Fluid leak
Grab our Forum Feed
+ Reply to Thread
Results 1 to 7 of 7
Thread: Fluid leak
  1. #1
    Join Date
    Jul 2012
    Location
    Little Rock, Arkansas
    Posts
    61
    Default Fluid leak
    I noticed today that my new Volt is leaking fluid. It is just in front of the drivers door, near the side of the car. It leaked quite a bit and when the liquid dries it is white and sticky. Anyone have any idea what it is. I thought it might be the AC but it leaked yesterday when I did not use it. Thanks for any help
    Clay
  2. #2
    Join Date
    May 2008
    Location
    Denver CO
    Posts
    1,548
    Default
    AC definitely will spit out water, especially once you first get going. Smell it and check if water or something else. No fluid I know of would turn white and dry up no less, other than water.
    America 1st - CHEVY VOLT, AMERICAN-MADE, AMERICAN-FUELED. White Diamond with everything.
  3. #3
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    5,187
    Default
    It's probably just water condensation. Even when the Volt is shut down... If you have it plugged in to your EVSE the temperature management system may run the AC to cool the battery. (And that can make more water condensate... Even with the car turned off.)
    If you suspect that it might be coolant... You should check the coolant levels under the hood. Open the hood and look near the front center. You will see two small coolant tanks. As you face the engine the smaller left hand tank should be about 1/2 full at the plastic seam. The larger right hand tank should be filled to the top fill mark. If either tank is empty... Don't drive the car. Call the dealer and tow it in for inspection.
    If the coolant tanks are filled correctly then you can drive the car in and ask your dealer to inspect it for peace of mind.
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Jul 2012
    Location
    Posts
    61
    Default
    I will check the fluids when I get home. The fuid is clear when it is wet but dries white and is sticky
    Clay
  7. #5
    Join Date
    Sep 2008
    Location
    my little grass shack
    Posts
    4,611
    Default
    Quote Originally Posted by clayk59 View Post
    Clay
    I agree completely with Fulgerite's comments. It's likely just condensation running off either the air-conditioning evaporator and/or chiller unit for the battery cooling. There are no perfectly clear fluids in the Volt, especially those that would evaporate in your driveway. The whitness visible when it dries is usually minerals or other contaminants within the fluid or from the floor surface.
    Check your fluids, but feel free to visit your dealer if you are still concerned.
    WOT
    Welcome Hidden Content as our latest forum vendor!
    Follow the Chevy Volt and other GM electrified cars on Twitter! Hidden Content
  8. #6
    Join Date
    May 2011
    Location
    Raleigh, NC
    Posts
    38
    Default
    Sometimes when the AC condensate sits on my garage floor and dries it creates a white area that sometimes grows like a fine mold. There is probably something in your concrete acting the same way.
    2012 Cyber Grey - Mylink
  9. #7
    Join Date
    May 2008
    Location
    Denver CO
    Posts
    1,548
    Default
    Must also say, absolutely, when it's plugged in all night (in the summer anyway) when I first leave, there's lots of water condensation dumping into my driveway. Clear, odorless, but with minerals from the air I suppose. I think you're fine, but hey, if it smells like anything other than water, then it's worth a quick run through. .
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Change Transmission Fluid?
    By daryllafferty in forum Mechanical Systems - Chevy Volt
    Last Post: 09-01-2013, 12:49 PM
  2. found a leak in the battery fluid radiator
    By voltowner in forum Generation 1 Volt (2011-2015)
    Last Post: 08-27-2012, 03:20 PM
  3. Pink Fluid From Volt?
    By dafreak in forum Mechanical Systems - Chevy Volt
    Last Post: 03-22-2012, 07:20 AM
  4. "Fill Windshield Wiper Fluid" Message remains after filling wiper fluid
    By Tmac in forum Problems/Issues, Driver Warnings or DTCs - Chevy Volt
    Last Post: 03-18-2012, 09:47 PM
  5. Windshield washer fluid that ships with the car - Winter safe?
    By mike1 in forum Generation 1 Volt (2011-2015)
    Last Post: 12-07-2011, 12:03 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
