Advertisement
  5. #4
    Join Date
    May 2011
    Location
    Delaware
    Posts
    3,641
    Default
    We've never seen it before. Given your experience, I'm thinking the battery saver mode that kicks in after ~10 minutes of inactivity may shut down the charger's controlling computer if there isn't a connection by that time - though the charger will sit happily for hours or days with a validated cord waiting and charging according to your schedule, so it seems a little odd.
    Walter
    Volt FAQ
  6. #5
    Join Date
    Feb 2012
    Location
    Las Vegas
    Posts
    548
    Default
    Maybe its simular to when you unlock the fuel port which automatically relocks if not opened after a period of time. Perhaps the charge port disconnects after being idle for a period of time as well.
    US Army (Ret)
    2012 loaded Volt Viridian Joule
    2010 Prius
    7KW Grid Interactive Solar w/battery backup
    2.1KW Solar Hot Water
  7. #6
    Join Date
    Mar 2010
    Location
    Central NY
    Posts
    1,440
    Default
    Are you sure that the cord was fully plugged into the car each time? I've had numerous instances with my 240V Voltec of plugging it in, but the button on the cord doesn't fully release when I plug it in. Shifting it around slightly usually fixes it.
    Also, why not plug in right away, but set your car to delayed charging? That way, you can just force it to start charging at some point during the day via your phone/RemoteLink, rather than having to go out there to physically plug it in.
    Volt Emergency Power Wiring Kit - Provide backup power to essential appliances.
    Leaf Emergency Power Wiring Kit - Provide backup power to essential appliances.
    Commercial Level 1 Charging Station - Low cost solution suitable for Hotels, Employers, Airports, etc.
    Join thE REVolution
    2011 Volt #186, VIN: B-00186, Cyber Gray Metallic - TRADED! 28k miles, 9k engine, 120MPG
    2013 Volt #43404, Blue Topaz Metallic - Love the blue!
    [SIZE="2"]Driving for FREE with Solar PV!
  8. #7
    Join Date
    Mar 2012
    Location
    Boston
    Posts
    61
    Default
    Well, like I said, we leave the ports open for several hours each day at work and that's always been fine, so I don't think the ports time out in the hour mine was open.
    I am sure the plug was making good contact. It had several chances. And it's been a month since then, so if it was a wonky connection it would have happened again by now.
    And usually at home I do plug in right away, but I was unpacking the car and didn't get to it. I do have off-peak hours programmed for home charging and override to immediate at work.
  9. #8
    Join Date
    Aug 2010
    Location
    Detroit, MI
    Posts
    2,002
    Default
    @ davemac616,
    Once the control modules on the vehicle have gone to sleep (about a minute after the last passenger has exited), the vehicle will need to be awakened in order for it to see the coupler being plugged in. When you press any button on the key fob or open a door, the car will wake up.
    If you decide to plug in later, it might be best to leave the charge door closed, especially if parking outdoors. Thanks for your question!
    If you have any further questions feel free to contact the Chevrolet Volt Advisor Team
    (877) 486-5846
    New Volt Advisor Hours:
    Monday - Friday 8AM to 11PM EST.
    Saturday 11AM to 8PM EST.
    Closed on Sunday.
    voltsocialmedia@gm.com
    https://twitter.com/ChevyVolt
  10. #9
    Join Date
    Mar 2012
    Location
    Boston
    Posts
    61
    Default
    Hi Trevor.
    That makes sense and it explains my experience at home that one time, but then how do our three cars at work get charged every day? If my Volt has been parked for 4 hours with the charge port open, another person can unplug his Volt and plug mine in, and it starts charging immediately. Does the presence of his fob wake up my car enough to activate the system? I guess as a test today I should try switching the charge cord without the fob in my pocket. But I have definitely switched the cord both to and from my car. We all had to turn off the "sound alarm if cord disconnected" option, of course.
    We're in a parking garage so weather isn't a big problem.
  11.
    Advertisement
  12. #10
    Join Date
    Aug 2010
    Location
    Detroit, MI
    Posts
    2,002
    Default
    Hi davemac616,
    You are correct about the fob. If your coworker had his fob, your vehicle may stay awake long enough to accept the charge immediately. The control module for charging will wake up for a variety of reasons. Your vehicle might be awake for other reasons as well, such as OnStar (VoltStats.net) or self diagnostics.
    (877) 486-5846
    Closed on Sunday.
Similar Threads
  1. Coulomb, Failure to Charge on Delayed Charge Setting....NEW UPGRADED UNIT Available
    By George Parrott in forum Chevy Volt News and Events
    Last Post: 08-24-2012, 07:15 AM
  2. Charge taking forever! 16+ hours for one charge!
    By capshert in forum Newcomers
    Last Post: 08-16-2012, 11:10 AM
  3. A new way to charge.
    By Bzzzt in forum Chevy Volt Accessories, Modifications, and Hacks
    Last Post: 05-04-2012, 02:20 PM
  4. can Volt charge cord charge a non-Volt?
    By eplantz in forum Newcomers
    Last Post: 05-23-2011, 12:51 PM
  5. Replies: 0
    Last Post: 05-16-2008, 10:30 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
