Air does not just jump out of the way of an approaching Volt cuz it's scared. It takes energy to PUSH the air out of the way while the car moves forward. Just like it takes energy to PUSH your hand through a pool full of water. You have to PUSH the air molecules out of the way so the Volt can fit into that space and move forward. (This always requires energy.)
Chevy engineers spent a lot of time and effort to design the Volt to be as "pointy" as possible to reduce air drag... But you still need POWER to PUSH the Volt through the air. Faster you go... More POWER required.
If you are suggesting that you can put little windmills all over the Volt to recharge the battery... Windmills adds drag. It's like trying to pick your self up by pulling on your shoelaces. No matter how hard you pull on your shoelaces you can't lift your self off the ground.
