Adding OEM Seat Heaters???
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Adding OEM Seat Heaters???
  1. #1
    Join Date
    May 2014
    Location
    Illinois
    Posts
    429
    Default Adding OEM Seat Heaters???
    Does anyone know the procedure for adding OEM seat heaters to a base model Volt?
    I am adding navigation to my 2012 Volt with cloth seats and because the replacement console has the heated seat buttons, I want to add them to the car.
    Does anyone know how?
    I know that car accessory shops can add aftermarket seat heaters with separate wiring and controls, etc., but is it possible to do this where the OEM factory switches and parts are used???? Or, at least just add aftermarket heater units, but have them controlled by the factory switches in the dash?
    Thanks!!!!!!!
  2. #2
    Join Date
    Jan 2013
    Location
    Anaheim, CA
    Posts
    1,015
    Default
    You'll probably have to find seats from a wreck using a yard's national parts finder. I would check Amazon for an aftermarket heated backpad that you could plug into an accessory socket. For those limited cold months is changing seats worth it?
  3. #3
    Join Date
    Oct 2013
    Location
    Illinois
    Posts
    7,456
  4. Remove Advertisements
    GM-Volt.com
    Advertisements
  5. Advertisement
  6. #4
    Join Date
    Dec 2012
    Location
    Welland, Ontario, Canada
    Posts
    982
    Default
    To add OEM seat heaters is going to be pricey. There are lots of places that sell aftermarket kits that come with the heaters and switches that work well.
    2014 Summit White Volt with black leather and dark accents.
    Loaded with all options including navigation.
  7. #5
    Join Date
    May 2014
    Location
    Abilene, TX
    Posts
    1,138
    Default
    For the sake of scientific inquiry, here are two questions.
    1) Lets assume that the OP finds a set of heated set at the local parts yard. OP now has the console with the buttons and seats with the heating elements. What else is needed? A control module (such as part#13502042)? Any updates to software, or additional harnesses?
    2) Let's assume that the OP chooses to install, regardless of the cost and labor involved, the heating elements in his/her existing seats. Is it just the process of
    a) removing the seat covers,
    b) installing the heating element (22786525, 20897260),
    c) removing existing harnesses and reinstalling two new harness (22786523, 22786522)?
    Said another way, is the difference between heated cloth and non-heated cloth just the wire harnesses and heating elements?
  8. #6
    Join Date
    Aug 2009
    Location
    Texas - DFW
    Posts
    4,477
    Default
    Buy a car equipped as needed. I have abandoned modding cars for so trivial a gain. It's just too expensive.
    Driving a show car. Every day! Hidden Content
    2014 Crystal Red ELR (REDD) code R w/Cashmere interior
    L2 - GE WattStation
    iOS 10.3.2 on iPhone 6. MyCadillac App version 3.6.0
    Hidden Content
    Hidden Content
  9. #7
    Join Date
    Dec 2012
    Location
    Brampton, ON
    Posts
    1,899
    Default
    I would think that, with the new console and switches already installed, you have the worst of it already done. It's not that big a deal for an auto upholsterer to strip down the seats and install the heaters. Maybe even do the rears while you're at it.
    2012 Volt, White, premium interior, nav and entertainment.
    2.8L/100 km., 55/45 EV and ICE lifetime
    Greenback Troll #2.75
  10. #8
    Join Date
    May 2014
    Location
    Abilene, TX
    Posts
    1,138
    Default
    Quote Originally Posted by Loboc View Post
    Agreed. I think we can all assume it will be more than the $275 for the Comfort package that was available when ordering. But play along here.
    What if the OP was suddenly transferred to Deadhorse, AK or diagnosed with circulatory problems. Adding features could theoretically be less expensive then selling and repurchasing another Volt with the features. I'm interested not because I want to do it, but to know what it would take for it to be done.
  11. #9
    Join Date
    Oct 2013
    Location
    Illinois
    Posts
    7,456
    Default
    Quote Originally Posted by saltsman View Post
    If people asked the tech at the dealer who can do the work and then told us, it would be so simple.
  12. Advertisement
  13. #10
    Join Date
    Feb 2014
    Location
    Chicago Burbs
    Posts
    446
    Default
    Why not float your question to Brian at theseatshop.com? Surely he'd know...
    https://www.youtube.com/watch?v=Fhd2DPbTjeE
    Gen 2 - 2017 Red Volt LT (purchased 10/16)
    Gen 1 - 2014 Red Volt Base (leased 2/14 - 10/16)
+ Reply to Thread
Quick Reply Quick Reply
  • Decrease Size
    Increase Size
  • Remove Text Formatting
Similar Threads
  1. Anyone put a child in the front seat yet with a booster seat?
    By cheifsfan in forum Generation 1 Volt (2011-2015)
    Last Post: 05-04-2016, 12:02 PM
  2. Seat heaters come on by themselves.
    By HOUSTONVOLTAGE in forum Generation 1 Volt (2011-2015)
    Last Post: 05-02-2016, 12:19 PM
  3. Seat Heaters not working?
    By KenPope in forum Generation 1 Volt (2011-2015)
    Last Post: 10-27-2013, 12:23 AM
  4. Is the 'low' level setting of seat heaters implemented by power cycling?
    By maestro77 in forum Chevy Volt Engineering and Design
    Last Post: 10-30-2011, 12:43 PM
  5. Oil Heaters for the Canadian GM-Volt
    By Interfacer in forum Suggestions for GM - Chevy Volt
    Last Post: 03-17-2009, 12:03 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
