Any advantage to choosing to do a slower 120V charge that a quicker 240V charge?
I thought I read somewhere that fast charging (240V) may be "harder" on the HV battery.
Not from a battery life perspective. A 4 hour charge is still "slow".
There are other advantages to 240V including better preconditioning in cold weather.
True fast charging (IMO) is anything above 1C charge rate. 4 hours = C/6 rate, or 1/6 the capacity of the cells (about C/(4*.65)) where .65 is the total capacity actuall "recharged". Which is a "very mild" charging rate. I also don't think Leaf "fast charging" at 6.6KW is that fast since it takes about 3-4 hours to fill their capacity.
VIN: B-2672 Crystal Red - Light Neutral Leather § Current VoltStats
USA-made 8.16KW Solar PV - SolarWorld + PowerOne Aurora ** Installation Blog
Thank you to Stingray Chevrolet for a great purchasing experience. Current Volts
6.6kW is the Leaf on a 220V line with the rumored upgrade (or the FFE on 220.) Chamedo(sp?) Fast Charging is another thing altogether - the external fast charger pushes power onto the DC High voltage bus directly, and achieves an 80% charge in 30 minutes, with over 20kW of raw power.
Many Volt Owners and Leasers are getting along just fine with their 120V arangement. Some like myself are getting outstanding results-
I know what I discribe below is NOT typical for some Volt Owners and Leasers, however, I want to give many of you newer volt drivers some great ideas-
I drive what the majority of the drivers do in this country, 40 miles or so a day. When I unplug in the morning, I am averaging 46- 50 Miles per Charge- With massive Deceleration Regeneration ( Regenerative Breakiing ) by driving in L most of the time, upshifting to "D" for long D.R. Opportunity Glides I usually Manage 55- 60 real Miles Per Charge-
http://twitter.com/AmazingChevVolt/s.../photo/1/large
My Volt is plugged in at work and after the 12 mile or so run in, is fully charged in 2 1/2 hours. I may unplug while at work, or any time to run erands, go to lunch or show off the Volt. Plug back in when done. This takes about 16 seconds per plug/ unplug event as I carry the charge cord cleanly looped and in a Duffel Bag in the trunk.
Again, using L1 charging, short periods of time, charging at work, using heavy Regenerative Deceleration has reduced my net cost for driving my 1250 miles or so a month to less then 15.00 a month electricity cost.
They beat our brains out in 2008 as the cost of a gallon of gasoline surpassed $3.00 in March of 2008 and moved on to $4.00 there after, staying there till late December of that year. This unexplained, and unopologised for economic crippling that destroyed many businesses may be happening again.
We were then, totally unprepared. Then I stated, NEVER AGAIN! We are ready for it now- If it happens again!
-Finally, be advised to remember to reset the Amp flow charge button on your new MY2013 Amazing Chevy Volt EREV when 120V ( L1 ) charging.
Located on the center stack, this new prompt resets the Volt charging to 12Amp from the now concervative 8Amp default.
http://p.twimg.com/Ax-e6BzCQAAiD1C.jpg:large
Once in park, with the parking break set, ( Always recomended whenever you are done driving- ), tap the Leaf button, tap charging, tap change charge level, tap Maximum 12 Amp button so that it glows green- Good To Go!
Note, you can switch this setting at any time. Turn radio on to access most center stack promps even whev the Volt is not booted up- ( Running ).
This is an easy habit to get used to.
Best, Thomas J. Thias-
The Amazing Chevy Volt EREV-Facts Guy
Out of Stock-March 12, 2012 CU114012 Ally Bank LSE- 36/45,000
"American Made"
"My Volt Is American Made, Built And Fueled In The USA,
From Its 100 Mile Top Speed To Unlimited Range, My Volt Is American Made!"
AmazingChevyVolt@aol.com
www.twitter.com/AmazingChevVolt
http://www.gm-volt.com/forum/showthr...lt-White-Paper
Reloaded: February 24th, 2012
110 volt charging works great and the cost of a 220 will never be recovered for most volt drivers.
HOWEVER, the 2013 aggravating 4touch reset requirement for 8/12 amps is a blunder and should be reversed or at least made a one-touch adjustment. I guess sometimes owners have been blowing circuit breakers, but t The ease of daily plug in is important. Also, no flashlight? I have no convenient light in my garage, am I the only one?
My volt is near perfect, don't mess it up
I agree that the 8/12 amp change would be a major annoyance. I don't care if it is an "easy habit", any extra steps I have to take to do the thing I do every day (or multiple times per day) is an annoyance. Let the user set a default at least! I already have the annoyance of turning off the park assist and switching to sport mode every time I start driving. Now we are going to add something extra I would have to do every time I stop? No thanks.
The flashlight isn't a big deal for me. Never needed it with the Leaf, I usually have a garage light (or the car headlights are still on) when I'm messing with the charger anyway.
Steve Martin
2012 Blue Topaz Metallic Volt delivered 7/31/12 charged with Ecotality Project Blink EVSE
2012 White Diamond Tricoat Volt delivered 6/29/12 charge with Ecotality Project Blink EVSE
2012 Cayenne Red Leaf delivered 3/29/12 charge with eVgo/Aerovironment EVSE
6kW Solar array
My one way commute is exactly 39 miles. I charge at home 120 and at work 220. I arrive each way with about a 1-2 miles of EV range left.
After doing this almost daily for about 4 months; I've noticed no difference in range/capacity when charging either way.
The thing is, 120V charge was fine to me at the beginning but it's too confining. For me, the 240V charge meant freedom for my schedule. I go home for lunch, pick up the kids after school, go to the store. My house is like an airport hub, I charge every time I get home. I don't have to worry about waiting an hour for an average of 4 mile per charge.
For me, it does make a big different on my "freedom". Yes it cost a bit more for the 240V set up, but for me - I don't know about most users, but since I have the Volt, I'm obsessing about "EV only" mode- it worth every penny.
Yeah the 240 charger is really for a convenient charge time. Grab an hour and get 10 miles. It lets you run all electric much more.
Diamond White #B2140 ecosister plate=SLRRYDER
Crystal Red #C8885, Red-Rider plate=NO2OPEC
No gas purchased, fully charged off Solar, OK so I bought some gas to go to Vegas!
DRIVING for FREE! NO OPEC FEE!
My TED 5000 power monitoring
