How many kWh are 2013 Volt owners getting per charge?
Grab our Forum Feed
+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 25
Thread: How many kWh are 2013 Volt owners getting per charge?
  1. #11
    Join Date
    Feb 2012
    Location
    Niagara
    Posts
    57
    Default
    Late built 2012 here, got 10.6kwh and 93.7kms or 58.2 miles out of first charge before switching over to gas.
  2. #12
    Join Date
    Jan 2011
    Location
    Aurora, IL
    Posts
    453
    Default
    I have a 2013 (#3197) and on my first complete depletion of the battery I got 10.6 kwh.
  3. #13
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    6,275
    Default
    Quote Originally Posted by jsmay311 View Post
    Congrats on the car! The news slipped by me. Didn't know you had gotten it.
  4.
    Advertisement
  5. #14
    Join Date
    Sep 2008
    Posts
    2,493
    Default
    IMO this is a silly thread, (other than perhaps the original post's intention) as this topic quite often derails quite quickly into "mine get's xx" where people are attempting to compare apples to apples.
    This thread is the exact reason why GM was so reluctant to put a "Kw*hr used" parameter into the instrumentation.
    This value is NOT meant to represent a performance metric or a reliable method of comparing one car to another.
    Your kW*hr used per trip depends on many factors that include not only the three T's (temps,terrain, technique) but other factors that are related to certain charge efficiencies, even charge settings or usage (such as "cycling" the connector pre-drive to "top-top" charge) as well as user variables such as the use of air-conditioning, remote start, mountain mode, cruise control, or others.
    Besides AC and climate settings probably the most blatant variable is the # and duration of regen events. Surely one can see that anyone that has (due to terrain or even traffic controls) the opportunity for more or more extreme regen events is likely going to get more net current flow in and out of the battery and the displayed kw*hr out of that charge as the more events that occur, the more opportunity for the innacuracies/tolerances to "stack up" one way or the other. We make assumptions that it's 1:1 but there will always be some error in this so the more regen, the bigger the error can be.
    The kW*hr display is there to assist the driver in analysing their individual energy usage, that is all.
    Trying to compare apples-to-apples with other Volts is fruitless (pun intended)
    JMO
    WopOnTour
    Follow the Chevy Volt on Twitter! @WopOnTour
  6. #15
    Join Date
    Jun 2011
    Location
    Fairfax Station, VA
    Posts
    709
    Default
    Quote Originally Posted by WopOnTour View Post
    When I engage Regen down a hill, I see my kWh go backwards, aso it looks like this is being accounted for. Or is there an additonal amount of regen that is not being subtracted from the total kWh used?
    In my 2012 Volt, I can never even get to 10kWh. My range drops to 0, at 9.9. I see the 10% drop each time at either .8 or .9 kWh. I see the same behavior when I drop like grandma, or if I am in Sports mode and quoting another gm-volt member "I drive it like I stole it".
    VIN: C-10318, Crystal Red, Light Neutral Leather
    06/01/11 - Deposit placed on a 2012 Volt. | 11/14/11 - ECOtality Installs Blink EVSE | 12/03/11 - Volt arrives home! | 11/26/12 First trip to the gas station due to FMM.
    Lifetime Stats - 5,800 mpg | EV Miles: 27,000 | ICE Miles: 139 | EV% 99.5 | Gallons Used: 4.5 | Est Gal Saved: 1174 | $4,402 Saved
    EV Range Record: 56.0 miles | Volt Stats | HOF Score: 5
  7. #16
    Join Date
    Sep 2008
    Posts
    2,493
    Default
    Quote Originally Posted by ari_c View Post
    Sure, but the energy flow efficiencies in and out of the battery (whether charging or regen) vary, so my point was that these efficiencies of everything are so variable to numerous factors that unless 2 cars of the same condition (by that I mean age and charge-discharge cycles and charging technique) are driving the exact same route, in the exact same fashion, you wouldnt observe the same kW*hr readout. (and then possibly not "exactly" the same)
    The readout is for YOUR use. It is essentially useless to anyone else by means of comparison.
    WOT
  8. #17
    Join Date
    Jun 2011
    Location
    Fairfax Station, VA
    Posts
    709
    Default
    WOT
    Do you find it unusual that I cannot get more that 9.9 kWh on a full charge? Or could it be just that this is just how MY Volt is reporting the usage and if another Volt drove the exact same route I did in the same manner, it could possibly report 10.1 or 10.2 to depletion where mine would report 9.9?
  9. #18
    Join Date
    Sep 2008
    Posts
    2,493
    Default
    Now you're getting it!
    There is nothing abnormal about consistently getting a report of 9.9kW*hr across any number of trip cycles, especially if you did everything consistently in terms of charging and those trips were similar in terms of TTT.
    WOT
    EDIT> Here's a very good older thread that discusses some of the variables that can affect the KW*hr value displayed
    http://gm-volt.com/forum/showthread....ht=kwh+display
  10. #19
    Join Date
    Jul 2012
    Location
    Bloomington, IN
    Posts
    7
    Default
    OP here. My intent was to collect info from a small sample size to see if, over a limited drive time what people were getting from the new chemistry battery. WopOnTour makes a good point that we drive under different circumstances, but I was looking to see if the average '13 got more kWh than the previous models. I know it would only be a loose estimate, but information I thought would be helpful to the group as a whole.
  11.
    Advertisement
  12. #20
    Join Date
    Jul 2012
    Location
    Orlando, FL
    Posts
    134
    Default
    I got 10.9 kWh today on my 2013.
Similar Threads
  1. Replies: 58
    Last Post: 03-16-2013, 09:24 PM
  2. 2013 120v charge time always defaults to 16 hours?
    By MrEnergyCzar in forum Chevy Volt News and Events
    Last Post: 09-05-2012, 08:04 AM
  3. My new 2013 Volt
    By mikeabd in forum Buying/Leasing
    Last Post: 08-07-2012, 03:13 PM
  4. Replies: 42
    Last Post: 05-11-2012, 12:54 PM
  5. 2013 Honda Accord Plug-In Hybrid coming in winter 2013
    By Jason M. Hendler in forum Electric Car Competitors
    Last Post: 05-07-2012, 10:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
