Charging on 2013 12-amp vs. 8-amp option
Grab our Forum Feed
+ Reply to Thread
Page 1 of 11 1 11 LastLast
Results 1 to 10 of 103
Thread: Charging on 2013 12-amp vs. 8-amp option
  1. #1
    Join Date
    Jul 2012
    Location
    Detroit Metro
    Posts
    4
    Default Charging on 2013 12-amp vs. 8-amp option
    I pickedup my New 2013 Silver volt and the dealer showed me a screen where you can set the option for the Volt
    to recieve a 12AMP charge or 8AMP(or something like that)
    My issue: It resets itself back to the lesser every time I shut off the car.
    What am I doing wrong? There is no "save" funcion. I assume that if I click the option it will not
    default back to the latter every time.. Very irritating.
    The dealer told me that at 12 AMP the car takes a higher charge and that it also can extent the charge from 37 miles to 45 in time. Frankly I have only had my car 65 miles so there is not much to go on..
    Has anyone else seen this option under the energy tab? And how can we get it to stay at 12AMP?
    Thanks,
    Chip
    Last edited by WopOnTour; 08-17-2012 at 11:32 PM. Reason: sp in title (for search)
  2. #2
    Join Date
    Jul 2012
    Location
    Milwaukee, WI
    Posts
    1,269
    Default
    Designed that way. Welcome to progress. Thank the Lawyers?
    8KW solar.array
    96 square foot solar hot water array
    Solar clothes dryer
    Banned so often I should put it in my signature
  3. #3
    Join Date
    Jul 2012
    Location
    Detroit Metro
    Posts
    4
    Default
    Sounds like we need a software Hack that adds the button (Keep this BI@CH on 12AMP)
  4.
    Advertisement
  5. #4
    Join Date
    Jan 2011
    Location
    SE PA
    Posts
    3,478
    Default
    Dealer's wrong.
    Also, isn't it 8A default 12A settable? The '11 and '12 use a 12A default for 120V charging.
    No matter what rate you charge at, you get the same miles out of the car's total battery charge. It just takes longer to get there on 8A. 1.5A is ridiculous and I think that's a typo in this post.
    VIN: B-2672 Crystal Red - Light Neutral Leather § Current VoltStats
    USA-made 8.16KW Solar PV - SolarWorld + PowerOne Aurora ** Installation Blog
    Thank you to Stingray Chevrolet for a great purchasing experience. Current Volts
  6. #5
    Join Date
    Sep 2010
    Location
    Phoenix, AZ
    Posts
    2,673
    Default
    I have seen several threads about this and the car always defaults back to the lower charge setting on the 120V charger.
    I forces you to set the charge rate everytime you shut the car off.
    Diamond White #B2140 ecosister plate=SLRRYDER
    Crystal Red #C8885, Red-Rider plate=NO2OPEC
    No gas purchased, fully charged off Solar, OK so I bought some gas to go to Vegas!
    DRIVING for FREE! NO OPEC FEE!
    My TED 5000 power monitoring
  7. #6
    Join Date
    Jul 2012
    Location
    Detroit Metro
    Posts
    4
    Default
    1.5Amp.. was a question (which is Why I said Something like that) Its just a pain that we have to set it to 12 amp everytime.. When I go to that screen it defaults back to the lower number
    Quote Originally Posted by bonaire View Post
    Dealer's wrong.
  8. #7
    Join Date
    Jun 2008
    Location
    Tolland, CT
    Posts
    346
    Default
    Quote Originally Posted by solar_dave View Post
    I wonder what would happen if the owners of the MY2013 used the 120V Charge Cord from a 2011/2012.
    2012 Blue Volt
    Voltstats.net: 2012-16084 (C-6084)
    In my garage charging for the 1st time on 24-Mar-12
    Typical Commute: 39 miles each way (Charging at Work!)
    All-Time Best....55.4 eMiles on a single charge.
  9. #8
    Join Date
    Jan 2012
    Location
    Lakeland Florida
    Posts
    1,271
    Default
    Nothing, the car sets what ever it wants to as long as its less than what the wall cord advertises is available
    So for 2013, its 8 amps unless you manual set using the center stack for 12 amp and the wall cord says at least 12 amp is available ( 2013 wall cords have not user adjustable settings )
    For 2011-2012, you can use the wall cord and set ( and sticks ) for 8 or 12 amp and the car follows that setting
    2012 Crystal Red Volt #10921 - Plug Powered #76
  10. #9
    Join Date
    Jul 2012
    Location
    Detroit Metro
    Posts
    4
    Default
    Ok good info. I work at lear and know the guys that developed the charger. i am going to see if there is a work around.
    Thanks!
  11.
    Advertisement
  12. #10
    Join Date
    Jun 2008
    Location
    Tolland, CT
    Posts
    346
    Default
    S
    Quote Originally Posted by Henry_FL View Post
    So, if all 4 lights are lit on the 2011/2012 cord the MY2103 will still charge at the 8 amp default setting? I guess that would make sense since the cord is simply a "switch" and the charger is in the car itself?
    2012 Blue Volt
Similar Threads
  1. New mute option
    By Krellion in forum Suggestions for GM
    Last Post: 05-30-2012, 04:24 PM
  2. What's the least expensive L2 charging option?
    By JMatt in forum Volt Ownership Forum
    Last Post: 10-07-2011, 07:33 PM
  3. 220 Charging Option
    By VoltinME in forum Suggestions for GM
    Last Post: 08-31-2011, 04:29 PM
  4. Interesting Charging Option?
    By pKIO3 in forum Engineering and Design
    Last Post: 03-29-2010, 09:59 PM
  5. Option-More Kw-hr
    By George S. Bower in forum Suggestions for GM
    Last Post: 01-25-2010, 04:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
