Loose Front End or Not?
Grab our Forum Feed
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Loose Front End or Not?
  1. #1
    Join Date
    Jun 2012
    Location
    Santa Rosa, CA
    Posts
    98
    Default Loose Front End or Not?
    At just about 35 Mph I feel a slight flutter (or looseness) from the front end of my Volt when I am on a smooth road. It is not significant, but seems to be there. It is not there at slower or higher speeds. I have about 1440 miles on my Volt. I have not hit any curbs. Could it be wheel balence? I should probably take it in but I don't want stop driving it and it is just a slight annoiance. I've been waiting for something significant to get looked at.
    Terry
    2012 White Tri
  2. #2
    Join Date
    Jul 2008
    Location
    San Diego
    Posts
    6,475
    Default
    Nothing is better than a Volt on a smooth road. I wouldn't want that disturbed. I'd have it checked out.
  3. #3
    Join Date
    Mar 2012
    Location
    Illinois
    Posts
    1,812
    Default
    My last two cars were a 2007 Z06 and a 2008 Jaguar XK, both cars had buttoned down suspensions with tight and precise steering. The Volt is even better.
    If you feel this anomally on EVERY road EVERY time you drive it, there's something wrong. Only you can answer that.
    Tom
    USAF Retired
    2012 Volt
    Best EV Range 50.x miles (more than once)
  4.
    Advertisement
  5. #4
    Join Date
    May 2011
    Location
    Delaware
    Posts
    3,782
    Default
    Quote Originally Posted by DonC View Post
    It's amazing how much more aware of the surface and condition of a road you become in the Volt (and other EVs?), isn't it?
    Walter
    Volt FAQ
  6. #5
    Join Date
    Jul 2012
    Location
    Connecticut
    Posts
    1
    Default
    Received my 2012 volt 6 weeks ago and have a front left flutter at speeds from 38 to about 55 mph. Today will be the third time i bring it back to the dealer. If not fixed soon i will investigate the return program and ask for a new car. I love the car but this noise will drive me nuts if not fixed. I now have 1800 miles on the car, bought it at Karl chevy new Canaan ct, drove to florida and bringinging it to dyer chevy in vero beach trying to get it fixed. It mist be fixed as i once had a new lincoln with a squeak in the dash which they never fixed and drives you nuts the longer you own it
  7. #6
    Join Date
    Apr 2011
    Location
    Texas
    Posts
    316
    Default
    Quote Originally Posted by look4terry View Post
    Terry
    2012 White Tri
    No way to know if it's the same or not but there is/was a service bulletin #PI0409 that addresses loose/broken/not sure fasteners in the front passenger wheel well that under certain circumstances caused a fluttering noise. For me it usually seemed to be dependent on outside wind speeds and direction relative to my direction of travel. My speed didn't seem as important as I heard it at 35mph and 70mph. I never felt anything as much as simply heard the noise.
    May not be your issue but probably wouldn't hurt to ask your dealer. They fixed mine and it's never done it since. I have 25K+ miles on mine. Also, this was on a 2011. No idea if this service bulletin is relevant to 2012's or later.
    Volt #2243
  8. #7
    Join Date
    Nov 2010
    Location
    Tewksbury, MA
    Posts
    540
    Default
    The volt has much better road feel then given credit for. If this flutter happens on the same road at the same speed, it is most lilkely the road, if it happens on any road at at the speed you noticed it at, then it is the car (tires, front end etc.). If it is the car go to a different dealer or tire shop and get a second opinion. Sometimes when you go in multiple times at the same dealer it is given to the same tech. and you end up with the same answer, because he will not admit that he or she is wrong, incorrect. The volt is a very smooth car and any imperfection, road, tires or front end will telegraph it to you.
    VIN#...B...01921 - Build completed 03/1/2011 - Picked up my new red Volt at Atlantic Chevrolet on Saturday March 26th, 2011 .
  9. #8
    Join Date
    Jun 2012
    Location
    Santa Rosa, CA
    Posts
    98
    Default
    Mine I feel more then hear.
    Terry
    2012 White Diamond
    #25038
  10. #9
    Join Date
    Jun 2012
    Location
    Santa Rosa, CA
    Posts
    98
    Default
    Good point, I need to use the same problem solving skills I use doing software design. I'll be more observant. Thanks for the advice. It will give more information when I take it in.
    Terry
    2012 White Diamond
    #25038
  11.
    Advertisement
  12. #10
    Join Date
    Sep 2011
    Location
    Los Angeles, CA
    Posts
    2,069
    Default
    Just observing the behavior is not the only way to diagnose the problem. Physical issues such as wheel balance, loose bolts, faulty bushings, etc... Can be observed directly and corrected by a qualified mechanic. Don't wait until the wheels fall off to take it to a Chevy mechanic and have it inspected. You could have a serious safety issue.
+ Reply to Thread
Similar Threads
  1. Front air dam - do you have it on?
    By AllenL in forum Chevy Volt Owners Forum
    Last Post: 2 Weeks Ago, 08:30 PM
  2. Front air dam
    By patrick40363 in forum Chevy Volt Owners Forum
    Last Post: 06-06-2012, 11:21 AM
  3. Replies: 5
    Last Post: 01-16-2012, 09:06 AM
  4. Oxygen Ions For Fuel Cells Get Loose At Low(er) Temperatures
    By JoeReal in forum Totally Off-Topic
    Last Post: 07-02-2008, 08:45 AM
  5. Turn it loose !
    By Jim in forum Suggestions for GM - Chevy Volt
    Last Post: 05-08-2008, 02:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
