Installed: Curt Towing Hitch
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
Thread: Installed: Curt Towing Hitch
  1. #1
    Join Date
    Aug 2012
    Location
    Saratoga, Ca
    Posts
    5
    Default Installed: Curt Towing Hitch
    Hi,
    There's a lot of interest in hitches for the Volt. I just installed the Curt Manufacturing hitch for the Volt and I'm really pleased. Price was just $137 on Amazon. It comes with the supporting hardware (but no tools). The instructions are superb - very easy to follow, with color photo inserts.
    The installation tales about 2 hours. I didn't lift the Volt as ground clearance was adequate, and the required tools are minimal. The only step that makes you stop and think is when you need to cut out two slots from the under-carriage trim - a piece of plastic that covers the trunk pan. But even that step was easier than it looked.
    I chose the hitch over a roof rack for my bikes as I didn't like the idea of the extra drag or the chance of wearing the paint job, which on a Volt is superb. The question of ground clearance comes up a lot - there's plenty. The front air damper always scrapes my driveway, but the hitch clears it easily.
    I can recommend the Curt hitch - great price for a do-it-yourself owner. If you prefer, a pro will charge approx $150 for installation.
    See photo for reference:
    ___________________
    2012 Volt
    Lic: XTRM49R
    VoltStats: Club Longo
    Max e-Range: 71miles on a single charge
    Hidden Content
  2. #2
    Join Date
    Aug 2012
    Location
    los angeles
    Posts
    242
    Default
    how much does it weigh:
  3. #3
    Join Date
    Aug 2012
    Location
    Saratoga, Ca
    Posts
    5
    Default
    The hitch weighs approx 32 lbs, a little heavier than my mountain bike.
    ___________________
    2012 Volt
    Lic: XTRM49R
    Hidden Content
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Aug 2013
    Location
    PA
    Posts
    71
    Default
    I'm about to install a Curt Hitch on my 2014 Volt and I'm wondering if you are still satisfied with it? My biggest concern is the ground clearance. I have a Curt on my Prius and no problems.
    Thanks
  7. #5
    Join Date
    Jun 2012
    Location
    Southern California
    Posts
    213
    Default
    @joetoocool underneath the volt was there a ready hole to screw a bolt to attach the hitch on both left and right side?
  8. #6
    Join Date
    Aug 2011
    Posts
    19
    Default
    I am wondering the same thing. Are the holes there to receive the hitch
  9. #7
    Join Date
    Aug 2013
    Location
    Republic MO
    Posts
    13
    Default
    Quote Originally Posted by joetoocool View Post
    Hi,
    Attachment 6763
    Do you use the curt stabilizing straps with your rack? I just order a hitch and a bike rack and want to get some opinions from owners that have this hitch. Thanks for your time.
    2012 White Volt - Premium Leather Seats Jet Black with Dark Trim, Rear Camera & Park Assist, Nav, Bose.
  10. #8
    Join Date
    Sep 2013
    Location
    Walnut Creek CA
    Posts
    132
    Default
    I installed a Curt on my wife's MDX and was happy with it. Was even happier when she just got rear ended and the hitch took the brunt of the force, destroying the Accord that ran into her.
  11. #9
    Join Date
    Jun 2014
    Location
    Houston, Texas
    Posts
    152
    Default
    I could get an XL frame road bike inside my Prius, with the bike's front wheel off and the car's rear seats folded. It fit easily. I haven't tried it with the Volt--I don't ride bicycles anymore--but eyeballing it, the cargo area looks like about the same volume of space, in about the same shape.
  12. Advertisement
  13. #10
    Join Date
    Jun 2015
    Location
    Central Florida
    Posts
    6
    Default
    Quote Originally Posted by SolarBoy View Post
    I just installed a Curt on my 2015. Instructions from Curt are not that good. They mention "drilling a hole forward..." on the driver-side without a precise location. SOLUTION: The passenger-side uses two factory installed pem nuts so I used them along with the drain plug bolt to temporarily hang the hitch. I then drilled the hole using the hitch as a locator for the hole (small bit, larger bit, etc.). Left the two passenger-side bolts in place, removed the drain-plug bolt, caulked the driver-side parts, and reassembled. Bought the Euro 1.25" tongue and so far have not heard a single drag going in/out of driveways and angled intersections.
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. curt trailer hitch
    By emd in forum Chevy Volt Accessories and Modifications
    Last Post: 10-18-2013, 08:27 PM
  2. The MY2013 Volt Reveal By Chevy Trainer Curt Miner- Thread #1
    By Selling Volts At Sundance in forum Chevy Volt General Discussion, News, and Events
    Last Post: 07-20-2012, 01:56 PM
  3. Finally got my bike rack installed on the TorkLift hitch: photos of rack and trike
    By artsci in forum Chevy Volt Accessories and Modifications
    Last Post: 05-31-2012, 09:48 PM
  4. Has anyone actually installed he Curt Hitch?
    By torn66 in forum Chevy Volt Accessories and Modifications
    Last Post: 04-22-2012, 12:27 AM
  5. Towing in FL
    By Mike McG in forum Generation 1 Volt (2011-2015)
    Last Post: 03-06-2012, 07:34 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
