It's Easy Being Green
Grab our Forum Feed
+ Reply to Thread
Results 1 to 8 of 8
Thread: It's Easy Being Green
  1. #1
    Join Date
    Oct 2010
    Location
    Columbus, Ohio
    Posts
    29
    Default It's Easy Being Green
    I'm not one to customize my car, but I couldn't resist this bit of personalization. It's subtle speaks to the environmentally friendliness of the car, and happens to be my favorite color. It's a bit of a pain to hand paint using G2 kit without removing the calipers, but I think I did a decent job.
  2. #2
    Join Date
    Mar 2012
    Location
    Kansas City
    Posts
    254
    Default
    Looks good. I like it.
  3. #3
    Join Date
    Mar 2008
    Location
    Fort Worth, TX
    Posts
    675
    Default
    I like it. But I doubt anyone will notice other than yourself or those you point it out to.
    2011 Blue Nissan Leaf SL (No QC Port)
    2012 White Chevy Volt
  4.
    Advertisement
  5. #4
    Join Date
    Feb 2012
    Location
    Las Vegas
    Posts
    548
    Default
    Looks great, good job
    US Army (Ret)
    2012 loaded Volt Viridian Joule
    2010 Prius
    7KW Grid Interactive Solar w/battery backup
    2.1KW Solar Hot Water
  6. #5
    Join Date
    Oct 2009
    Location
    Connecticut
    Posts
    1,379
    Default
    Looks good. Now you just need a black light on it....
    MrEnergyCzar
    My Chevy Volt Videos: One Year Review (click here) | Sexy Volt Car Wash (click here) |
    ................................Original Test Drive (click here) | 10,000 Mile Review (click here) |
    22,000 miles on 80 gallons | 100 miles per dollar (100 MPD)
    My Social Media Sites: http://xeeme.com/MrEnergyCzar
    09/30/2011 Delivered. (8,154th Volt Produced)[/QUOTE]
  7. #6
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    5,389
    Default
    The metal is galvanized. What primer did you use?
    Ah. I see G2 is a product line. "The G2™ High Temperature Brake Caliper Paint System Set is an epoxy based application, therefore it does not require the use of a primer."
    B3320
    Best All Electric Miles: 54.2
    Lifetime: 30,821 miles, 139 MPG, Remaining Oil Life 100%
    Typical Commute: 57-67 miles
    30 day Stats: 1100 miles, 201
    MPG, 82% Electric, 28% gas, Saved 42 gal., 26 kW-hr/100 miles
    VOLT TIPS & SECRETS
  8. #7
    Join Date
    Oct 2010
    Location
    Columbus, Ohio
    Posts
    29
    Default
    Thanks all for the compliments; I like the fact that it's subtle and that people with an eye for detail might notice. It's probably more noticeable at highway speeds.
    Steverino - Correct, the G2 brake caliper paint system does not require a primer. Per the instructions, I sprayed the brakes with the brake cleaner (included with the kit), masked off the rotors and pads, then used the included brush to carefully apply two coats of paint. It took over 3 hours but was a fun little project.
    -david
  9. #8
    Join Date
    Jan 2011
    Location
    Illinois
    Posts
    5,389
    Default
    TireRack carries G2 caliper paint
    http://www.tirerack.com/brakes/acces...tail.jsp?ID=41
    I read that some people have had bad experience in the past with painted calipers chipping. However, many caliper paints seem to be spray on, whereas G2 is a two-part epoxy and it includes a spray cleaner. Good surface prep makes all the difference when painting. Plus it's brushed on for more control than you'd get with a spray can. For about $12/wheel, it seems very affordable for those who want a color accent, though not as snazzy as the custom Volt caliper covers for $250-$270 or so.
    http://gm-volt.com/forum/showthread....=caliper+paint
    B3320
    VOLT TIPS & SECRETS
Similar Threads
  1. LED install in backup light is easy but a PIA
    By artsci in forum Chevy Volt Accessories, Modifications, and Hacks
    Last Post: 04-01-2013, 04:24 PM
  2. Allergies? Try the Breathe Easy Cabin Filter
    By jbfalaska in forum Chevy Volt News and Events
    Last Post: 06-27-2012, 07:41 PM
  3. Future easy upgrade for folks without NAV, HDD or eventually MyLink?
    By Brittt1 in forum Chevy Volt Accessories, Modifications, and Hacks
    Last Post: 12-12-2011, 09:29 PM
  4. WSJ: Facing Up to End of 'Easy Oil'
    By Steverino in forum Politics, Finance, and Environment
    Last Post: 05-25-2011, 09:38 AM
  5. Getting high EEStor yields won't be easy
    By Tom in forum Lithium and Advanced Automotive Batteries and Charging
    Last Post: 08-24-2008, 10:55 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
