A tale of two new Volts (interesting stats)
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: A tale of two new Volts (interesting stats)
  1. #1
    Join Date
    Jun 2012
    Location
    Plano, TX
    Posts
    223
    Default A tale of two new Volts (interesting stats)
    I took delivery of my 2nd Volt yesterday. It was driven from a dealership >150 miles away so it came with 210 miles on it. I was comparing the initial stats from the download on Volt-stats.net compared to the other Volt we took delivery a month ago and it is kind of interesting.
    Volt 1 (June 29)
    EV Miles: 42.1
    CS Miles: 41.6
    Oil Life: 98.3
    Economy: 64.9
    Volt 2 (July 31)
    EV Miles: 25.9
    CS Miles: 184.3
    Oil Life: 98.8
    Economy: 63.7
    What I found interesting is that the Lifetime economy is almost exactly the same where one car has 50/50 EV/CS and the other is only 14% EV. Also, the oil life on the car with less miles is lower.
    That seems to imply that the lower mileage car got really bad economy on gas before we took delivery. My theory is that it may have sat idling for a long time? Any other theories?
    I'm not complaining about anything, just thought it was interesting that they both started out with the same economy with such different backgrounds.
    Steve Martin
    2012 Blue Topaz Metallic Volt delivered 7/31/12 charged with Ecotality Project Blink EVSE
    2012 White Diamond Tricoat Volt delivered 6/29/12 charge with Ecotality Project Blink EVSE
    2012 Cayenne Red Leaf delivered 3/29/12 charge with eVgo/Aerovironment EVSE
    6kW Solar array
  2. #2
    Join Date
    Jul 2012
    Location
    Milwaukee, WI
    Posts
    1,269
    Default
    Quote Originally Posted by Cheezmo View Post
    My comment? I want to be you!
    8KW solar.array
    96 square foot solar hot water array
    Solar clothes dryer
    Banned so often I should put it in my signature
  3. #3
    Join Date
    Jun 2012
    Location
    Plano, TX
    Posts
    223
    Default
    Quote Originally Posted by montgom626 View Post
    And me you. My 6KW Array should be going up in the next couple of weeks!
    Steve Martin
    6kW Solar array
  4.
    Advertisement
  5. #4
    Join Date
    Oct 2011
    Location
    Lafayette, IN
    Posts
    127
    Default
    Wowee. Nice!
    Given that the Volt doesn't allow the engine to idle, I can only think that maybe the first only got a little bit of bad fuel mileage, and the second got lots of great fuel efficiency. Or the guess-o-mo-tron is just incorrect, but I doubt that.
    Two Volts, a Leaf, and a soon-to-be PV array? I hope I can get there someday!
  6. #5
    Join Date
    Jul 2012
    Location
    Milwaukee, WI
    Posts
    1,269
    Default
    Ground mount? ????? Pictures of the install always welcome.
    8KW solar.array
    Solar clothes dryer
  7. #6
    Join Date
    Jul 2009
    Location
    Colorado Springs, Colorado
    Posts
    2,864
    Default
    Yes it could be idle.. my car had more gas used and I eventually confirmed with the dealer they had idled it at the shoppe in MM to charge for some demos.. Can really eat up the gas that way, with no cs miles being added.
    Also could be car had a few test runs at the dealer with a lead-foot driver testing 0-60 in CS mode.. The algorithm for oil is supposed to reflect how hard the engine goes. MM and high-speeds can push the RPM into the 4K range which is much harder on the engine and much less efficient.
  8. #7
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    6,293
    Default
    I suspect it is the idle. If it's just idling then your MPG is 0. When the miles are so long just using a gallon makes a huge difference.
  9. #8
    Join Date
    Jun 2012
    Location
    Plano, TX
    Posts
    223
    Default
    No it will be on the roof. Just had a major hiccup though as we have power company choice here in North Texas and apparently my cut rate company (Pennywise) is trying to say that they don't support solar installations for their customers (never mind that they are owned by the same company writing the lease on the solar!). Having to change to a more expensive energy company in order to "save" money with solar isn't in the cards. Hopefully it will be worked out but this isn't the thread to discuss it.
    Steve Martin
    6kW Solar array
  10. #9
    Join Date
    Oct 2010
    Location
    Chicagoland VIN:B-01234
    Posts
    3,514
    Default
    Volt 1 (June 29)
    EV Miles: 42.1
    CS Miles: 41.6
    Oil Life: 98.3
    Economy: 64.9
    Volt 2 (July 31)
    EV Miles: 25.9
    CS Miles: 184.3
    Oil Life: 98.8
    Economy: 63.7
    Volt 1 definately got poor MPG in CS. Consider 40 miles EV and 40 miles on gas at 40 MPG is "80 MPGused'. A frequent comment I make when folks tell me they need to go over 40 miles on their daily round trip/RT.
  11.
    Advertisement
  12. #10
    Join Date
    May 2012
    Location
    Grapevine, TX
    Posts
    430
    Default
    I am seeing what I consider to be REALLY poor ICE mileage on my Volt based on how the ICE gets used. I often run just a few miles over my charge range each day and that has me burn some gas for sometimes as little as a a few hundred yards, and other days as much as 4 or 5 miles. I don't know what it is, but those few miles (almost always city and low speed) use an inordinate amount of gas. Comparatively the few days I end up blowing past the electric range and burning a full gallon show the full gallon's number to be much better. Those little short bursts seem to hurt. Admittedly, it may average out over time. I only have 652 miles total on the car with 88 miles being ICE. I have gotten about 23 mpg ICE for those 88 miles. While any ICE gets worse mileage in city vs. highway driving, that is a pretty big delta.
Similar Threads
  1. Tale of Two Air Dams
    By Adarondax in forum Chevy Volt News and Events
    Last Post: 02-08-2013, 01:19 AM
  2. A Tale of Two Cities
    By WopOnTour in forum Politics, Finance, and Environment
    Last Post: 06-25-2012, 05:11 PM
  3. A Tale of The More The Merrier-
    By Selling Volts At Sundance in forum Volt Ownership Forum
    Last Post: 05-30-2012, 03:58 PM
  4. Interesting Russian take on NYPD Chevy Volts
    By Codyozz in forum Chevy Volt News and Events
    Last Post: 11-01-2011, 05:40 PM
  5. A Volt Holiday Tale
    By Electric Lurker in forum Volt Ownership Forum
    Last Post: 12-21-2010, 08:52 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
