Originally Posted by
SiestaKeyJimmy
Hey Guys - back to the original subject! (On the 2013)...
It seems to me that you can set the charge rate to 12AMPS anytime while you are driving (Your "last Leg") and it remembers it.
I saw somewhere in this subject that it resets it back to 8amps when you put it in park - but I think that is not correct???
(But I'm totally open to learning exactly how it works)
I THINK my experience is that anytime I am on my "last leg" of my trip (where I will finally put it in Park as I park in my spot next to my charger) - I can reset it to 12 amps - and it remembers that and charges at 12 amps.
If this is true - to me that simply means that at any time when I am on my "last leg" - (If I remember) I set it to 12 amps and it stays and charges that way - is this correct?
(In other words - it does not revert back to 8 amp when you put it in Park - it seems it reverts back when you take it out of park - or power down and power up) - ???
In any case it is always fully charged overnight at the 8amps - so that is fine with me. We are all different - (I go to bed early) and bugged by different things!
What drives me nuts is I set the Air Con on ECO - (and Automatic) - but then I get in and IT CHANGES the setting to Comfort all by itself - THIS DRIVES ME NUTS!! - also how DIFFICULT it is to turn off the Automatic Air Cond - endless hits on the "fan" to finally get it to off - why not simply an OFF button?
