Is there a way to force the display screens to day mode?
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
Thread: Is there a way to force the display screens to day mode?
  1. #1
    Join Date
    May 2012
    Location
    Los Angeles
    Posts
    227
    Default Is there a way to force the display screens to day mode?
    Whenever I leave for work in the morning, the displays are dimmed as if I'm driving at night (because the car is in my dark garage). When I pull out into the sun, it still can take up to 10 seconds for the car to realize that its daytime and switch off the headlights and brighten the displays.
    While I know I can switch the displays to "day view" and "night view," that only changes the colors of the displayed map and other text; switching to "day view" doesn't cause the display to turn bright like when its daytime.
    I hope I'm making sense with this question! Anyone know a way to force the displays to be bright (like during sunny daytime) when the car thinks it's too dark outside? Again, I'm not referring to the color change of the maps nor to the dial wheel to the left of the steering wheel that controls contrast in night mode; just whether the displays are automatically dark or bright (probably in conjunction with the headlights being auto on or auto off).
  2. #2
    Join Date
    Sep 2008
    Posts
    2,487
    Default
    I know what you are saying (not such a big beal IMO) but sorry no. (other than turning OFF the auto-lighting feature OFF completely by "cycling" the switch in the turn signal level to OFF and back again, it's spring loaded and will return to AUTO afterwards. This must be done with the car ON each IGN cycle though)
    Unfortunately in "AUTO" there's no practical method to alter this behavior (other than brightening your garage - a skylight maybe ;')
    About all you can really do is set the night-time brightness setting to maximum in order to minimize the transition (but then I find its too bright at night)
    WOT
    Quote Originally Posted by Blastphemy View Post
    Follow the Chevy Volt on Twitter! @WopOnTour
  3. #3
    Join Date
    Jun 2012
    Location
    Santa Rosa, CA
    Posts
    96
    Default
    The only thing I can think if is turning up the brightness of the display all the way while it is in night mode. That is the roller knob just to the left of the steering wheel on my MY12. It makes it pretty bright. You would probably want to turn it down when it is really night.
    Terry
    2012 White Diamond
    #25038
  4.
    Advertisement
  5. #4
    Join Date
    May 2012
    Location
    Los Angeles
    Posts
    227
    Default
    Quote Originally Posted by look4terry View Post
    As noted in my original post, I already know about that roller knob. But I shouldn't have to use that at all. I wouldn't have a problem if the screen would switch to its normal day mode immediately upon pulling into the sunlight, but it can take quite a while sometimes. Driving under overpasses causes the same problem.
    I own a 2012 Volt built in May 2012, and I'm surprised that the car still seems to have many "first year" glitches and omissions that I'd expect to have been resolved by now. Even more surprising is that the 2013 models don't appear to fix many of these problems either. Weird.
  6. #5
    Join Date
    Sep 2008
    Posts
    2,487
    Default
    Not a glitch.(and you're being a bit rediculous lol)
    Every GM car and truck with Auto-Lighting works this way for very sound rationale (as well as most other OEMs for that matter)
    If you didnt have the time delay, your lighting would be switching back and forth between day-night with cloud cover, buildings, tunnels etc
    You could always go back to manually controlling your exterior lights I guess... (turn the little knob from "AUTO" to OFF and back to AUTO with the car ON)
    WOT
  7. #6
    Join Date
    May 2012
    Location
    Los Angeles
    Posts
    227
    Default
    Not ridiculous if I previously had a $23,000 car that didn't exhibit any of these problems I'm having with the Volt. Still, I wouldn't trade in my Volt for anything else right now, and the little problems are just that - little. But it still would be nice if the systems were refined. Perhaps the Cadillac ELR will resolve all my complaints and be my next Voltec in 2014
  8. #7
    Join Date
    Sep 2008
    Posts
    2,487
    Default
    Then I can presume your $23,000 didnt have Auto exterior lighting features as THEY ALL work this way. (as will the 2014 ELR) lol
    WOT
  9. #8
    Join Date
    May 2012
    Location
    Los Angeles
    Posts
    227
    Default
    It did have auto exterior light features. It also let me override it on the nav display, so it never was a problem like in the Volt.
    All cars do not work the same way. There's a lot of "all cars do this" going around on this forum
  10. #9
    Join Date
    Sep 2008
    Posts
    2,487
    Default
    Like I said, you can over-ride the feature on the Volt as well. Just turn the little headlight knob from AUTO to OFF.
    How is that any different from your other car? (and you'll have to let me know what $23K car has full LCD NAV features)
    Lots of "incessant" whining about menial items happening on these forums as well. (especially in the last hr!)
    WOT
    Tell you what. I'll just move these threads into a more appropriate forum. Good luck with your suggestons!
  11.
    Advertisement
  12. #10
    Join Date
    Sep 2010
    Location
    Dublin, CA
    Posts
    190
    Default
    Quote Originally Posted by WopOnTour View Post
    How is that any different from your other car? (and you'll have to let me know what 23K car has NAV features)
    Lots of "incessant" whining about menial items happening on these forums as well. (especially in the last hr)
    WOT
    Moderator: Aren't you being a ittle reactive/harsh here? This is a legitimate question that I was asking myself just the past two days (my little toddler must have played with knobs becuase now my dispaly is super dim like the original poster is describing). I'll try the knob on the left. His question wasn't whining but a real question.
Similar Threads
  1. 2013 Volt - New DIC screens
    By Krellion in forum Volt Ownership Forum
    Last Post: 10-12-2012, 07:26 PM
  2. Hidden Diagnostic Screens
    By mhoepfin in forum Volt Ownership Forum
    Last Post: 05-02-2012, 03:02 PM
  3. Edit Screens
    By F16BMATHIS in forum Suggestions for GM
    Last Post: 01-11-2012, 12:18 PM
  4. Screens go almost dark....
    By hodad66 in forum Volt Ownership Forum
    Last Post: 09-23-2011, 11:20 AM
  5. Any change of display mode turns the radio on!
    By honoreitiscom in forum Suggestions for GM
    Last Post: 11-16-2010, 10:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
